Old 10-21-2015, 08:48 AM   #1
PotholeEnthusiast
PotholeEnthusiast's Avatar
PotholeEnthusiast is an unknown quantity at this point
Radio Harness Wiring 97 240SX
So I recently purchased some Tanabe USA gauges, and I was going to test them out by twisting them up with the radio harness but I cannot seem to find a diagram. I have an SE 1997 240SX if that helps, the only wires I would need would be dimmer, ignition accessory, and constant power.
Instagram - @wheresjohndoe
PotholeEnthusiast is offline   Reply With Quote
Old 10-21-2015, 09:02 AM   #2
Gingersmurf
Gingersmurf is an unknown quantity at this point
On the s13 the wires are labeled. If you disconnect the radio harness from the car, they are written on the side of the wire. Not sure if its the same with s14 though
KAs are like Frank's RedHot, Nissan put that shit in everything
Gingersmurf is offline   Reply With Quote
Old 10-21-2015, 09:02 AM   #3
PotholeEnthusiast
Well I'm guessing the previous owner sliced it down pretty far because there are no labels at all.
Old 10-21-2015, 09:32 AM   #4
Gingersmurf
Found this in a quick google search
Old 10-21-2015, 09:47 AM   #5
PotholeEnthusiast
Thank you sir, I saw that diagram earlier but I assumed 95-96 and 97-98 were different.
Old 10-21-2015, 09:58 AM   #6
Gingersmurf
I have an s13, so i can't say for certain, but its worth a shot to try. You can also check online and find the factory service manual for your car and find it there
Old 10-21-2015, 11:18 AM   #7
tschmidt55
tschmidt55 is an unknown quantity at this point
http://www.nicoclub.com/FSM/240sx/1997/el.pdf (EL 115)
tschmidt55 is offline   Reply With Quote
Old 10-21-2015, 01:40 PM   #8
PotholeEnthusiast
So I tried the blue wire and I don't think its an ignition acc. Could be wrong but controller and gauges are not illuminating....
240, s14
