#121 | |
![]() Join Date: May 2007
#122 |
![]() Join Date: Mar 2005
Trader Rating: (41)
You can use the stock driveshaft if you choose to, but it puts your motor unfavorably forward. The motor/trans need to be pushed back 2 7/16" back with the method I use of bolting up the trans cross member like so
![]() Simply bolt up the front of the member to the back holes and make a bracket. This in turn will obviously move the shifter back that distance, but you'll end up with proper clearances for other things in your engine bay. Doing this will also put you within 1/8 from the brake booster on an s13, so this is as far back as you can go. Small update on my pig. Time to fab up all the little things, so I threw in my mockup motor. ![]() I'd be willing to make you guys motor mounts and the trans brackets for a very reasonable cost if anyone is interested. Just shoot me a pm
"cigarettes killed my father, and raped my mother!" Last edited by turtle m3th; 10-06-2013 at 12:50 PM.. |
#124 |
Fries, I didnt get the full kit from brett :/. but as you already saw, turtle clear everything up
#125 |
Trader Rating: (41)
I am currently working on getting a full kit together for you guys (minus the adapter plate.) I've done this swap a few times now, and have a good understanding of how things "should" be done, and what should be improved upon.
parts included: Plug and play harness motor/trans mounts (with, or without the use of an insulator) power steering kit driveshaft available for order through "thorough concepts" Ali is great!!! template for shifter hole trimming stock sway bar modification (i'll post pics of this soon.) throw out bearing modification (you can send me your current unit to save money) pilot bearing adapter clutch line (if converting from auto trans) A list of part #'s you need to finalize your swap and lastly PDF files of articles I've found to be informative about the 1UZ! If anyone of you is willing to a comprehensive build thread, I'll be glad to provide you with all items from the above list granted you provide the parts needed for modification (engine harness, throw out bearing, etc.) I can even go as far as doing header modifications, and making y pipes!!!
"cigarettes killed my father, and raped my mother!" |
#126 |
have you done the wiring on this swap for an s14 before? id rather pay someone that knows what theyre doing, than screw it up trying to do it myself. a lot less stressful for me being that I will not have to worry about it while packing up everything and trying to sell the house. if so, PM me a quote.
#127 | |
#128 |
Trader Rating: (41)
Sorry guys, I have yet to get my hands on an s14. But, on the upside, I have got a car to work with so I can start a well documented build thread. Pretty much everything I've listed above will be covered, so stay tuned!
"cigarettes killed my father, and raped my mother!" Last edited by turtle m3th; 10-11-2013 at 02:39 PM.. |
#130 |
Trader Rating: (41)
I'm not 100 percent sure, but it's most of them if not all. I only use the larger sized bolts that are on the top and the sides.
finished mounting up the power steering pump, and mocked up the lines. The routing isn't final yet. ![]()
#131 |
![]() Join Date: Sep 2011
Yup from reading this whole thread, I might not get the swap kit from Brett.
To think your paying 16?? (that's the price I saw on his page (could be wrong) and still have to modify some parts it's not such a good ideal. Right know I just picked up my 1uz with harness and ecu with all accessories, for a good price I couldn't pass up. And looking to get this swap started. Will be keeping up with this page. Turtle I pm'ed you. |
#134 |
I finally got my 1uz 89 coupe finished and took it out to the drift event. Its a 91 1uz. Exhaust is 2.5 from the headers to single 3" to a vibrant muffler. KADE trans, straight one piece alum shaft, welded diff, 205 tires. The torque is awesome compared to my ka24det25 10psi hatch. Definitely has a bit more hp too.
Here is a vid from the event. Im in it a few times. Shannonville Drift Event Oct 14 2013 - YouTube ![]() ![]() |
#135 |
I don't want to burden this thread with an intro and my 1UZ woes, but I'll keep it short...
Who am I: My name is Mike. I'm a 29 year old graduated Mechanical Engineer from University of Miami, currently still living in Miami. I have tons of fab and machining experience (check out my previous job of chief engineer at scorpionmotorsports.com). I'm now in the medical device field working as a Biomedical Engineer. I've been drifting my Z for 3 years, and decided to build an S13 missile car since the Z is my daily and it's not worth busting up at the track. My story: After getting the run around from Collins (including a huge variation in his pricing along the 6 months it took him to respond to all my detailed questions), I found a member on Zilvia selling his "turnkey swap". It was not cheap, but did come with all the right parts to stuff it into my S13 including a Z33 tranny and adapter, new ACT clutch and modified tundra headers. I don't have any malice towards the previous owner, he has been great at helping me out with questions I have, but the built quality is not up to my standards.. you know what they say, if you want it done right, do it yourself. The wiring was hacked, the engine looks a thousand years old, and the other day, get this, I took the header wrap off to slap a coat of heat resistant paint on them only to my dismay to find a 3" section of galvanized fence post section welded in. To add insult to injury, the welds might be the worst welds I've ever seen and do not fully seal. Needless to say, I will be fabbing my own long tube 304SS headers (at least the driver side). I can provide updates to anybody interested in my build, but I am grateful there are others out there that are knowledgeable and happy to post their builds for us to follow along. |
#136 |
Sweet shit jitter!
Sucks about your header z33. I'm not excited about having to get mine fabbed. I was able to get a 1uz outta a rear ended ls400. With 83k on it! Rear main leaks like a mofo, but other than that... Pretty stoked. Did work. ![]()
#137 |
I have never seen 1UZ swap headers, even Collins was going to "need my car" to custom make me a header. WTF. I understand clearance is tight, but hell.. if someone sold legit headers with their mount kits, I think they'd have a strong advantage over their competitors.
I'll keep everyone posted when my mandrel bends come in. |
#138 |
Trader Rating: (41)
Glad to see there's more activity in this thread! I'm heading to the machine shop tomorrow to get some of these parts going for you guys.
#139 |
Trader Rating: (41)
Very exciting news guys! Just left the machine shop and the prices are projected to be very similar to Brett Collins! These are actual cnc'd parts for around the same cost as some mickey mouse bullshit! First thing being addressed is the throw out bearing. So, for those of you that have only purchased your plate through Brett, I will have a solution for you guys so you don't have to deal with the lack of proper "customer care" or questionable quality control. This is a process, so i'll be updating everyone along the way before the build thread actually begins.
#140 |
great work turtle! im sure that once your name gets out there you will have his business. bc ive heard nothing but complaints when it comes to his customer service. looks like you got a new business on your hands! ha.
#141 | |
#142 |
Trader Rating: (41)
Hey guys, check out what a customer of mine is dealing with when if comes to good ol Brett!
He opened up a paypal claim against him yesterday @3:57 pm (10/19). Here's the screen shot of what was said. ![]() Then i'm assuming that once Brett caught wind of the claim he even more disrespectfully decided to send the package anyways @8:05 pm (10/19) after a refund was requested!!! So now my customer has gotta deal with that. ![]() Fries: I've got you covered if you can wait about 2 weeks!
#144 |
Trader Rating: (41)
^LOL! honestly though, you guys can peep my trader rating and feel confident buying from me. I'm an engineer major myself, and i have no idea which school Brett is learning from, but he sure doesn't make it seem accredited, LOL!
#146 |
Trader Rating: (41)
I can make whatever demand dictates. I wish I had the resources to explore all avenues, but unless the demand is there i'm much too small of an operation at the moment to accommodate everyones needs. A 1/2jz adapter is very likely in the future though! However, I will stray away from doing one for the ka transmission because it will inevitably fail on the jz series.
#147 |
Trader Rating: (41)
Updates: Okay, so the throw out bearing parts are taking a little longer than my machinist originally told me because he had to order up some tooling to get the job done. Shouldn't be more than another week. Pilot bushing adapters will be done next week too!
onto my turd! I got a lot of little things sorted out: power steering lines, radiator lines, y pipe, intake (armor all tub temporarily, LOL!) p/s cooler, along with some other small stuff. I'm almost ready to start wiring. Should be another couple of weeks since I don't get much time to wrench these days. the lines are just for mock up ![]() ![]() yes, I got the biggest filter I could find! ![]()
#148 |
Does anybody have an FSM? Preferably from a early 90s LS400 which my particular setup was pulled from. I'm buttoning up the wiring but ran into a few items of concern maybe you guys can help me out with:
There's a ring terminal near the passenger cylinder head that has 4 wires in it (including two White/Blue) and I'm wondering if it's for a ground or what. Do you have to pull the intake manifold to get at the +12V that goes to the starter? Also, where are you guys mounting your igniters? I tubed the front end of my car, so I have no fender wells forward of the shock tower to mount to, so I may need to mount them further back and extend the AFM plug. TurtleM3th, which power steering pump are you running? Mine is belt driven off the passenger side of the engine... is yours electric? As an update, I started receiving the tubing to fab my headers/y-pipe. So I'm stoked about that. |
#150 |
Trader Rating: (41)
here's a model of the new throw out bearing assembly which is getting done this week! I will not be providing the actual throw out bearing itself so you have the ability to run whichever one you'd like. It is also internally identical to the stock unit, so the grease collector is also retained.
![]() A "no guess" pilot bearing adapter is also going to be in the mix this week. hope you guys are as excited as I am to get these parts into testing!
