#63 |
![]() Join Date: Jan 2004
Trader Rating: (82)
![]() Feedback Score: 82 reviews
best price i got quoted was 350..... will see , what tools are you using to assemble your bottom end? torque wrench ? rod stretch tool? how are you measuring your clearances? im also interested in assembling my motor as well
NEED Bolt kits for your car? |
#67 |
Trader Rating: (82)
shit! hell yeah i have better access to better tools and i was planning on not doing it, but after viewing this .. im going to go ahead and build it lol
#68 |
![]() Join Date: May 2011
Trader Rating: (50)
![]() Feedback Score: 50 reviews
not hating at all but you everyone's gotta pay homage to the ebay gods at some time in there lives lol.
FS: DSS 1pc Steel Non ABS, 6bolt axles WTB: Boost Gauge, Hatch Roof Wing |
#69 |
Trader Rating: (50)
nice, i am thinking the exact same thing bro. hows things going?
#72 |
![]() Join Date: Dec 2008
Trader Rating: (71)
![]() Feedback Score: 71 reviews
nah its my old one. i just cleaned it reall good! use the foamy engine degreaser and a nylon cleaning brush. or pressure wash it. just make sure the two ports are covered.
#73 |
Trader Rating: (71)
my ID1000 came in! 11mm tops ill be using the aem fuel rail that will need longer spacers to fit.
![]() injector dynamics goodness! ![]() learning how to degree my cams but 1st i need to set my valve lash .008" intake and .010" exhaust according to BC cam card. intake side is pretty much done but exhaust side was no were near specs. i had to buy a few shims in the 2mm+ range but few needed 1.91mm & 1.93mm and the thinnest nissan carry are 1.96mm.....what to do??? ![]() ![]() ![]() ![]() |
#79 |
Trader Rating: (71)
not much update but finally done with valve adjustment. ordered few shims frm my local nissan dealer and took at least a week to get 6 shims. then i needed more for the exhaust side so i ordered some frm nissanparts.cc actually got them quicker than my local dealer considering their in Washington.
![]() anyways.....decided to give this shim tool i bought frm egay!supposedly its for toyotas. at 1st, i was like...damn! this thing works awesome. till i took out the cams out and noticed it was scratching the journals. polished em with 2k sandpaper hopefully it'll be fine! ![]() ![]() i was stuck how to switch shims around quicker and not scratching the journals. so i decided to fabbed my own bucket/spring pushed-down out of 304 stainless steel flat bar. ![]() ![]() it bolts on to one of the cam cap bolt and pretty much press down on the edge of the bucket and shims pops off easily. ![]() |
#86 |
Trader Rating: (71)
been a while since i updated the thread.....here we go....
bought some hi temp powder on ebay i hate rust so i decided to take the s15 turbo apart and coat the turbine housing. ![]() how it looks ![]() also decided to coat the isis v2 turbo manifold aluminum oxide blasted ![]() how it looks ![]() this is where my build stand at...... ![]() pick n pull had a labor day sale 50%off everything so i took advantage! scored a 96 s14 ka24de unknown miles??? ![]() ![]() tear down..... ![]() also scored this z32 calipers frm pick n pull for cheap....alredy have em but hey it doesnt hurt to have another set plus they were cheap! ![]() parts starting to pile up again.... ![]() this another KA build is for smog purpose only. cali smog sucks! lol |
#88 |
Trader Rating: (71)
found out i got another yr or so till i need smog :dance: !!!!!so im going back to building the built KA
![]() was lurking around ebay and scored this BC intake and exhaust valves for 130shipped which i think is a steal! ![]() i guess ill give this setrab 8an oil cooler a try. if nascar uses it im pretty sure itll work on my KA. ![]() king bearings and NPR piston ring set for the "smog legal" KA built lol ![]() |
