09-25-2014, 12:05 PM | #3541 |
Heat wrap on any exhaust component is a pretty good idea for heat management.
Also, for items for which you want to keep the heat out of, heat reflective tape is a very good additional measure. I recently had to do both measures to protect my wideband and BMC. After a proper trackday, all items held up fine and engine bay temps have dropped by a good amount. In addition, I has having heat soak issues on my wideband, and the heat reflective tape with wrapping the downpipe which it ran about 10-12 inches from, allowed the wideband to not run super hot, drive resistance values to infinity and stop working. Almost all turbo cars I have have a combination of Ceramic coating, heat/fiberglass wrap and heat reflective tape |
09-25-2014, 12:09 PM | #3543 |
Blanket on my T3 turbo dropped the temp 3 inches away from 500+ F, to barely above 95 F. This dropped underhood temps by several hundred degrees and kep the radiator cool as well (T3 turbo SE-R).
Now, how good goodspeed heat management properties are, that's another question. And for something which requires quiet a bit of research and cost to get the material grade and makeup correct, I would be a little skeptical of a knock off.......but if it works, it works, I guess I use either Thermotec or DEI materials when it calls for it. |
09-25-2014, 12:38 PM | #3544 | |
AFC #1
09-25-2014, 03:15 PM | #3546 |
AFC #1
10-01-2014, 02:23 PM | #3551 |
AFC #1
Ball bearing: .032in / .8mm
Journal bearing: .062in / 1.6mm To bad Harp isn't making kits anymore...
10-06-2014, 07:52 AM | #3554 | |
What's always concerned me is just the shear magnitude of how small an orifice that is for a very critical engine part. At an average engine oil pressure of say 30-50 psi at that tiny orifice area, that's just not alot of oil flow. I can't imagine it taking much more than a tiny piece of debris to clog that orifice and cutting off oil flow to turbo. Has anyone else had a similar concern? |
10-06-2014, 07:55 AM | #3555 |
10-06-2014, 09:38 AM | #3556 | |
As long as it`s making more power when boost is added, i`ll add boost! Really nice powerband also. Stock head, stock TB, stock headbolts, forged bottom with about 9.5-10:1 compression and reinforced block. |
10-15-2014, 04:01 AM | #3557 |
Got a dyno day scheduled for this Sunday with Martin from Enthalpy. It'll be at Built To Win Performance.
My s13 is a street car that gets daily driven a lot (although I have a vert and an EM1 civic for backup) yet it sees it's fair share of street drifting and events (when they're ever nearby). It still has full interior, power steering, heat, automatic seat belts, sound deadening, etc. I just purchased a set of 740cc injectors and JWT s3 cams. Will be throwing all this and a z32 MAF in before going on the dyno since I'm currently on stock tune/MAF/injectors/cams. I've only been running the 2871r at about 8 lbs for the past 4 months (due to stock tune/injectors/MAF), but I'm thinking Martin will shoot to put me at about 16 to 18 pounds since I'm on stock pistons. Not sure what the limit here is. My setup:
I am running a stock 62 ECU right now but the other ECU i have that Martin has modified already is an E5. I currently have a skinny o2 sensor since I have a 62 ECU. Can he change the tune on the E5 ECU to work with this skinny o2? I'm hoping so. Also, as far as the tune goes, I would like the knock sensor disabled and a quicker sounding revlimiter. Less like gunshot Bee-R style, and more faster and smoother like PowerFC style (if that's even possible to change on a ROM tune). Not sure what numbers to expect, but I will post up the results!
10-20-2014, 01:05 PM | #3558 |
So to follow up, Martin and George from RS-Enthalpy got to play with my car on the dyno last night. They were running into some issues right off the bat which they believed to be fueling.
I have an inline Moroso fuel pressure gauge for my stock FPR. They said it was dropping some pressure up in the rev range, which Martin figured it could be due to the stock fuel pump wiring and/or my e-fan thermostatic switch being wired from the fuel pump fuse (I have a new OEM fan shroud and GKtech fan that I was waiting to put on until afterwards because I wasn't sure if it would be as easy to see the crank pulley with the timing light). Martin clipped his jumper wires straight from my battery to the power wires that goes to the fuel pump (he made little openings in the insulation) then made another pull, but said it was still acting up. He said it might be some rust in my tank, and maybe a bad fuel filter, so I immediately threw my brand new filter on. They said fuel pressure got about 2 pounds better, but the old fuel filter looked like it had some black specs coming out of it when they'd shake it. We looked in my fuel tank to see that it was really clean, but they said my Walbro was really old and brown (I got it in 2010, used). They were confident that if I put a new fuel pump and sock in my tank that everything would be perfect so that it could go to 18 psi. With the issues it was having, they only went to almost 11 pounds, where it made 286 whp on the DynoJet (which they said was the good dyno that doesn't make the power seem higher than it really is). According to them, those were really good numbers for that low pressure, so my setup was pretty spot-on. Martin was also very confident that at 18 pounds it would make 360-380 whp. He's coming back in about 3 months for another dyno day and said he wouldn't charge me since I got the word out for yesterdays event and got him a fully booked up day. That, and the fact that my dyno time didn't get to be used as well.
10-20-2014, 02:17 PM | #3559 |
AFC #1
I am impressed your stock FPR is still holding up. They do tend to start bypassing fuel under boost after a while. Especially with more flow and higher fuel pressure.
I still want to know what Martin set my rev limiter to. Have never hit the limiter.
10-20-2014, 05:02 PM | #3560 | |
They said that the supposed need to get an aftermarket FPR at modest power levels is a phenomenon from the FWD crowd, and that there's absolutely no reason to change from the stock FPR until 500+ whp, because there's actually a greater chance of having issues when using an aftermarket FPR underneath that power. Having watched them work their magic on 12 cars in a row yesterday, with each one demonstrating that they know their stuff backwards and forwards, I'm highly inclined to believe them. It was impressive to say the least. And you should contact Martin about your rev limiter rpm. He could probably have your answer pulled up for you super quick.
10-23-2014, 05:27 PM | #3562 |
What's everyone's thoughts on using the direct bolt on version vs. generic 3" inlet style?
I can see the potential to make a bit more power, though I like the idea of bolt on utilizing what I already have and keeping the clean look. Can anyone actually quantify what type of differences you would see in power? Am I that much better off going with the larger inlet style? Side note this would be in combo with s3, oem manifold, and external gate for reference. Thanks
@UpshiftEngineering |
10-23-2014, 09:25 PM | #3563 | |
-Kyle |
10-23-2014, 09:37 PM | #3564 | |
Trader Rating: (18)
Feedback Score: 18 reviews
I don't like to fab stuff up too much, depending on my mood...lol. I believe the 3inch inlet (56. Trim), just makes about 10-15whp more. My friend Sr made 366whp on E85, 16 psi on a 52 trim. My gt2871r sits in my closet right now, waiting to be installed by December. I think it just comes down to your own personal preference on which to choose. |
10-24-2014, 08:09 AM | #3565 | |
luckily, I like to fab stuff!
10-24-2014, 09:01 AM | #3566 |
cbh148, why would you disable the knock sensor?? It is actualy active in the regions of most importance and actualy load (it's inactive below 44-4600 I believe). The largest loads occur in the mid range when going full throttle, so I am not sure that is such a good idea.
And in terms of load, I am not talking about just simply airflow, but how the engine transitions from no throttle to WOT in the middle of the RPM range. It's similar to putting it in 5th and going WOT going up a hill from 3K onwards. |
10-25-2014, 11:55 AM | #3568 | |
Martin was all for disabling the knock sensor. They're more for helping with saving the engine if non-premium gasoline is accidentally put in, rather than for saving the engine if it leans out spontaneously doing sportscar stuff. Yeah I've heard that too -- that it gets ignored beyond some rpm.
10-25-2014, 10:05 PM | #3569 | |
Furthermore, just because you are listening to the knock sensor, does not mean you have to react to it. In other words, if I had the option of knowing what it says, vs flat out removing it, I would rather simply have that additional data flowing in to react to if necessary. Just for curiosity sake I've put "bad" numbers in places to see if the knock sensor knows whats up... and it does. It always does. Just some food, it is a tool and should be treated like one. |
11-03-2014, 07:48 AM | #3570 | ||
