Old 09-20-2014, 03:17 PM   #31
WOOTEN
WOOTEN is an unknown quantity at this point
Oh my bad, these are amazing! Great products, great service! I will get picks when I get time
Sent via flying Monkees....
WOOTEN is offline   Reply With Quote
Old 09-23-2014, 07:02 PM   #32
G-E@Z31P
G-E@Z31P is an unknown quantity at this point
Glad you like em
I've just shipped out a small bundle of these, should be arriving end of the week for those that ordered!
I also had a bunch of thin stainless spacers made (think of them like small-OD washers), they are included with the kit, punched from 1.8mm stainless, some coilover bottoms are a lot narrower than they should be...
http://responsetype.com/shop/silvia-...strut-adapter/
Reducing washers to use S14 front coilovers on S13 for even more mixing'n'matching fun are in stock too!
http://responsetype.com/shop/silvia-...-12mm-inserts/
G-E@Z31P is offline   Reply With Quote
Old 10-02-2014, 10:19 PM   #33
nextproject
nextproject is an unknown quantity at this point
Got mine in last week. SPL sphericals showed up yesterday and i installed them today. Will be installing the entire setup this weekend or next week. Hard to find an alignment machine that i can fit on or that uses adapters that dont grab the outside of the tire.
nextproject is offline   Reply With Quote
Old 10-03-2014, 05:42 AM   #34
G-E@Z31P
Good stuff... when installing, mockup the bracket on the coilover to get the alignment angle for the slug, ideally once you've set your base camber and approximate toe with the arms.
Old 10-03-2014, 08:11 AM   #35
ANDY black s13
ANDY black s13 is an unknown quantity at this point
Anyone know are the s14/s15 upright bushes the same size OD as z32 300zx uprights?
as I want to do this swap and I have some spherical bushed s15 uprights
and hoping I could press them out and reuse them in some z32 uprights
And I'm liking that solution for the coil-over mounting, nice idea imo
any chance you could post them to the UK?
ANDY black s13 is offline   Reply With Quote
Old 10-03-2014, 08:38 AM   #36
G-E@Z31P
Bushings should be common with s-chassis, turbo uprights being hicas...
Old 10-03-2014, 09:50 AM   #37
ANDY black s13
Cool that's what I was hoping for,I don't have any 300zx uprights yet but
can mic them up to confirm
And we never got the hicas gubbins on UK s bodies
only jap imports had it afaik
replied to your PM as well mate
Old 10-03-2014, 10:53 AM   #38
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
Not bad, I have some laying around in my garage, might consider installing them
andisan is offline   Reply With Quote
Old 10-13-2014, 07:15 PM   #39
AXV
AXV is an unknown quantity at this point
Everything arrived, fairly painless install, used a flapper wheel on a dremel to clean out the hole, after cutting out the bushing, sprayed with wd40, used a long m10 screw with big washers to draw it in against a cross bar with a hole in it...
Then I just leaned on the bracket to line it up, and rammed the bolts through, voila!
omg!!! where were you 6 months ago?! I had to buy Z32 lower coilover mounts for my Z32 uprights. Any still for sale? I think I might pick up one of these.
AXV is offline   Reply With Quote
Old 10-13-2014, 10:40 PM   #40
G-E@Z31P
Well, I was told by several know-it-alls that this product is a waste of time pursuing... makes you wonder how many people have been dissuaded before me eh?
Aren't you glad I didn't listen?
Old 10-13-2014, 11:14 PM   #41
AXV
So are they still available to buy?
Old 10-13-2014, 11:15 PM   #42
G-E@Z31P
Yea I have a new batch of brackets coming (didn't make equal quantities of everything), but still have plenty in stock... fire away!
Old 11-06-2014, 08:29 PM   #43
Blksrt4
Blksrt4 is an unknown quantity at this point
Got mine in last week, I must say I'm impressed with the quality of the kit. Was a breeze to install and didn't take too long. I've yet to drive on them but I figure I'd post pics of them installed.
Blksrt4 is offline   Reply With Quote
Old 11-12-2014, 05:04 AM   #44
revolvedspecv05
revolvedspecv05 is an unknown quantity at this point
Yeah I would love to buy a set
Hit em wit it
revolvedspecv05 is offline   Reply With Quote
Old 11-12-2014, 05:41 AM   #45
WOOTEN
If you get a set of Z32 uprights, make sure you get the spacer that is used to connect the ball joint to the upright...
Old 11-27-2014, 06:45 PM   #46
SilviaSativa
SilviaSativa's Avatar
SilviaSativa is an unknown quantity at this point
Still available? PM sent. I would like to make an order ASAP to try these out versus cut and weld my new coilovers
SilviaSativa is offline   Reply With Quote
Old 12-20-2014, 11:53 PM   #47
G-E@Z31P
When is someone going to go widebody (a q45 subframe perhaps?) with these?
Old 04-06-2015, 02:01 AM   #48
G-E@Z31P
Alright so a bunch of you have these now, show us (me) some pics!
Old 04-29-2015, 02:28 PM   #49
SilviaSativa
Thank you for the PM with install instructions! I haven't installed mines yet but will be sure and keep this thread updated when I do!
Old 04-29-2015, 05:12 PM   #50
zeitgeist
zeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of lightzeitgeist is a glorious beacon of light
Glad i saw these. I was about to remove the z32 uprights from my s14.
Will be purchasing within a week
I recommend you advertise through the site or other companies. I was lucky i just happened to stumble on this thread
zeitgeist is offline   Reply With Quote
Old 04-29-2015, 09:24 PM   #51
G-E@Z31P
Such a pretty thing
Old 04-29-2015, 09:45 PM   #52
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
These look dope!
Might pick these up soon.
Dboyizmlg is offline   Reply With Quote
Old 05-02-2015, 11:57 AM   #53
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
for kicks, I have a pair of Z32 Koni sport dampers to sell. The sport dampers are fine for 6, 7, and 8kg/mm spring rates we often run.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 07-04-2015, 07:14 AM   #54
G-E@Z31P
Another successful conversion
Old 07-17-2015, 12:12 AM   #55
JSimpson
Banned from the Marketplace
JSimpson is an unknown quantity at this point
How are you guys liking these? From the guys who have driven on them, is the bind gone like on an S14 knuckle or is it still present (like using Z32 knuckle on S14)? Thanks!!
JSimpson is offline   Reply With Quote
Old 07-17-2015, 01:32 AM   #56
G-E@Z31P
You see the pic I posted last?
You can clearly see the near side, where the adapter matches the inward tilt of the coilover body.
On the far side you can see the misalignment from the upright mount to the coilover body is not a problem either.
So far I haven't received any complaints, just questions...
Old 07-17-2015, 02:00 AM   #57
JSimpson
Thanks for the info! These look great!
Old 07-17-2015, 02:52 AM   #58
Blksrt4
Jimmy I got these on my s14. Install was cake. I'll let ya know how they ride when I'm road worthy
Old 10-26-2015, 06:48 PM   #59
dreimers
dreimers's Avatar
dreimers is an unknown quantity at this point
I just got my uprights prepped and ready for your inserts. Could you pm me with some of the install instructions. I will post up some pics once mine are installed. Gonna do a step by step, if you think its needed.
This is a site ran by the US government, not some crazy biased organization
dreimers is offline   Reply With Quote
Old 10-26-2015, 08:09 PM   #60
G-E@Z31P
You should have the upright installed and the coilover hanging from the tower with the spring perch loosened all the way...
1. attach the steel bracket to the coilover bottom loosely
2. raise the suspension to approximate ride height
3. push the steel bracket flush against one face of the upright's strut mount, with the tabs perfectly centered over the hole, find the radial orientation of the slug, mark the upright in a way that makes sense to you
4. then find the best offset combo, bracket leaning forward or rearward, the slug's head on the front or rear of the upright, aim for as much clearance between toe link and axle as possible
5. remove the upright, press in the slug at the correct rotation from the correct side... freezing the slug overnight and using wd40 will help (many uprights go out-of-round, may need a quick buzz with a dremel flapper)
6. reinstall the upright, raise to ride height, loosely bolt everything together and inspect clearance through a range of motion
7. torque everything down or re-adjust as needed
