Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 07-25-2013, 08:59 PM   #31
S14kouki_10
S14kouki_10's Avatar
S14kouki_10 is an unknown quantity at this point
Curious to see how you fixed the rust by the hood hinges
S14kouki_10 is offline   Reply With Quote
Old 08-07-2013, 07:24 PM   #32
Aaj2k5
Aaj2k5 is an unknown quantity at this point
Thanks coolwhip! And as far as hood hinges go I haven't gotten to doing that section yet - ill post up when I do though.
This ladies and gents is a TR6060 6 speed from a ~2012 Chevy Camaro. Thanks to a man named Joe, it now resides in my shop staring the LQ9 down. Also joining it is a bnib GM TR6060 concentric slave cylinder and a Camaro driveshaft, flex couplings and the shifter. TR6060 is fairly factory with exception of carbon synchro's.
Aaj2k5 is offline   Reply With Quote
Old 08-11-2013, 08:16 PM   #33
Aaj2k5
So probably one of my more productive days woohoo!
Did the passenger engine bay same as the drivers so no real process pics required:
Then I did a 1x3x.120 up the footwell at a 60* angle and all the way along the floor. The floor was bowed from welding the whole panel in but with a bit of planning and a bit of weight on it - it squared up to 0.1 degree side to side and 0.2 end to end relative to pinch weld and 0.6 degree relative to the engine bay rail - not too bad. I capped the top of the 60* piece so it's nice and flush but I might add a small drain hole for condensate inside the rails.
Nice and square
Ill match the other side up next weekend hopefully. Then tie both into rear subframe, add the 20* pieces connecting the engine frame rail with the floor rail and get some wheels bolted up and set on em!
Old 08-16-2013, 10:42 PM   #34
S14kouki_10
looking good
Old 10-06-2013, 08:08 PM   #35
Aaj2k5
Had some time today to get some done on the Z
Matched the passenger footwell, floor rail and footwell rail to the drivers.
I have to find out if the subframe fastener can stick through the mount plate for my cage main hoop. If it can't, I have to inset a nut inside of the 1x3. Anyone know if I can?
Old 01-13-2014, 07:03 PM   #36
Aaj2k5
Same old game - days off getting farther apart and I'm going to McMaster part time to finish my B.Tech.
Updated the Solidworks model with cage:
Plated the rear strut tower tops and fitted the rear tower member of the cage. Also cut out the rear floor to the frame rails so I can start on fuel cell frame.
Hit up BendTech for the main hoop - thanks Joe!
Cut the main hoop base at ~9 degree angle towards the rear so it sits flush at base when hoop was in place. This is a temporary fastener for subframe btw - inverted socket head shoulder bolt will be the final.
Didn't wanna waste $100 on a lift plate - cut piece of scrap 1/4"x6"x18.5" plate, drilled 10 holes, zipped two 1" pieces of scrap pipe, ground flats on each of them to sit square and just need to weld er up. $2 lift plate (cost of fasteners haha)
Old 01-14-2014, 10:50 AM   #37
Coolwhip
Coolwhip's Avatar
Coolwhip is an unknown quantity at this point
Send a message via AIM to Coolwhip
Nice update!
Keep em coming
Coolwhip is offline   Reply With Quote
Old 01-16-2014, 09:29 PM   #38
Therealdapnyc
Therealdapnyc is an unknown quantity at this point
Nice I have one as well
Sent from dap using Tapatalk
Therealdapnyc is offline   Reply With Quote
Old 01-19-2014, 06:08 PM   #39
Aaj2k5
Hit up the shop today - got the main diagonal in. Before someone mentions it, I plan on taking the tacks off and cleaning up the weld joints next weekend before continuing the rest of the cage - I just didn't have any emery cloth today.
Also finished up that lift plate. Buying some engine goodies this week hopefully come in for the weekend.
Old 02-09-2014, 06:32 PM   #40
Aaj2k5
Obviously not the wheels I will be running, however these 205/60/R16 have the exact same OD as the 275/40/R17 I have at the shop. Someday will be 315/35/R17, but I'll run the Yokohama 275's I already have first.
The forward rear control arm mount is at 0 degrees centre of mount pivot to the centre of the balljoint at the ride height shown. This leaves 3.5 inches of wheel travel upwards from ride height once I cut out the wheel well and run extra wide ZG flares
The rearward rear control arm mount is at ~5 degrees from centre of mount pivot to centre of balljoint at the ride height shown.
Suspension experts: Is 3.5" enough wheel travel or am I leaving too much or too little of a gap before hitting tire into wheel well? The optimum parallel RLCA - is this to the front mount or the rear mount of the RLCA?
All arms will be adjustable, but if I have to move my subframe mount up - now would be the time to do it.
Also, made these braces up - will make the same for the other side of the engine mount bracket all the way to the firewall.
Factory 2012 Camaro driveshaft with the isolator placed where my transmission flange will be:
This means I can cut the second half of the camaro driveshaft off at roughly that weld line and weld a Q45 flange onto it for mating to my diff. I'll have a U-Joint, Slip yoke as well as the rubber isolator at the transmission output shaft.
Picked up GM LS7 Lifters
As well as GM LS2 Lifter Trays
Everything in blue is done.
I put the Z back on rotisserie today so if this week I can come to a conclusion about the subframe height I can continue on with the cage.
Old 02-09-2014, 07:02 PM   #41
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Looking good man
Old 02-10-2014, 11:18 PM   #42
edsonflores
edsonflores is an unknown quantity at this point
looks good
edsonflores is offline   Reply With Quote
Old 02-16-2014, 08:29 PM   #43
Aaj2k5
Edit: old setup
Old 03-02-2014, 07:09 PM   #44
Aaj2k5
Removed the old 2.5"x2.5" Crossmember.
New 1.5"x3"x.120 cross member - just roughed for now since I didn't get the M20 Socket head shoulder bolts in time.
Clearance to bulkhead. I added 3/4" angle to the bulkhead for strength in that corner, notched the bulkhead and the angle for the 1x3 horizontal piece. Brought a tube from the frame rail down to this at what worked out to exactly 45 degrees Also added 2" angle 6" long to brace the factory crossmember where this 1x3 meets it.
Also picked up one of these for dirt cheap since the powdercoat was dinged on the front face as shown. 50% off for a pure aesthetic? Sold!
04-07 Cadillac CTS-V Brembo Front Caliper
# Pistons: 4 x 40/44mm
Total piston area: 8.61 sq. in. 5554 sq. mm
Rotor Thickness: 1.26 in. (32 mm)
Part #: (L) 89047727
Old 03-30-2014, 08:00 PM   #45
Aaj2k5
I've been called in to work every weekend so this has not progressed all month
Matched the DS fenderwell to the PS
Turned these up on the lathe since I don't like paying $$$ for $3 in 6061 T6. Solid diff bushings - new to make a few more for the front of my Q45 diff.
Started sketching my front knuckle to design CTS-V Brembo caliper adapter.
Old setup:
New setup - not shown but welded pipe nipples into the holes like the old setup to sleeve bolts/help crush.
Tacked in place after measuring from a number of reference points.
I'll have new front subframe mounts done next weekend and continue on with cage A-pillars!
Old 03-31-2014, 09:50 PM   #46
S14kouki_10
What did you paint the fenderwell with?
Old 04-01-2014, 10:26 AM   #47
Aaj2k5
Tremclad - the whole car will be covered with this and when all of my metal work is done, I am media blasting the whole car.
Old 04-28-2014, 07:17 PM   #48
Aaj2k5
Soo this happened a few weeks ago
So I was out of the game for a bit, but starting back into er now.
Took this setup
And stuffed it in here
Had to chop the factory transmission mounts off the car to get the TR6060 to clear but there is plenty of room in there otherwise. The shift is about 2" too far back but that is no sweat since it has a 6" long bracket connected to a rod which can both be shortened.
The steering rack is going to be an issue but ill deal with that after I make my mounts.
Also, this is waiting for a rainy day.
Old 04-30-2014, 07:29 PM   #49
edsonflores
looks awesome keep it up
Old 07-01-2014, 11:35 AM   #50
Aaj2k5
Thanks edson,
While I've been down with the ACL tear I had some powdercoating done by JP @ Strip Tech. My Cusco RUCA's as well as the LQ9 valve covers in wrinkle red.
And to start rebuilding the RUCA's since it seems like the PO didn't know they were left hand thread.. QA1 XMR12 chromoly rod ends - I just need to turn up the 3/4 to M26x1.5LH adapter this week.
Picked up a set of JDMFlares Wide ZG fender flares - 3.75" in the rear, 3.25" in the front. I'm not a fan of doing the usual sheet metal screw so I grabbed M8 nutserts and the tool to install them.
The interior was pretty haggard from welding the rails and sitting forever. All seam sealer is gone, penetrating welds smoothed and all the remnants of sound deadening gone as well.
Made these up for the front cage mounts
Now that the front mounts are done, need to clearance the cowl a bit to allow a nice tight fit of cage to A-pillar.
Also need to cut some tube with an ID larger than the OD of your cage, in an odd shape similar to the pic.
I still have to finish up the cowl clearancing but that's it for today!
Old 09-05-2014, 08:27 AM   #51
lgsr20swap
lgsr20swap's Avatar
lgsr20swap is an unknown quantity at this point
Eagerly waiting for a update lol.
Sent from my SCH-I605 using Tapatalk
lgsr20swap is offline   Reply With Quote
Old 09-09-2014, 10:51 AM   #52
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
I love this build.
Frank_Jaeger is offline   Reply With Quote
Old 10-14-2014, 09:30 PM   #53
240sxowner
240sxowner is an unknown quantity at this point
Awesome work man, keep it up! Def an inspiration for my current s30 build. Looking forward to an update.
240sxowner is offline   Reply With Quote
Old 11-07-2014, 12:52 PM   #54
Toykoz32
Toykoz32 is an unknown quantity at this point
WOW . . . . Im loving everything about this build. Just started mine about a month ago, planning on a z32 diff tho.
Toykoz32 is offline   Reply With Quote
Old 12-31-2014, 09:26 AM   #55
sleeperd
sleeperd is an unknown quantity at this point
awesome build
sleeperd is offline   Reply With Quote
Old 02-01-2015, 06:27 PM   #56
Aaj2k5
Hey guys, been a while since I've been able to get to shop.
Picked up Contano S14 5 lug hubs
Borrowed a buddies tube bender and bought a Princess Auto tube notcher. This is the biggest POS I've seen but it was cheap and I needed something asap. The blue bushing housing had a ton of play to the shaft and the hole saw adapter had huge runout so I made a new shaft assembly out of some spare bearings and milled a plate with a step to align them. Popped a 3/8" hex socket into the end and pinned it so it will never spin so I can adapt to any drill and the wobble of the drill will be taken up by this adapter.
Bent up some scrap pieces of tube to get angles right without using the good DOM
Bent up full A-pillar bars
Halo bar notched nicely.
Front view of today's work
Next will be dash bar and halo to main hoop. Should I go straight back or X for the roof bars?
Old 10-14-2015, 03:53 PM   #57
soundboy
soundboy is an unknown quantity at this point
I like everything besides the front suspension and the drifeshaft. I believe a aluminum unit would be great for this build rather than retrofitting spots for the carrier bearing. It would work tho.
soundboy is offline   Reply With Quote
Old 10-20-2015, 08:49 AM   #58
lgsr20swap
lgsr20swap's Avatar
What's up with a update!!!!! I sent u a pm on that notcher. I want u to make me one. I will prebuy it
Sent from my SM-N915V using Tapatalk
Old 01-14-2016, 03:37 PM   #59
brianglawson
brianglawson's Avatar
brianglawson is an unknown quantity at this point
Send a message via ICQ to brianglawson Send a message via AIM to brianglawson Send a message via Yahoo to brianglawson
Subbed, Nice Sir!! how are Z33 transmissions holding up to V8 torque?! (always heard about synchro problems in earlier years)
S15 SR20DET Powered, Kouki S14 http://zilvia.net/f/showthread.php?t=578575
brianglawson is offline   Reply With Quote
Old 09-01-2018, 11:10 AM   #60
jr_
jr_ is an unknown quantity at this point
It's been a while. Any updates OP?
jr_ is offline   Reply With Quote
240z, datsun, lq9, s30, v8z
