04-09-2015, 06:18 PM | #1 |
Touge kouki build
I finally decided to build my car from the ground up like I've always wanted to. The car was great before but I wanted to change it completely. I mainly run the local roads around here and plan to attend the Chasing the Dragon Hillclimbs if I can get it done in time.
For now I'll post a short version of the car as I bought it about 4 years ago, the last state and it's current state as unfinished. I am hoping to have it finished within the next month. I bought the car about 4 years ago to be my DD as an automatic KA SE with basic upgrades like KW coils, Q45 brakes, HKS exhaust etc. I borrowed the KF's from my VH 45 coupe and bought an OEM lip. From there swapped to stance coils and converterd to manual. Then came across an s13 blacktop SR in a junkyard thanks to a friend. After that I decided to go full JDM aero etc. Follow me on instagram for more photos @touge_tuned
Touge Tuned Last edited by tougetuned; 04-13-2015 at 07:04 PM.. |
04-13-2015, 06:56 PM | #2 |
For now I'll post a couple photos of the car in it's various stages and a mod list before I started this build.
Touge Tuned |
04-14-2015, 07:13 AM | #4 |
Thanks! Wish I never sold them. They were 17x10 +12 245 x4.
Touge Tuned |
04-14-2015, 07:14 AM | #5 |
Here's a short mod list "pre-build"
Engine: S13 sr20det New oem timing chain New oem water pump New oem turbo gasket New oem exhaust manifold gasket New oem Z32 fuel filter New oem O2 sensor New oem CTS New oem coolant sender Mishimoto radiator Altima dual electric fans Thermostat fan controller DIF water neck adapter Battery relocation Cusco motor mounts Nismo transmission mount New oem shifter bushing S15 t28 dual BB turbo CS SS turbo lines New oem S15 oil drain DIF turbo clocking adapters Nismo 555cc injectors Z32 MAFS Walbro 255lph fuel pump Enthalpy ROM tune 18psi with 93 octane K&N air filter Isis turbo elbow Isis 3" downpipe Isis 3" straight pipe exhaust CX Racing FMIC HKS SSQV V1 with recirc adapter CodyAce A/C conversion brackets Chassis/suspension: Stance GR+ Pro Coilovers S14 VLSD SPL outer tie rods Tein 350z inner tie rods SPL rear traction rods PSM Rear Upper Control Arms PSM Rear Toe Rods SPL adjustable subframe bushings ES TC rod bushings ES rack bushings ES sway bar bushings PSM 30mm adjustable spacers front Brakes: 300zx rebuilt front calipers Hawk HPS pads Billet aluminum adapters for 12.75" 350z track rotors Centric rotors SPL SS brake lines 300zx rear calipers/ebrake assembly Hawk HPS pads R33 ebrake cables CS SS brake lines ATE super blue fluid Interior: AEM Truboost controller AEM Uego wideband PSM drift knob Cue ball shift knob Exterior: JDM kouki front bumper Greddy front lip JDM kouki grill JDM kouki rear bumper JDM kouki valances (replica) JDM kouki rear spoiler JDM Zenki Navan side skirts Circuit sports JDM kouki turn signals LED corner lights LED tag lights HID high and low beams Rolled and pulled fenders front and rear Fender harnesses relocated Wheels: Work VS-KF'S 17x9 +22 New Federal 595 235/40/17 18x10 +20 Federal 595 255/35/18
Touge Tuned Last edited by tougetuned; 04-14-2015 at 05:39 PM.. |
04-14-2015, 05:11 PM | #6 |
I finally had to let go of my s13 after ten years together, I couldn't do two unfinished projects anymore. I sold her to a good friend of mine who I knew would take care of her. I also sold my VH45 swap so I could dump every last dime into this project.
I even sold my camera so I apologize in advance for the crappy instagram pictures.
Touge Tuned |
04-14-2015, 05:19 PM | #7 |
Finally onto the good stuff. I refuse to make my car look too lame in the name of performance so fixing my geometry was my main concern. PSM front knuckles, rack eccentric bushings, diff bushings, Driftworks rear knuckles so I can retain factory ebrake, Nismo lsd, new clutch hydraulic system because mine was acting like a fgt, the oem 300zx slave worked wonders for my pedal feel.
Still working out my alignment specs but here are some before pictures.
Touge Tuned |
04-14-2015, 05:24 PM | #8 |
Looking sweet so far!
Have to say, I'd probably rather see the coupe get fancier but I have much faith in you making any s-chassis cooler haha. |
04-14-2015, 05:24 PM | #9 |
Touge Tuned |
04-14-2015, 05:27 PM | #10 |
More parts to make it a better touge car.
Just waiting on new rear ball joints and SPL tension rods, then I'll post some pictures post drop knuckles.
Touge Tuned |
04-14-2015, 05:32 PM | #11 |
Still has to look cool so I bought some JDM headlights finally and some decent looking corners.
Now if my aero would just arrive I would be good to get her ready for paint. I'm still in search of a cool hood and some ganadors!
Touge Tuned |
04-16-2015, 03:25 PM | #13 |
Touge Tuned |
04-20-2015, 08:41 AM | #16 |
Thanks guys! I wanted something different.
Touge Tuned |
04-21-2015, 12:18 PM | #17 |
Got these beefcakes in the mail yesterday. Also finally killed my driveshaft carrier bearing so I'll be replacing that too. ImageUploadedByTapatalk1429640289.947822.jpg
Touge Tuned |
04-21-2015, 08:56 PM | #20 |
Looking like it's going to be another month plus before I get my aero from GTRGarage. Less than pleased about this but not much I can do until then besides more boring upgrades.
Touge Tuned |
04-21-2015, 09:04 PM | #21 |
Temporary fixed my driveshaft center bearing so I took her for a quick run tonight. Here's a crappy Instagram video of what I do every weekend.
https://instagram.com/p/1ws8FwEZMl/ Had to put her away before my axles self destruct. Nismo diff, solid bushings and new axles going in ASAP. ImageUploadedByTapatalk1429671840.333155.jpg
Touge Tuned |
04-29-2015, 10:34 AM | #22 |
Touge kouki build
New tension rods on and fresh alignment. Pulled a little camber out front and rear and shortened my rear traction rods. Sway bars next so I can get it back to being able to throttle steer it.
Video of a full run, noise is from how I mounted the camera. <iframe width="1280" height="720" src="https://www.youtube.com/embed/05x_UGdfiA0?rel=0" frameborder="0" allowfullscreen></iframe> Not sure why the video won't embed.
Touge Tuned |
04-29-2015, 02:16 PM | #24 |
Nothing worth seeing, still waiting on my aero so it's ugly. I might pull it out of the shop wash it and take a few tonight.
Touge Tuned |
05-13-2015, 09:16 AM | #27 |
Thanks Corry! I've been busy but I finally have time to update it. I'll make it short and sweet since there's nothing really exciting yet.
Put my SPL TC rods on. Went to do my extended studs for the rear and ended up ripping my rear end out and doing my solid diff bushings. Still haven't had time to setup the Nismo diff. I killed my vlsd in the mountains this past weekend so I'll be putting it in soon hopefully along with new axles. Video of the noise before it got really bad on the way home. https://flic.kr/p/rSuK6h My a/c belt shredded itself so I replaced it and recharged the system. What racecar doesn't have a/c? I cut up my altima fans for a cleaner look and foam taped everything to improve cooling. Shrouding from the intercooler to condenser/radiator will be next. Did something cool with my rear overs. S14's are shaped stupid so now I have the same clearance front and rear, plus they match my front fenders! More cool stuff. And a random iphone photo I took before hitting the mountains.
Touge Tuned |
05-16-2015, 08:34 PM | #29 |
There are more suitable overs like Chargespeed for OEM aero IMO. Unless you plan on adding other aero bits like splitter, canards, diffuser etc.
Touge Tuned |
05-16-2015, 08:45 PM | #30 |
Had a major setback today.. Plowed into the back of a stopped minivan on the way to SoWo.
Got both my headlights, right corner light and fender, hood, grill, intercooler, a/c condenser, fans, etc.
Touge Tuned |
