Old 12-07-2014, 11:29 AM   #781
zeitgeist
zeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of light
After a good long month, finally picked them up for fedex. Im stoked
zeitgeist is offline   Reply With Quote
Old 12-23-2014, 10:06 PM   #782
Nick@Fortune-Auto
Nick@Fortune-Auto's Avatar
Nick@Fortune-Auto is an unknown quantity at this point
Originally Posted by e1_griego View Post
If you already have the radial bearing, you don't need to add torringtons.
Correct, the radial bearings work way better:
http://www.fortune-auto.com/apps/web...s/show/3772489
Originally Posted by killer240 View Post
What's the ID and OD of your nylon rings terry?
They are 60mm ID
WEBSITE / BLOG / PRODUCTS
BESPOKE SUSPENSION SOLUTIONS
Nick@Fortune-Auto is offline   Reply With Quote
Old 12-23-2014, 10:41 PM   #783
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Originally Posted by Terry@Fortune-Auto View Post
We can make you lay frame if that is what you want
What height and stiffness swift spring would I need to achieve this on gen 1 500 series s13 coils?
corkscrew is offline   Reply With Quote
Old 12-28-2014, 04:38 PM   #784
Nick@Fortune-Auto
You will not be able to go that low, but running a 6 inch spring and flipping the lower mount on Gen 1's will get you pretty low!
Old 12-28-2014, 06:54 PM   #785
corkscrew
corkscrew's Avatar
What will happen if I run a 5 inch spring?
Old 12-29-2014, 11:08 AM   #786
TheRealSy90
TheRealSy90's Avatar
You'll be sitting on the front subframe with the tires off of the ground...
I was able to set my sway bar on the street with Gen 1's with their taller 12k springs and flipping the front mounts... You don't need 5" springs.
Terry, is there any way I could get my hands on some S13 super down lows?
Such a good signature.
Old 12-30-2014, 03:41 PM   #787
slideslidegnarslide
Trader Rating: (29)
slideslidegnarslide is an unknown quantity at this point
Feedback Score: 29 reviews
^^ the new series is now the super down low. at least that is what i was told when ordering from him.
slideslidegnarslide is offline   Reply With Quote
Old 12-30-2014, 04:29 PM   #788
TheRealSy90
So the current s13 generation is the same as the last gen super down lows?
Old 12-31-2014, 08:54 AM   #789
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
No it's not.
REVIEW
killer240 is offline   Reply With Quote
Old 12-31-2014, 01:27 PM   #790
TheRealSy90
I didn't think so either...
Old 12-31-2014, 01:41 PM   #791
killer240
killer240's Avatar
Trader Rating: (24)
They said the super down low was just too much.. the new ones could go pretty low though
REVIEW
Old 12-31-2014, 04:08 PM   #792
yomisiu
yomisiu's Avatar
yomisiu is making a name for him/her selfyomisiu is making a name for him/her selfyomisiu is making a name for him/her self
2015 super down low group buy?
yomisiu is offline   Reply With Quote
Old 01-01-2015, 09:23 PM   #793
Nick@Fortune-Auto
Super Lows will do this:
The Gen 5 regular spec can get you ridiculously low. We can do a SDL spec, since everything we make is custom built to order. But the SDL spec is really not necessary unless you want to lay frame and drive around like that lol. But we can make it if you want it!
Old 01-01-2015, 09:25 PM   #794
Nick@Fortune-Auto
yes!
It wont work because the shaft is to long. The shortest spring you can run is a 6 inch.
Old 01-02-2015, 12:47 AM   #795
xfgjjgyj
xfgjjgyj is an unknown quantity at this point
Good to know, thanks.
xfgjjgyj is offline   Reply With Quote
Old 01-02-2015, 08:22 AM   #796
zeitgeist
Got mine mounted and everything and am enjoying them on my s14
However there was some confusion as i received s13 coils. It would have been fine but the z32 mounts were half the length they should be. Worked it out with chris to get lower mounts off from another car mailed which were the required length and a few mm wider. I still need to find a longer mounting bolt as the original is too short. But I would much rather send these back and get some lower z32 mounts that are extended
But just to clarify with him or anyone else, the s13 and s14 mounting points are the same, the s14 coils just normally have longer strut housings. But with the lower mount extended you can still use them like you guys have done. Just providing this so it doesnt happen to anyone else
Following pics show maximum height with first pair of z32 mounts. And the size compared to original rear mounts
Old 02-02-2015, 01:20 PM   #797
Nick@Fortune-Auto
Glad you enjoying them. I noticed that on the Z32 mount. I think we are going to officially not offer the Z32 mount on the S14 application. If you are not happy with your purchase overall please let me know and I can take care of you. You can email me at [email protected]
Old 03-23-2015, 09:18 AM   #798
SHIFTrl240
SHIFTrl240's Avatar
SHIFTrl240 is an unknown quantity at this point
So this weekend I installed radial bearings on my fairly old (don't know which gen) FA500's. Did I do something wrong? Left is without the new bearing, right is with the new bearing installed. Note the amount of thread left on top.
SHIFTrl240 is offline   Reply With Quote
Old 03-25-2015, 06:23 AM   #799
ditchs14
ditchs14's Avatar
ditchs14 is a well-known jackass
Just wondering if you guys still sell the super lows? i know only 25 sets where originally made. can i get a set built?
ditchs14 is offline   Reply With Quote
Old 05-12-2015, 11:15 PM   #800
adamhanna
adamhanna is an unknown quantity at this point
i bought some gen 4's brand new with 7/6 rates. ride was awesome but after some drifting they turned out to be a little too soft for me so i went to 10/9 springs with no revalving. the 10/9 setup was awesome, perfect for the track and not too harsh to daily. these were more comfortable than any other coils ive ridden on(isc,tein super drift,megan,bc racing, isis, ebay). and they go as low as you ever need to.
that picture is collars removed but i could get lower in the front by adding preload or using a shorter spring, and lower in the back by using a shorter spring.
they also go pretty high if thats what youre into
first set was s good i just ordered another but with 11/9 springs this time
adamhanna is offline   Reply With Quote
Old 06-05-2015, 12:53 PM   #801
c-los13
c-los13's Avatar
c-los13 is an unknown quantity at this point
^^^^^^^^^^^^^ dammmmmnnnnn
since I found this thread
Terry, Will I be able to get this kinda fitment ( pic above ) with the 5 GENs?
( http://www.importimageracing.com/for...san-240sx.html )
Thank you so much
c-los13 is offline   Reply With Quote
Old 07-01-2016, 12:24 AM   #802
white95zenki
white95zenki is an unknown quantity at this point
What spring rate would you guys recommend for s14?Its my daily.
white95zenki is offline   Reply With Quote
Old 07-01-2016, 12:28 AM   #803
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
Get the swift springs.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
fortune auto, s14
