93 240sx from Shell to Silvia SR20 GT3076r
Purchased the shell when I lived in TN back in 2008. Delayed for budget constraints, Iraq Deployment, etc. Looking good now.
93 240sx from shell to Silvia SR20 GT3076r - Imgur Redtop sr20det XTD 13lb Flywheel CarbonKevlar clutch Garret GT3076r 3inch downpipe, test pipe, cat back, and knockoff N1 muffler JGY Fuel Rail and 72lb Injectors Walbro 255 fuel pump JWT ECU FMIC Short shifter Alum Radiator One Piece Driveshaft r200vlsd 17X8 Wheels 1 inch rear wheel spacers Wide front and rear fenders Full body kit KYB AGX Struts w/ H&R springs Evo leather Recaro seats on bride rails, modified of course 5 point camlok seat harness' I might be missing some things, but I think that's it. Shooting for 450whp....may be high but we shall see soon. JWT ECU comes in today, will test it out and see how it all goes. Check the imgur gallery for details of the build process. Thanks for all those who posted to this forum and other forums. I used forums and google as my technical assistant the entire way. |
looks good, why did you opt to stay bottom mount vs top mount with that turbo ?
how is it for response ?, or is it power at the top ?
Two-Tone owner#011509-Lightly Modded ![]() |
I opted for bottom mount for cost mostly...and because I had yet to find anyone who kept the factory manifold. Maybe a reason for that. I'll find out tonight when I fire her up for the first time since the upgrade. JWT ecu comes in today!! I'll let you know the response and such. Also my friend who provided the vlsd's has a dyno, so i hope to get initial numbers running it at 15psi.(wastegate is set at 15, once I'm comfortable, I'll throw a controller on there and take it up)
Test last night was a no go... Fuel pressure regulator was leaking fuel from where the flange meets the rail....Not quite sure why. I sent an email to JGY to ask if they have seen this issue using the factory fpr on their rails... I might go for some Permashield and dress the flange.
New an improved O-ring for that regulator fixed the fuel leak. She fired up and test drove. Took a little while for it to stop stalling, guessing the ecu was learning the atmospheric bov again. It did this when I first did the swap for about a day.
Only issue I am having is exceeding my clutch.... I didn't realize the stage 2 I had in there was rated so low (250hp). I'm shopping for a 6puck now. The clutch slips around 13psi in all gears. Even so, the car still feels great, pulls hard and if I half throttle it I can get a 2nd gear pull. I'll update when I get a better clutch in there. |
Spec installed and broke in! Pulling hard and no clutch slipping!!!!!! I hit 5psi at 3100rpm and full boost (15psi) by 3800rpm. This turbo is pretty sweet! Although, I've never ran a 2871 so I cant really compare with my 3076.
Tags |
240 240sx, 400 hp, gt3076r, s13, silvia conversion |
