12-21-2016, 11:59 AM | #1 |
S13 hatchback 1jz
Engine:
stock 1jzgte engine harness done by Efrain from suspicious garage Driftmotion light weight pulley kit brand new water pump assembly aluminum 2 row radiator welded with 90 degree for radiator hose mercedes radiator fans and relays wired into switch xcessive engine bracket mounts RSR downpipe FMIC with HKS bov 1 piece steel drive shaft brand new w55 transmission out of lexus is300 stock w55 flywheel re surfaced brand new act clutch HD stage 4 Buddy club spec II full exhaust welded diff prosport gauge for water temp. valve cover gaskets and seals just changed battery relocated to trunk Suspension: PBM coilovers barely used 12k and 10k spring rates Gsp front tension rods Gsp rear recast Gsp toe arms wheels: Enkei PF01 18x9.5 +15 all around interior - 9/10 (only thing is cracks on the dash) exterior - 7/10 Text only 7one4220843three 6,000 obo |
02-01-2017, 10:56 AM | #16 |
yea there on the craigslist add. if anyone needs more pics text me and I can send them.
https://losangeles.craigslist.org/lg...916919452.html |
