Origin Labo s14.5 | 400hp 1jz | VS-KF | DRIIIFFFFFT
Here ye, here ye.
The time has cometh that I shall have to say farewell to my noble steed. It has served me valiantly but, as I move onto pastures new, I find myself searching for a person of fine standing who can take the reigns of this grand stallion. Make no mistake, whomever shall choose to take this beast will be bestowed with the ability to rip many the sick chuck and gain the attention of many the fair maiden. Now, without further ado the listing of spec.... Engine 1jz non vvti, tuned on e85 around 400whp (was 459 but I turned the boost down) Engine custom mounted as far back as possible GT35 with top mount manifold Custom 3” downpipe/dual exhaust Forge Motorsport 44mm external wastegate FIC 950cc injectors Bosch 044 fuel pump Summit 7gal fuel cell Dual summit fuel filters Tomei fuel pressure regulator AEM v2 2jz ECU Chase Bays wiring harness Koyorad hypercore KA radiator Flex-a-lite dual fans Koyorad oil cooler Fluidampr crank pulley Driftmotion pulleys (power steering, alternator, water pump) Parts Shop Max HMIC Drivetrain CD009 6-speed transmission Maverick Motorsports trans adapter plate/flywheel ACT six puck clutch D-Rex Concepts trans mount and shifter relocation 1-piece driveshaft Welded diff w/ Weir Performance output shafts Q45/z32 TT axles Q45 rear hubs Suspension Stance XR1, 12/6k with helper springs F/R and custom valving Hotside knuckle, crossmember, and FLCA Maxima inner/ s14 outer tie rods Nismo Power Brace Maverick Motorsports tension rods Modded subframe, raised 40mm and link angles corrected Frame notched to allow suspension travel Adjustable links (RUCA, toe, traction) Parts Shop MAX rear knuckle Z32 front brakes w/ slotted rotors SPL braided z32 brake lines Project Mu pads F/R Modded handbrake seahorse/brackets Sikky front swaybar/ Whiteline rear Work VS-KF 18x9.5j -3 / 18x11j -7 built by VR Wheels Parts Shop MAX wheel spacers (pair) Heat Maker lug nuts w/ extras Exterior S15 headlights Ganador mirrors Origin Lab aero parts.. S15 silver carbon hood w/ aerocatch latches S14.5 Racing Line full kit w/ spare side skirts and rear bumper (new) Custom s15 type 3 conversion fenders S14 type 3 rear overfenders w/ spare set (new) Side under panels, rear under panel type 1 Carbon roof spoiler Carbon 3D GT wing 1750mm width / 355mm height Interior Nardi Deep corn 350mm Circuit Sports quick release hub OMP WRC drivers seat Racetech passenger seat Racequip harnesses AEM gauges (water temp, boost, AFR, EGT) Apexi tach Price: $25k Serious buyers please contact me for more info/ detailed pics. [email protected] Thanks! ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#4 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
Tis a sad day. Good luck on future adventures homie.
![]() Join Date: Jun 2003
Trader Rating: (130)
you forgot to mention custom floor mount seat for gentlemen of a certain stature.
#24 |
Thanks for the kind words, guys.
Thought I'd give it a chance for someone to enjoy it all together but kinda figured it would have to be parted out. Shoot me an email for pricing on parts -> [email protected] <3 |
