09-04-2014, 01:31 PM | #1 |
jdm cluster USDM engine
i purchased my friends 240sx, it had a ca18 in it, it now has a ka24de dohc, but it has a jdm cluster, does anyone know of any way to get the tach working without buying a new cluster?
09-04-2014, 06:22 PM | #2 |
Both the ca18 and ka24de use the same tach signal so if the tach is not working its either a wiring issue or the tach itself is dead. The sohc ka24e tach is the one that uses a different signal and won't work but you can use a Dakota Digital converter to fix the issue. The converter costs about $80 bucks.
09-04-2014, 06:28 PM | #3 |
You got that backwards.
CA18 and KAE use the same tach sig. SR and KADE use the same. OP you need a KADE or SR Tach
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
10-18-2014, 01:49 PM | #4 |
Hate to bring up a old thread but I figured I would point out that this is incorrect in case anyone comes across this in a thread search. I was hoping that my memory was wrong and that Sileighty was right but I just finished up a ca18 swap into my car that had a SOHC tach and it did not work. After I swapped in a DOHC tach it worked fine.
