Old 06-03-2017, 10:49 PM   #3871
derass
Originally Posted by 240sxRuinedMe View Post
anyone know if I'll be able to fit a square set up of cosmis xt-006r 18x9.5 +10 on a s13 coupe with stock fenders.
I'm definitely gonna keep stock body lines but wanting to run an aggressive setup with thick rubber on
That's a pretty aggressive size. You can probably make it fit with -3* (or more) camber all around and 205 or 215 tires. But that's not "thick rubber".
I would look for something closer to 18x9 +20. Then you could run a 235 - 255 tire and less camber.
Old 06-04-2017, 11:00 AM   #3872
imerse
imerse is an unknown quantity at this point
anyone know how 15x9 -15 look on stock body s13?
imerse is offline   Reply With Quote
Old 06-04-2017, 11:48 AM   #3873
derass
Poked out like crazy with super stretched tires. Search the dorisha thread.
Old 06-06-2017, 12:08 AM   #3874
1gr8bar10der
1gr8bar10der's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
I have that exact same wheel spec to put on my S12. I'll run fender flares though.
Old 06-06-2017, 12:30 AM   #3875
1gr8bar10der
Trader Rating: (77)
Originally Posted by integlspwr View Post
Need help with ordering my CRkai 2pc fam!
I currently run 18x10.5 +18 Te37RT's on my s2000 but would like to get Work EMOTION CR 2P.
Looking at this:
I have no idea what size lips I would get. I have a J's racing BBK on the front of my car so I assume I would have to get L Disk.. But then wwen I go on the 18x10.5 line and look under L Disk. I see.. "79(35)~-3(117)" I assume that 18x10.5 +79 would get me a 35mm lip and a -3 offset would get me a 117mm lip. But what about a +18? The rears I know I can go A Disk. but then what size lip would I get? with a 18x10.5 +18 with a A-Disk..
Any help is greatly appricated. Thanks!
It's a little tricky here. I'm looking at S1 3P's chart for comparison. The 10.5" with 16mm offset will get you 109mm lip size with A disk. The CR 2P should yield you a similar result.
So hope it helps.
Old 06-07-2017, 12:36 AM   #3876
strat.attack13
strat.attack13 is an unknown quantity at this point
So I'm a newb, and don't know much on rim sizing. I currently have a celica, but i'm trying to sell/ trade it for an s14, but my parents said only if I have everything priced out. I don't want a drift car, jjust something fun that handles well, so I'm trying to figure out what rims I would have to get. The car I'm looking at has 50mm rear overfenders and 20mm fronts, but stock wheels. I couldn't find anything really helpful that I understood, other than about an 18x9 in the front and 18x10 in the rear. what offsets would I need? I was looking at a set of xxr 551's that are 18x9.75 +36 would those work?
strat.attack13 is offline   Reply With Quote
Old 06-10-2017, 12:20 PM   #3877
marcyeo
marcyeo is an unknown quantity at this point
I'm looking at getting tires in:
225/40/18
or
225/40/17
On an S13 Hatch, what width wheel could I expect to fit for 17 and 18 respectively WITHOUT any fender modifications whatsoever.
marcyeo is offline   Reply With Quote
Old 06-10-2017, 12:35 PM   #3878
1gr8bar10der
Trader Rating: (77)
9.75" +36mm offset fits decent on stock body. With those overs you'll have, they would be sunken way inside the wheel wells. If you have a bunch of friends who can lend you hands, ask or borrow them some wheels to do a test fit on your S14 and go from there. That, you'd get the idea on what wheels sizes you'll have to order.
Old 06-10-2017, 12:38 PM   #3879
1gr8bar10der
Trader Rating: (77)
225/40/18
or
225/40/17
The width between 8-9" and offset between +20-30mm should be good if you don't want to do the fender modification.
Old 06-10-2017, 12:41 PM   #3880
marcyeo
I'm planning on running BC Coilovers soon. Should +20-30mm clear? Will it fit flush or will I need any spacers or anything
Old 06-10-2017, 01:08 PM   #3881
1gr8bar10der
Trader Rating: (77)
Hmmmm can't really pinpoint on this on since I've never run that specific wheel size before. However, I've done 1810 +20 in the front and needed 3mm spacers to clear my Tein coils. I also know for a fact that 9.5 +12 don't need any either. A buddy of mine runs 9" +20 and it's fine, though he has to roll the fenders a little to clear.
I'd go close to +20 on the 9" wide just to be safe if you don't want to run any spacers.
Old 06-10-2017, 01:10 PM   #3882
marcyeo
Okay, sounds good. And this applies both for 17 and 18 inch sizes?
What you're saying is, I could run around 18x9 +20 and be generally fine with clearance and such, but can also run something like a 18x9.5 +12?
I may want to run the thicker wheels because of the concave shapes that some of them have.
Old 06-10-2017, 01:16 PM   #3883
1gr8bar10der
Trader Rating: (77)
Yes and yes, though the 9.5" +12 will need the fenders to be rolled flat, the 9" +20 should be okay or slightly rolled.
Old 06-10-2017, 01:17 PM   #3884
marcyeo
Okay, I'll try it out. I really, really, really want to avoid making any fender modifications.
Old 06-10-2017, 01:22 PM   #3885
d9m13n
d9m13n's Avatar
d9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really niced9m13n is just really nice
my .02, I run 9.5 +12 and they poke like a mf in the rear, its a pretty aggressive fitment with no camber. I do run 235s however, so its pretty squared off. Unless rota grids fit weird id stay away from that size if you dont want to touch the fenders at all or dont want to run a couple degrees of camber
That wing looks as effective as the electoral college.
d9m13n is offline   Reply With Quote
Old 06-10-2017, 01:24 PM   #3886
marcyeo
Okay. Hopefully I find a nice wheel with a nice shape soon. Any suggestions? I have a 526 Hot Red S13 Hatch, looking to run white wheels maybe.
I don't mind running a bit of camber.
I'm mostly looking at 225/40/18 or 225/40/17.
Old 06-10-2017, 01:28 PM   #3887
d9m13n
d9m13n's Avatar
You could definitely get away with a less aggressive offset, I've got a bit of room between the wheel and coil
Old 06-10-2017, 01:29 PM   #3888
marcyeo
Around what offset would you think?
I also am not sure which tire size to run if you could give some input
225/40/18
225/40/17
225/35/18
225/35/17
Old 06-10-2017, 01:32 PM   #3889
d9m13n
d9m13n's Avatar
225/40/18
225/40/17
225/35/18
225/35/17
+20 maybe? Don't put too much stock in that though lol. I'm running 17s with a 40 sidewall (235) so you'd be good with a 225 40, 35 would tuck even better
Old 06-10-2017, 02:14 PM   #3890
derass
224/40R17 doesn't exist. There is 225/45R17, which is super common, and 225/35R/17, which is quite uncommon.
To help with your question, I ran 17x9 +20 and 235/40R17 all around on a stock body S13 without any fender modifications. This was with about -3* camber all around. Also had about 5-10mm clearance to both my Stance and HKS coilovers.
So any other wheel and tire combo inside of these specs will suit what you are trying to do. I don't think I could have gone larger in any dimension.
Old 06-10-2017, 02:56 PM   #3891
marcyeo
Then I may go with 225/40/R18 or 225/45/R17. I'm not sure which I prefer, and they should generally fit the same, right?
I'm quite new, is -3 degrees of camber a lot?
Old 06-10-2017, 04:20 PM   #3892
derass
Yes, they are nearly identical in outer diameter, only a 0.1" difference.
Tools like these are quite useful when comparing tire sizes: https://tiresize.com/comparison/
As for camber, it depends on what you mean by "a lot".
Compared to a completely stock car that has -0.5* to -1.0*, then yes.
Compared to a car that has an alignment catered towards track driving, then no, it's about average.
Compared to a hellaflush car which can anywhere between -3* to -10* and up, then no, it's quite tame.
To put it in perspective, the wheel doesn't "look" like it has excessive camber at -3*, however, you will be able to see it in the contact patch and tire wear.
If it's your daily driver and you're racking up thousands of miles per year, you may want to consider a less aggressive wheel size for better tire wear / life.
Old 06-11-2017, 11:06 AM   #3893
marcyeo
Yes. It is going to be my daily driver. About a minimum of 10 miles a day (just for school). I'm not sure what other kind of set up to go for.
Old 06-15-2017, 03:01 PM   #3894
marcyeo
I think I've decided on some wheels and tires I'd go for. Let me know how you guys think this will fare in my S13 hatch.
MB Battle 18x9.5 +15 on 225/40/R18 tires.
- Is the stretch a lot/too much for a daily driver?
- Will this clear stock struts and/or coilovers?
- Will this clear stock fenders?
Thanks
Old 06-15-2017, 10:40 PM   #3895
1gr8bar10der
Trader Rating: (77)
Thanks
I run 225/35 on 1895 +12 on the front of my daily, you will be just fine.
Yes, it will clear both.
Yes, but they need to be rolled flat and you have to run some camber.
Old 06-15-2017, 10:45 PM   #3896
marcyeo
I don't mind running some camber, but I really want to avoid rolling my fenders at all costs. Any way I could avoid this besides using a different setup?
Old 06-15-2017, 10:49 PM   #3897
derass
stock suspension and mexipoke / brodozer stance?
Old 06-15-2017, 10:50 PM   #3898
marcyeo
I'm on the stock suspension right now, but I plan to get BC Racing Type BR Coilovers.
Old 06-15-2017, 10:59 PM   #3899
1gr8bar10der
Trader Rating: (77)
Unfortunately not, unless you want your car to look donky. Try opting for a higher offset (9" wide wheels between +20-30mm) if you don't want to modify your fenders.
Old 06-22-2017, 04:14 PM   #3900
90S13dude
90S13dude's Avatar
90S13dude is an unknown quantity at this point
Send a message via AIM to 90S13dude Send a message via Yahoo to 90S13dude
19x9/10.5 +42 on my kouki?
90S13dude is offline   Reply With Quote
