11-14-2014, 08:57 PM | #1 |
1996 Nissan 240sx
SOLD! SOLD! SOLD! SOLD! SOLD! SOLD! SOLD! SOLD! SOLD! SOLD! SOLD! SOLD! ************************************************** ************************************************** ************************************************** ********************************************* 1996 Nissan 240sx 5spd base model Super cold A/C and hot heater Clean title 197k miles on chassis and motor. Original Miles Engine: stock ka24de obd II Recently replaced with OEM parts from Nissan, water pump, thermostat, alternator and z32 fuel filter. Front main seal. New NGK iridium spark plugs, wires distributor cap and rotor. Sonic motor aluminum radiator. GKtech fan blade. K&N drop in filter RSR ex-mag black piping cat back exhaust Drivetrain: ACT heavy duty pressure plate with street disk clutch, baker precision clutch steel braided clutch line. Driveshaft shop 1 piece steel drive shaft. Kaaz 2-way LSD I used Kaaz fluid every 3000 miles Brakes: z32 30mm aluminum brakes front with new rotors and portifield rs-4 pads. Stock s14 rear with new rotors and bendix ceramic pads. Steel braided brake lines Suspension: JIC Magic fla-t2 coilovers Tien inner/out tie rod Kazama tension rods PBM g1 rucas ST front/rear sway bars New Energy suspension rear subframe and diff bushing Tanabe front/rear strut bars Wheels: 5lug conversion Varrsteon 17x9 +22 front 17x9.5 +30 rear Interior: Full stock interior 7/10 condition. 1 crack on dash PBM shift knob Exterior Painted lavender metallic Origin-lab stylish aero Nissan rain guards Dmax tail lights Circuit sport clear corners and side marker CON: BLOWN HEAD GASKET BOUGHT OEM HOOD, SO ITS DIFFERENT COLOR I am a medical student and don't have time to fix it due to almost impossible to finish bunch of homeworks and studying. I don't even have time to go out either.. I am not in a rush to sell. IF NOT, I LIKE THIS CAR A LOT SO I DON'T MIND KEEPING THIS CAR UNTIL I FINISH SCHOOL AND FIX IT. $4000 as is $3500 without wheels Keep negative comment to yourself, thanks Pink slip in hand ready text 714 728 3683
