Old 02-15-2014, 07:23 PM   #1
apple240
apple240 is an unknown quantity at this point
RB 1991 240sx RB25 hatch FS/FT
Turbo is blown. Sale or trade for snowmobile, truck,boat
I have a 91 240sx hatch with an RB25 swap. I swapped this motor myself and put all top of the line parts in it. It ran and drove amazing and is pretty fast. Im guessing it makes somewhere around 280 horsepower but can easily be increased with the boost controller and a tune. The RB is from rawbrokerage in orlando florida and all the parts needed for the swap also came from them. I have a wiring specialties plug and play harness along with the piggyback harness for easily adapting in new electronics and gauges, and mckinney motor mounts all the way around. I put a lot of time and money into this car. There is not one ebay or godspeed part on it. Everything is name brand or special custom ordered from japan. The rb also has new water pump and timing belt done by rawbrokerage. It has a mishimoto radiator and 565ft lb 6 puck act clutch.also has stainless steel power steering kit with reservoir, raw brokerage inter cooler and piping kit. 300zx. The gauges are also AEM coolant temp sensor and AFR gauge. No suspension has been done. Frame is in good condition. Nismo shifter and an LSD. Also I have new drive belts never used.
Stock parts:
Power windows
Power Doors
Sun roof
After market parts:
RB25 Series 2 engine and transmission(under 60,000 miles)-$2600
Walboro Fuel Pump-$100
Tein inner and outer tie rods-$160
McKinney motor and transmission mounts(Powder Blue)-$500
Wiring Specialties Harness rb25 into s13-$500
Wiring Specialties ECU patch harness(to easily wire in new accessories)-$149
AEM Digital coolant temp and Air Fuel Ratio gauges-$350 for both
Autometer Boost gauge-$90
300zx Maf-$120
New Tomei Timing Belt-$190
Nissan OEM timing component kit-$154
ACT 6 Puck Clutch Sprung HD 525ft lbs-$350
Custom Raw6 heater hoses-$60
Chase Bays Stainless steel power steering kit-$240
Flex a lite 12 and 14 inch fans-$80
Mishimoto Radiator for RB swaps-$225
Raw6 -steel 1 piece driveshaft-$365
Impact GT front mount intercooler and piping-$480
McKinney RB Down pipe -$235
New valve cover gaskets-$60
New thermostat
ISIS fuel pressure regulator adaptor-$30
New spark plugs NGK_6es-$25
New rear main crank seal-$50
Raw6 Blue Silicone radiator hoses-$50
Raw6 vibrant air intake filter-$80
New water pump-$115 (raw brokerage installed)
Professionally installed water pump and timing belt by raw brokerage-$240
I have receipts for all that comes out to a little over $8,000
The bad: no doors lock, paint,no heater core, also I blew the turbo, but the car still runs and drives. Not saying that at I am ,just saying the motor is still perfect just the turbo went cause of my boost controller. Speakers need replacing and headlights don't go down.
Looking for 6000 or best offer, the swap alone cost me more than that.
Looking also to trade for a pickup truck
Pretty much tell me what kind of truck and ill let you know. Im open to all offers. I started a business and a pickup truck will help me make a lot more money faster.
PM me and I can send you any picture you want.
Dave
apple240 is offline   Reply With Quote
240sx, for sale, for trade, rb25, s13
