#1021 | |||
![]() Join Date: Dec 2004
Trader Rating: (58)
IIRC the KA head actually outflows the SR-DE heads almost everywehre that I've looked. Quote:
I wonder if the .86 housing will help that 2.4 out?
#1022 | ||
Cody, looking up the numbers (after I posted the response above) you are correct! I just never updated my original post, but I will update and post flow numbers here!
Here is what I saved KA24DE Head flow numbers Quote:
#1023 |
I did my own digging ironically enough yesterday during my physics class haha, came up with the same info. Working on porting my KA head recently
MRP Manufacturing |
#1024 |
![]() Join Date: Apr 2012
Trader Rating: (63)
![]() Feedback Score: 63 reviews
By looking at those number looks like the .86 would be a better match for the KA I'll see if I can get my hands on a .86 turbine housing as well & give both a try.
#1025 |
If I remember correctly, the .84 T25 flows similar to the .63 T3??
If that's the case, yeah, a T25 would be an option....although I would personally opt for the 0.63 T3 housing option. |
#1026 |
My KA has seen mostly .63 a/r t3's or close and that seems to be favorable.
MRP Manufacturing |
#1027 |
I know its 2 extra cyl but i had a 3076r .63AR on my bone stock rb25det and it responded very well, made about 14 psi at around 3100 and 22 psi at 3700-4000rpm. until i got my nt05's 2nd and 3rd gear would roast my 595 ss
#1029 |
.64, he doesn't have the extra displacement for the .8x.
#1030 |
![]() Join Date: Sep 2010
Has anyone used T25 Plus housing from atp turbo for there Gt2871R or Gtx?
Its a T25 flange but flows like a T3. Is it worth the upgrade for $300 bucks when your shooting for 380whp give or take
IG-jonathanprem |
#1031 |
![]() Join Date: Sep 2005
That quote is a marketing ploy,
Flows like a t3 part. And the standard gt2871r should make 380hp easy most people have problems making 400 though. The answer to the 1st question is yes. Sent from my SM-N910T3 using Tapatalk
#1032 |
Can anyone measure how much room is left behind the sr20 head? My waste gate is behind the manifold. Im trying to figure out if it will work. Im also using the top port for the electronic boost controller.
#1034 |
Use a 90° etc. or banjo fitting to make the return back towards the bay a lil easier on the hoses, maybe?
#1035 |
![]() Join Date: Jul 2012
you could probably use a tape measure and measure the distance from the bolt hole for the engine mount on the crossmember, to the firewall. And then measure from the stud on the actual engine mount, the one currently on your engine, and see where youre at
#1038 | ||
Can I? Lol. I dont know shit about waste gates. Tial instruction just said the top is only electronic. If I can use the top side port then that will help me even more. |
#1039 |
Another GTX2867 .64 reporting in.
403whp 365ft/lbs @19psi and 7700 rpm rev limit. (pump gas 93 octane) S14Sr20det JWT S4HL cams Tial 38mm wastegate on stock manifold 740 hks injectors ARP Head Studs Cometic Headgasket 350z transmisson Car feels fantastic and pulls all the way to redline. Cams are really a must with this turbo. I was at 21psi prior to the cams and was making 375whp so this was a very significant upgrade. -Lou |
#1040 | |
Trader Rating: (63)
jwt s4hl ftw |
#1041 | |
Trader Rating: (58)
Love seeing results like this
![]() Quote:
#1042 | |
Trader Rating: (63)
What ecu ? |
#1043 |
AEM EMS V1 with 3.5 bar map. The only downfall of the V1 is that it cant quite control my VTC so that might be a reason to upgrade at some point as id like to have it and got my cams made specifically to keep it.
#1044 | |
#1050 |
Is there a graph some where that I missed or something. That torque looks like it was sacrificed to gain hp. I want to see the birth certificate....in mean graph!
All hail the mighty s4hl... Sent from my SM-N910T using Tapatalk
gt2871, gtx, gtx2867r |
