#14402 |
They don't show it apart on the FSM iirc. When I pulled mine apart, there was no sealant or gasket, so I put it together without any sealant. I have 300 miles on the motor now and have had regular oil pressure the whole time.
* S14SR22 * 9.0 c/r * GT3071R * |
#14403 | |
Having driven a few road race cars with kidney killing set ups that were ok on the street but killed the track, we think the same here. Firm, progressive, settings kick ass
#14404 |
![]() Join Date: Jan 2008
Does anybody know if 30mm z32 brakes with 350z track rotors will fit behind xxr 530s sized 17x9.75 +25 on all four corners?
'89 240sx-Track monster in progress '03 Grand Prix GTP-pepped up DD. |
#14405 |
Better asked in the wheel fitment thread...
#14407 |
The main reason you see sag is because there is not center support. It has been or was removed to make room for the FMIC.
#14408 | |||
![]() Join Date: Dec 2004
Trader Rating: (58)
And truthfully, I'd say my Koni setup rides nicer than any of the competition based, similar priced coilovers. You want the suspension to work with the car not against it. No
#14409 |
Does this rsm
http://i53.photobucket.com/albums/g5...pexirsm003.jpg use this manual? Apex'i Old RSM Manual Theyre slightly different and Im not sure if it matters
#14410 |
![]() Join Date: Dec 2009
Has anyone heard of this company, SSI Exhaust Industrial Co., Ltd.???
I recently bought a turbo and it came with an elbow made by this company... I'm just wondering if their products are any good.... thanks heres their link.. Taiwan Export, Manufacture ![]()
#14411 | |
Bandwagon.
But if you're concerned about drooping, there's the 4 bolts that hold the bumper up under the hood., you can play with that. |
#14412 |
What wheels are these?
![]() Yes, I know they are fugly & weak sized. Just need the name. Googled "6 spoke directional wheel" and came up empty. The pic was taken in Japan this spring. The picture taker doesn't know what they are either. |
#14413 | |
Many companies use progressive springs in the coil over sets. A Progressive spring is one that has stiffer and softer spring rates in the same spring. All the coil overs that are a mix between what I will call 'all out race', and 'basic Stage I Street' use progressive rate springs. Tanabe's 210 'Grip Feeling' is also a progressive rate spring. This is why these firmer coils also have a softer ride that still works well on the street is due to the progressive rated springs Think of progressive spring rates like a really stiff spring at the top 1/3 of the total spring, a Stage II spring in the center 1/3, and a Stage I spring in the bottom 1/3. If the spring is merely moving across flat tarmac, it offers a smooth compliant ride. If it is driven a little harder, the center is flexed and suppressed and holds a slightly firmer ride quality. If the car is driven hard, the springs flex to the Stage III firmness of the top 1/3 of the spring. The harder the suspension is worked, the firmer the ride becomes. I have the same style progressive rated springs in my Sportster cafe racer's shocks and forks. The billet racer WORK's shocks are softer when barely moving, but lay into it and they get really stiff. Same as the fork springs with the Gold valve emulators and stiff oil, softer when barely cruising, but lay it into a back road corner and it gets totally stiff and 'racy'
#14414 |
![]() Join Date: Jun 2009
I bought some rear Project Mu pads and put them on yesterday. I resurfaced the rotors and what not. They work and all but I can't get them to lock the ebrake. I went sliding at a track last night and the ebrake was kinda awkward. I know it was working because if I was already sideways and grabbed the ebrake it would still lock, but I couldn't get them to lock just to initiate. It's like they aren't grabbing hard enough. Also, I have to pull it up maybe 3-4 clicks higher in my driveway for the car not to roll back. Anyone else ever have any of these issues?
I jacked up the back and verified both wheels are locked when the ebrake is up. I don't think I should tighten the handle because at the first click the pads are already starting to touch the rotor.
#14415 | |
AFC #1
![]() Join Date: Oct 2003
Park with the hand brake on?
#14417 |
AFC #1
As far as the pedal, yes. Under the dash there is an adjuster on the master cylinder rod where it screws into the fork that pins into the pedal.
#14418 | |
Bandwagon.
http://zilvia.net/f/engine/528353-bo...ipe-529-a.html what if we adjust the rod fully and still no adjustments pedal wise for engagement? |
#14419 |
Do you mean compress the brake pistons? Yes i did. I just swapped wheels today and i noticed after one day the driver side pads were still turquoise looking but the passenger side looked pretty dusted over and almost black. Also the edges of the rotor had a pretty bright red rust color. Ill upload some pictures in a bit.
#14423 | ||
Trader Rating: (58)
Seriously, think about what my reply was and consider the source. Why pay for such work on SOHC engine if it's just going to be put back together somewhat stock and kept that way? I'm all about pissing money away on dumb shit, and stuff I don't really need, but in the same respect I understand where money should be spent on a street car. Quote:
The only positive of a progressive rate is for 'daily' driving...and my reply to that would be if you're daily driving a car in a city persay, why not just run a lower spring rate. Anything performance related in a car you want repeatability in action...not 'well if i'm doing 50mph in this corner vs 75, I need to do XXX vs YYY'. Atop of that progressive springs allow for abnormal changes in body roll as the spring is 'non existant' for a certain amount of time. NOT FOR ME. PS: Tanabe coilovers are generic run of the mill things. No different than any other similar priced JDM things. PPS: While I've never tracked cafe style bike, I can say on a sport bike I don't know of anyone who runs a progressive spring. http://zilvia.net/f/s-chassis/297254...al-thread.html
#14424 | |
Trader Rating: (58)
Did you read the rules/regs of the for forum? 2 posts doesn't allow you to post in the classifieds.
#14426 |
![]() Join Date: Sep 2004
Trader Rating: (24)
I think you're confusing digressive valving and progressive springs.
Pretty much everyone runs linear springs, but most of the performance shocks (real stuff) have digressive rates (which is why the shock dynos have a 'knee' in them). Lower, linear rates on the street work fine but with real shocks and higher linear rates the ride quality is still not that bad. |
#14429 | |
#14430 | |
![]() Join Date: Mar 2010
Trader Rating: (34)
![]() Feedback Score: 34 reviews
![]() S15 coil packs will work with S13 head? or should I get some Splitfire? or LS1 coils... I know S15 coils have built in ignitors, not sure how this is gonna work. |
