![]() Join Date: Apr 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
![]() Hello everybody, so I've got a seemingly small problem that I am dealing with and after doing research and applying those methods, I'm frustrated because I'm still where I started.
To get you folks on track:
So yeah, nothing is moving at the moment except my RPM needle moves very slowly when applying and letting off gas--I revved the engine to a high RPM and the needle moved like a turtle. Any ideas? Is the mechanism stuck or broken? How can I find the original or stock positions? |
Trader Rating: (38)
I tested out the SOHC cluster as well with the same gauge faces and got same results: lights work, turn signals, high beams, warning lights, e-brake light, etc. all work except for the gauges.
Forgot to mention that I checked the fuses and the wires to make sure and everything is fine. I guess I solved the mystery and need to get the mechanism that turns the needles fixed. |
The DOHC tach gets a 0-5V signal from the ECU and the SOHC tach gets a 0-12V signal off the coil. That might explain some of your tach issue.
NismotronicSA - Speed-Density Tuning for Nissans |
#5 | |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
#6 | |
Trader Rating: (38)
Also, do read my previous post where I said that I checked the wiring and fuses and everything checks out just fine. So it can't be the "car" side. Update: Got the fuel gauge and the temp to work. The speedo and tach/RPM gauge are also kind of working. What I mean is: 1.) the tach still revs slowly and then sticks 2.) the speedo does go up as I drive and goes down before I stop but very slowly |
#8 | |
Having two different clusters fucked in exactly the same way is unlikely though, unless you pulled the same dumb move on both of them. And DON'T TAKE THE FUCKING NEEDLES OFF THE GAUGES STUPID... Cluster mods must add like 50hp or something. |
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 41 reviews
i had a similar issue with my last car... check ALL of the wires (especially ground) going to the plugs in the dash harness. these wires are over 20 years old and will split VERY easily! i found my issue was the ground cable had split in half when i removed the cluster (i went from digital to analogue). the split ground cable caused the cluster to do all kinds of weird stuff! the dash/cluster harness unplugs at the main dash harness about a foot in. take it out and completely inspect it. the split in my ground wire was so small i couldnt see it until i spread the wires out!
Trader Rating: (38)
^Definitely will recheck those grounds, thank you, dorkidori.
Also, racepar1, thanks for trying. It was nice of you to reply with information that I already stated. Clearly, insulting other members makes you all the more helpful. I'll make sure that I "gain power" for my car from this. |
#12 | |
...ever ever ever ever ever ever ever ever ever... ...EVER, take the needles off the gauges. Serious question though. Did you do the same thing to BOTH clusters? Is there another car available for you to plug your cluster into just to be sure? Like I said before, it is EXTREMELY unlikely that both clusters have the same issue. Want a cluster upgrade? Get a Stack unit. Replacing gauge faces is dumb... |
#13 | |
Trader Rating: (38)
For anybody that wants to paint/color in their cluster's needles, you'll want to pull the gauge needle and not the metal pin that comes along with it. Delicacy is a must when putting the plastic portion back in. Calibration is a breeze if you leave the metal pin inside.
And yeah, I was able to test out both clusters on a different car and it worked. My speedo and tach on the DOHC cluster took a dump on me. For daily driven car, a stack unit isn't needed. |
Tags |
240sx, dohc, gauge cluster, s13 |
