best s13 chassis/car in general is best for 2jz swap
about to buy a 2jz to rebuild and i want to put it in a s13 hatch. i dont know what year is the best if any for the swap. Or if there are any years i should stay away from all together.
i know realize the title sounds retarded. wish i could change it ![]() |
![]() Join Date: Aug 2011
the mk1 & mk2 have the same everything, except bumper, hood, and some brackets front.
most mk1 have smaller brake rotors, & a lot of the mk2 owners complain about the oem bumper radiator opening being too small. In any case, you can swap parts from 1 model to the other so it wont matter (you ARE going to bin the brakes anyway, and i guess it will have a bodykit too) |
#4 | |
Sent from my VS980 4G using Tapatalk |
![]() Join Date: Feb 2012
Trader Rating: (37)
![]() Feedback Score: 37 reviews
All USDM s13's from the front seats to the headlights is the same. Other than the convertibles, which are a convertible.
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
#7 | |
#8 | |
![]() Join Date: Aug 2006
Trader Rating: (29)
![]() Feedback Score: 29 reviews
Are you asking if there is a preferred chassis for a 2JZ swap to come from, which might make for an easier swap into a S13?
Or which S13 chassis (vert/hatch/coupe) will receive the swap better? Kinda hard to tell. I'm for your sake assuming you already know what everyone mentioned above, because I can see how the question can be difficult to word. From above for example all S13's have the same exact engine bay and crappy front brakes, everything firewall forward is the same except for the convertibles which have a lot of extra sheet metal bracing outside of the engine bay (which means nothing is different for your swap) All S13's are OBDI and the JZ series engines have the turbo on the passenger side, both are good things for a swap in a LHD US-spec 240SX. |
#10 | |
![]() Join Date: Oct 2014
As stated above, s13 is all the same in the engine bay. Now days with all the swap kits and wiring companies having already figured out really nice harnesses without doing a one off custom, this swap is getting easier and easier. Basically a bolt in affair. There is a lot of great info on the swap itself all over zilvia if you do a search, should make your swap extremely painless. Unless you have my bad luck of course and everything goes wrong.
+1 at this point the hardest part of the swap might be the intercooler piping
When I did one, that was really the hardest part, other than getting the engine harness right, which at the time was like trying to wire one person's brain into another person's body, but im sure wiring specialties has a swap harness for this thatd be SO worth the money spent |
#13 | |
#14 |
There are a bunch of companies now that make plug and play harnesses, all you need is a speedo and tach adapter from dakota digital or something equivalent and done. Just ship them the jz harness once you get the engine and usually by the time you have the motor in the car and ready to start, the harness will be complete and sent back to you.
#15 | |
#16 |
What the forum is for right? But make sure whichever company you end up going with, talk to them before get the engine, and make sure to tell them exactly what you want and if you are going with a specific trans. I went with the z33 trans (which doesn't have a speed sensor) so just be aware and give them as much info as you can think of and then more haha. It's easier to give them more info than they need and for them to just disregard it. Rather than you not giving enough and them making a base harness that will work but might need slight modification. I learned all this a minute too late because I built a custom chassis harness myself and didn't know which trans I was going to use when I had the harness made, learn from my mistakes. Also, if you plan on running a wideband and no other o2 sensors, you can use most as the "narrowband" that the ecu sees. Just a little extra fyi
#17 | |
#18 | |
