Old 08-20-2013, 05:46 PM   #1
s14sliding
s14sliding is an unknown quantity at this point
IACV coolant lines help
YES i have seached. so please chill. i purchased a S13 sr20det with freddy intake manifold on it. I don`t know which and how the coolant lines are supposed to be hooked up to the IACV and throttle body. I have a feeling the guy i purchased the motor from looped the coolant lines so that they wouldnt have to travel through the throttle body or IACV. Can i leave them this way without TB or IACV being connect? If not any help on where the coolant lines on throttle body are supposed to hook up to and the lines on the IACV? Ill have pictures up soon.
s14sliding is offline   Reply With Quote
Old 08-21-2013, 06:12 AM   #2
s14sliding
ImageUploadedByTapatalk1377087022.624861.jpgImageUploadedByTapatalk1377087131.777860.jpgImageUploadedByTapatalk1377087155.563811.jpg
Old 08-21-2013, 10:17 AM   #3
waxball88
waxball88 is an unknown quantity at this point
Well, its quite simple. The Idle control is NOT hooked up to coolant. The IACV is hooked up to vacuum at the rear of the manifold, and then in front of the throttle body.
Your pictures are horrible. But if the coolant is looped leave it looped.
Yes you can run the car without coolant to the throttle body. You "can" run the car without an IACV if you adjust the idle via the throttle plate; IE cracking it open making your static idle higher. However your car will be a bitch in cold weather.
waxball88 is offline   Reply With Quote
Old 08-21-2013, 11:09 AM   #4
Kingtal0n
Kingtal0n's Avatar
for a daily driver you need the coolant lines connected. I forget which but one of those two things has a wax element that expands or contracts with temperature and changes idle speed.
check the FSM it tells you all about the wax.
tinyurl.com/4l80er
Old 08-21-2013, 11:11 AM   #5
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
that is NOT TRUE. IACV has coolant passing through it, along with TB.
your pics totally suck
loop TB, just run 2 lines thru IACV, direction doesnt matter.
KoukiMonsta is offline   Reply With Quote
Old 08-21-2013, 11:53 AM   #6
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
I don't even have coolant flowing through any of that crap haha
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 08-21-2013, 01:20 PM   #7
s14sliding
Sorry for pics being shit it's hard to get a camera down there while the motor is in the engine bay. Ill try and get better ones today. But from what some of you are saying just loop the throttle body. I will try and do the IACV as winter in North Florida believe it or not it can get really cold. When I do that I'll take pics just to make sure I'm looping them properly.
Old 08-21-2013, 01:33 PM   #8
Mikester
Mikester's Avatar
No, you didn't search.
Here: http://zilvia.net/f/tech-talk/499765...old-hoses.html . I just capped off the throttle body coolant feeds with 5/16" vacuum caps w/small clamps.
If you have any other questions, let me know.
Old 01-17-2021, 02:07 PM   #9
christhedude41
christhedude41 is an unknown quantity at this point
I know this is an old thread. But! Awhile back when I was throwing my engine together I bought the s14 water neck to keep from having coolant lines running behind the block. WELL that also meant I had no coolant running to my IACV. We threw away all the s13 metal lines that give me the ability to hook up my iacv to coolant. Can I try to run a t piece from the heater core lines to the iacv and run it like that? Or do I need to get the under intake metal hoses? I cant find them anywhere.
Sent from my SM-G973U using Tapatalk
christhedude41 is offline   Reply With Quote
Old 02-01-2021, 11:28 AM   #10
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
if you need a set of the metal hoses, I have spares. if its easier for you to just add a tee to the heater core lines, go that route.
