Old 10-28-2015, 04:56 PM   #361
TheRealSy90
TheRealSy90's Avatar
Bumping for e85.
I'm going to be staying rubber fuel hose on my setup, doing a flex fuel tune with a GM ethanol sensor wired to my AEM EMS 2.
Walbro 255 in pump, Integrated Engineering Bosch 044 surge tank.
Is the 2005 GMC Savanna fuel filter the best option for 3/8" clamp/line as mentioned in a previous post? Something about needing a filter with stainless media, not a paper one like a z32 filter.
Also, anybody found a good place to buy a drum for storing e85? Closest pump for me is almost 2 hours away, so i'll be having to take a drum and cans there and back to fill it whenever I run out.
Slightly off topic; can a surge tank be mounted either below or above the fuel tank? I haven't found a good place to mount it under the car, leaving me having to mount it in the trunk area. Only qualm with that is the possibility of needing a rear firewall installed...
Such a good signature.
Old 10-29-2015, 12:47 PM   #362
Mannykiller
Mannykiller's Avatar
Mannykiller is an unknown quantity at this point
^ I've actually been using an Aeromotive 40 Micron for the past year and a half with zero problems. ALso push fit/push-lock hose with a few small sections of good old regular autozone rubber hose with no problems so far. I honestly believe that in dryer climates such as yours and mine, you won't be needing the crazy filtration that some on the east coast or up north may need.. but either way I'm still swapping to a 10 Micron Filter for this season. I've also stored E85 for up to 4-6 weeks without any problems over this season. All in 5 Gallon fuel jugs.
IG:@AAPARKAH #ThisIsTheWolf
Mannykiller is offline   Reply With Quote
Old 10-29-2015, 02:56 PM   #363
TheRealSy90
Yeah I'm glad about the area I live in, don't have all those moisture worries like the Midwest and north guys have.
Old 04-22-2016, 01:32 AM   #364
taeisbeast
taeisbeast's Avatar
taeisbeast is an unknown quantity at this point
Just wanted to get some feedback as I'm still in the process of learning.
Current set up:
9:0:1 CR
1000cc ID(-6 return / feed)
3076r
Aeromotive intank 340lph
Want to run E85 - only want to push around 500whp+ is that possible?
Thanks
taeisbeast is offline   Reply With Quote
Old 04-22-2016, 01:49 AM   #365
Tom N
Tom N is an unknown quantity at this point
Current set up:
9:0:1 CR
3076r
Thanks
You Will probably need to turn your base fuel pressure up
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98
Tom N is offline   Reply With Quote
Old 05-05-2016, 10:34 PM   #366
claaasssiiiccc21
claaasssiiiccc21's Avatar
claaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura aboutclaaasssiiiccc21 has a spectacular aura about
In the process of swapping my 14 to e85. I have historically run a 255 in tank to a bosch 044 in-line. I am going to a Walbro 450 in tank to parallel 044s. What is the deal with wiring up a walbro 450 in tank, how have you guys gone about it? I see that the 450 has a nice sealed connector... but is this necessary or can I just snip the wires and crimp like I have done with the 255s???
Wondering since walbro went to such effort to seal up their electrical connections, is special alcohol resistant wire needed or have you guys got away with solder and heat shrink?
Thanks
claaasssiiiccc21 is offline   Reply With Quote
Old 05-06-2016, 09:14 AM   #367
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
Current set up:
9:0:1 CR
3076r
Thanks
You will need to up the fuel pressure to 4 bar.
Or you could just get ID 1600CC and be at 500whp.
You are limited with 1000cc, those should max out a little over 400whp, unless you up the fuel pressure.
I just recommend ID 1600cc for the 500whp range.
Dboyizmlg is offline   Reply With Quote
Old 05-06-2016, 09:24 AM   #368
Tom N
I think he means ID 1700's but you can also do ID 1300's
According to Martin of Enthalpy he can push a little over 500 on E85 and ID1000's but you will need to run higher fuel pressure and have the pump and lines to support it.
Old 05-06-2016, 11:15 AM   #369
Kylepaschke
Kylepaschke is an unknown quantity at this point
1000cc injectors on E85 should be good for around 450.
edit- I am sure people can push it further than that, but I mean- 450 wheel on a SR is pretty nasty
Kylepaschke is offline   Reply With Quote
Old 05-06-2016, 11:50 AM   #370
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Yes, 1,700cc thanks
But I think Injector DYnamics is developing a 1,600cc version.
Old 05-06-2016, 11:55 AM   #371
Tom N
What would be the point?
Old 05-06-2016, 12:03 PM   #372
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
What do you mean?
Old 05-06-2016, 12:07 PM   #373
KAT-PWR
KAT-PWR's Avatar
KAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really nice
Siemens deka have 2400cc flex fuel injectors that are a good price. $170 each.
MRP Manufacturing
KAT-PWR is offline   Reply With Quote
Old 05-06-2016, 12:28 PM   #374
Tom N
What do you mean?
Why would they make a 1600cc injectors when they already have a 1700?
They don't even make them , Bosch does.
Old 05-06-2016, 02:57 PM   #375
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
http://ipgparts.com/blog/injector-dy...00-are-coming/
I seen this a while back.
Not sure if they are considered 1,700cc though.
Old 05-06-2016, 03:20 PM   #376
Tom N
That's from 5 years ago. The ID 1700's are the same injector FIC has been selling for a few years now as FIC 1650's.
Old 07-04-2016, 07:29 PM   #377
derass
We were talking about the SR20. Is this even possible? That's like 100 hp over how much airflow that turbo can provide. I know E85 provides gains from the advanced timing but this seems a bit much.
Old 07-05-2016, 11:46 AM   #378
ultimateirving
ultimateirving's Avatar
I call bs, with my gt2871r and stock long block I made over 340 at 18psi or so.
My little t28 I think put down 298 a year before that.
Z32 with lq4 swap
Old 07-10-2016, 05:56 PM   #379
hille70
hille70 is an unknown quantity at this point
Sorry to change the subject guys but I'm looking for someone to point me in the right direction on some things if possible. I Have a 1990 240sx. Just got my LSX built and I will be running on E85. It's NA and is around 620 H.P. at the crank so we are thinking around 500 at the wheels. I was wondering what size fuel pump would be the best for me. I was looking at the Aem 340LPH but would hate to find out it's not enough. And also a good company to get my fuel lines and filter from. Any help would be appreciated. Thank you!!
hille70 is offline   Reply With Quote
Old 07-14-2016, 08:42 AM   #380
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Lets keep this thread going!
I am in search for a fuel filter at the moment, I think a 40 micron ss mesh filter would be good, any one running one in replacement for the stock fuel filter?
Also, how important is running a filter before the fuel pump??? Any one running one of these on their set up?
Old 07-14-2016, 11:58 AM   #381
Def
The AEM pump will likely do it as your pressure will be pretty low given its not a boosted setup.
That said, I'd still go with a Walbro 450 E85 pump. It's almost the same price, but a much better pump than the old "drop in" fitment size.
DEFSPORT
Old 07-14-2016, 07:14 PM   #382
sil14zenki
sil14zenki's Avatar
Trader Rating: (25)
sil14zenki is an unknown quantity at this point
Feedback Score: 25 reviews
that is what i've been using. i believe its an earls from summit.
need to ditch that stock filter as the e85 can dissolve the glue and what not that used with paper filters.
@andymcfly
sil14zenki is offline   Reply With Quote
Old 09-26-2019, 12:08 AM   #383
sharad909
sharad909's Avatar
sharad909 is an unknown quantity at this point
Hey guys, starting to go full E85 soon. Im currently on:
stock block
TD05 @ 17
900 sidefeed sard
stock fpr but have tomei type s to swap.
Jim wolf tuned
Seen some people on 555cc getting 360whp.
Im looking for the same numbers! Will I be maxed out?
sharad909 is offline   Reply With Quote
Old 09-27-2019, 10:25 AM   #384
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
stock block
TD05 @ 17
900 sidefeed sard
Jim wolf tuned
No you'll be fine. That's more than enough injector for 360hp.
Need aftermarket parts? PM or DM me competitive pricing! IG@S13Guille
e30gangsta is offline   Reply With Quote
Old 08-13-2020, 11:34 PM   #385
TwistedRage10
TwistedRage10 is an unknown quantity at this point
Hey Guys,
So I went though a lot of the post here regarding the E85. I yet have still two thing unconfirmed only because there’s people saying it works and some say it doesn’t. So I have a 2002 Silvia S15, but I’m not sure if I should use the stock rubber fuel line for E85. Like will it work, or just eat through it in a matter of weeks? The other question was for the Walbro E85 fuel pump, do you just splice the wires together or is there a specific connector or adaptor available? Below are the details of my setup:
750cc Injectors
Top mount Garret GT3071 .72 AR
Front mount intercooler 3 inch core
3inch intercooler piping all around
Pushing roughly 380whp
Haltech ECU
*the goal is to get to like close to 500whp on stock internal via E85*
And let’s say that I put the walbro E85 fuel pump in, I put a flex fuel sensor and tune it via haltech. Would that be all I need to run E85? Am I missing anything crucial? Like what about the stock fuel filter?
TwistedRage10 is offline   Reply With Quote
Old 08-14-2020, 04:24 AM   #386
S14rebuild
No, the stock rubber lines on the s15 are not e85 safe.
The walbro e85, installs like any other fuel pump. Splice in the wires.
Run a fuel filter that is e85 approved.
Ull need larger injectors aswell
Old 08-14-2020, 02:22 PM   #387
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Originally Posted by TwistedRage10 View Post
Hey Guys,
So I went though a lot of the post here regarding the E85. I yet have still two thing unconfirmed only because there?s people saying it works and some say it doesn?t. So I have a 2002 Silvia S15, but I?m not sure if I should use the stock rubber fuel line for E85. Like will it work, or just eat through it in a matter of weeks? The other question was for the Walbro E85 fuel pump, do you just splice the wires together or is there a specific connector or adaptor available? Below are the details of my setup:
750cc Injectors
Haltech ECU
And let?s say that I put the walbro E85 fuel pump in, I put a flex fuel sensor and tune it via haltech. Would that be all I need to run E85? Am I missing anything crucial? Like what about the stock fuel filter?
You will need a minimum of injector dynamics 1,300cc top feeds for 500whp range on a 4 cylinder engine.
Rubber fuel hoses are ok. Replace with new rubber hose rated at 225psi fuel pressure. I have been using mine for over 5 years now.
Old 08-14-2020, 02:34 PM   #388
S14rebuild
No!......
https://www.kaizenmotorsports.com/bl...ect-fuel-hoses
Id recommend ptfe line AN hoses. Never have to worry..EVER
Old 08-14-2020, 03:44 PM   #389
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Originally Posted by S14rebuild View Post
No!......
Of course PTFE is the BEST way to go.
However I have been using these rubber hoses my self for over 5 years with NO issues what so ever! Fuel tank to hard line hoses are rubber and will continue to be! As long as hoses are changed out every 5-7 years there?s no issues
Old 08-14-2020, 04:47 PM   #390
S14rebuild
I guess u could go that route. But all the rubber hoses ive seen with e85, they split, and deteriorate from the inside clogginging up fuel filters and pumps
