![]() Join Date: Oct 2008
![]() i have a 1995 s14 ka24de, i was parked and when i tried to start my car it wont start i just heard a clicking noise.i dont know if my starter is out, so i checked my battery voltage and its fine, what other things should i check before i replace my starter? and also how hard is to replace the starter? THANK YOU
today i hit my starter with a rubber hammer a few times and it doesnt start, it just clicks once every time i try to start my car, any other ideas?THANK YOU
![]() Join Date: Jun 2011
Trader Rating: (29)
![]() Feedback Score: 29 reviews
[QUOTE=s14koukirules;4118524]today i hit my starter with a rubber hammer a few times and it doesnt start, it just clicks once every time i try to start my car, any other ideas?THANK YOU[/
Your battery might have a lose connection. Might be wrong just throwing ideas out to you. |
![]() Join Date: Oct 2006
this happened to me on my coupe. huge pain in the ass. i tried hitting it with a starter. i took the starter out (which is super easy) and cleaned the contact areas. i cleaned both terminals on the battery. check all my grounds and cleaned them.
after multiple times doing this i bought a used starter from someone local to me. car started right up and havent had a problem since. you can also check the voltage going into the starter which cranking the car to see if you are getting enough power. you want to check it coming off the trigger wire.
92 Coupe ka-t |
![]() Join Date: Nov 2004
Check your clutch interlock relay ISSD if your starter is still good. I think that's what it is on an s14. It is inside the fuse box on the passenger side in the engine bay.
i was going to take out the relay out of the fuse box, but i cant find the clutch interlock relay, i just found one that said clutch ASCD CUT is that the one?THANK YOU
![]() Join Date: Mar 2011
check your grounds, I had that same problem when i rebuilt my engine and put it all back together, it woudl just click, click, click I added some more grounds and it turned over.
#12 | |
That switch is notorious for going out on 95 S14's causing your starting problems. ID PS: Before you replace your starter, take it to Pep Boy's, Autozone or O'Reileys and have them test it for you for free. Chances are your starter is probably still good...
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies.... ![]() |
today i went to buy the clutch interlock relay at autozone, but they don't carry it, does anyone know where to go buy one? And how much do they run for?THANK YOU
#14 |
finally i took out my starter and took it to autozone for testing and it pass, know i will change my clutch interlock relay tomm to see if thats the problem.
#16 |
![]() Join Date: Jun 2003
Trader Rating: (130)
Guess you're fucking retarded for bumping a two year old thread just to add your useless comment?
