01-17-2015, 09:21 AM | #1 |
✰✰✰ Yashio Factory Oka-Chan Water Temp Meter Version 2 - $249 ✰✰✰
We have an early order placed with Yashio Factory for their soon to be released updated version of the Oka-chan water temp meter. Demand is still sky-high for their original unit and having had a chance to see the new model in action, we can safely say it is far superior. Made in Japan it simply plugs into the consult connector allowing the unit to display a wide variety of real-time sensor readings. It features a large LCD screen with an easy to read green back-light (much improved over the original model), multi-channel and map display modes, warning and peak hold functions and a fault diagnosis function. Available channels include water temperature, RPM, vehicle speed, batter voltage, throttle voltage, airflow voltage (single or twin MAF), 02 sensor voltage (single or two sensors), AAC voltage, injector duty, ignition timing, A/F correction, intake air temperature, power steering and a/c. This unit will only work on Nissan's that have a functioning Consult port. If you have a Power FC installed this until will not function correctly. We currently have a large shipment of these on pre-order. They will not arrive until the end of January. Supplies are limited and Yashio Factory is expected to sell out quickly. Price $249 http://www.gtr-garage.com/collection...-temp-meter-v2
www.gtr-garage.com |
01-30-2015, 06:39 PM | #2 |
Just got mine today. Any chance you guys would be able to provide a translation for the user manual? Seems like lots of functions to utilize, no clue how though...
01-30-2015, 06:40 PM | #3 |
That's a good idea. We'll sit down and translate the manual and then put a link to the PDF up on our website.
