Old 03-31-2014, 10:48 PM   #1
Nazdog247
Nazdog247 is an unknown quantity at this point
While turning wheel hard to the left my electronics cut out the turn back on
Alright so I have a 95 240sx and been having some problems with the wiring on the car... When I turn hard to the left I've been realizing every once and awhile my lights inside and out will flicker. Dash lights my deck and my gauges that I have will turn off and turn right back on... I have no clue what it could be I know my tires rub on the inside but jus like any lowered car... Been realizing this lately and was wonderining if anyone knew what it was... Thanks
Nazdog247 is offline   Reply With Quote
Old 03-31-2014, 11:05 PM   #2
heychris
heychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura aboutheychris has a spectacular aura about
Searching is your friend......sounds like a short
Sent from my SM-N900V using Tapatalk
heychris is offline   Reply With Quote
Old 03-31-2014, 11:12 PM   #3
Nazdog247
Yeah I'm sure it's a short somewhere jus wondering if anyone knew where it could be. Just replaced a fuse that was blown under my steering wheel... Idk if that will do anythin thou lol
Old 03-31-2014, 11:21 PM   #4
typical
typical is an unknown quantity at this point
If you're lowered and know you're rubbing, I'd check the wire harness in the wheel well. Most people relocate that up thru the fender. Just a thought, worth a shot.
Disclaimer: I only have s13 experience and am not very bright. Just trying to help
typical is offline   Reply With Quote
Old 03-31-2014, 11:48 PM   #5
Nazdog247
Thanks for your input I'll have to check around for the harness tomorrow that might be it! It's weird cuz sometimes I'll be maybe 1/2 wheel turned and it will do it an others I'll be fully cranked and nothing...lol
Old 04-01-2014, 12:31 AM   #6
240boi115
240boi115's Avatar
240boi115 is an unknown quantity at this point
im almost 99% sure its the harness. i lowered my car and forgot about it and on the ride home had some issues ooooooh boy. just take the fender off and get you some zipties and youll be all set. also if the wires have been eaten through youll need to repair/ replace them. keep electrical tape on you.... youll need it
Originally Posted by 13esim View Post
I'll trade you my 300ZX and my older sister
my 240 broke down..again
240boi115 is offline   Reply With Quote
Old 04-01-2014, 06:42 AM   #7
Nazdog247
Thank you! That sounds like the problem... So would I need to remove my fender as we'll? And I believe there's harness on each side right? so I would need to take off both my fenders to do this?
Old 04-01-2014, 11:06 AM   #8
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
+1 this!
I'm sure this is the issue. Take that fender off and take a look.
Dboyizmlg is offline   Reply With Quote
Old 04-01-2014, 09:16 PM   #9
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Look first to see if that it is your issue. If you see wires rubbed out and bare, then you're gonna have to take your fenders off to relocate them higher up.
http://zilvia.net/f/showthread.php?t=233752
CLICK HERE!!!
Old 04-04-2014, 04:43 PM   #10
dallasb53
dallasb53 is an unknown quantity at this point
your gonna have to take your fender wells off to check. iirc the harness goes from your fuse box down the left outside engine bay and then on the front of the radiator core support. there is a wiring harness on the right side but it goes from the front of your motor over the top and into the wiring harness inside the engine bay. not likely to get rubber out.
been awhile since i pulled my wiring harnesses lol
dallasb53 is offline   Reply With Quote
electronics, wiring
