02-09-2014, 10:51 AM | #214 |
Ok here is where I'm confused. If i run the second caliper independent from the regular brake setup then where does the e brake get its fluid from? All the pics im looking at show lines running from both ports on the hydro master. Shouldn't the hydro have a separate resivour
02-12-2014, 08:52 PM | #215 | |
or maybe like this or put in a remote resevoir like this |
02-15-2015, 10:51 PM | #221 |
Hey George, just bought these brackets and a pair of mustang rotors. Just to make sure, I run the normal brake lines from the master cylinder to one pair of Z32 calipers, then I run a separate line from the hydro e-brake that splits into two that goes to the other pair of Z32 calipers correct?
07-09-2016, 03:39 PM | #223 |
Would this also work on stock 4lug set up without any of the cutting ? My hydro is on the way and want to lean more on the dual caliper set up. Any info would be appreciated
