05-06-2013, 12:39 PM | #13651 |
I have the same issue right now. Ober time it has gotten harder to steer, my rack also creaks close to full lock, makes loud cracking sounds, and pulls to both sides even after multiple alignments.
05-06-2013, 12:44 PM | #13652 |
Right. I really have to manhandle mine to get it to turn. I also forgot to mention that I dont have the electric plug for the power steering but that shouldnt make that big of a difference.
05-06-2013, 12:48 PM | #13653 | ||||
GM2 (SW/AW)
(no offense taken) As for your guys' problems; Quote:
Look into a new rack & pinion. if you're hell bent on the idea that it's not your belt being loose, and your pump being good. Then I'm willing to bet your seals and such are going out. If you're working with a front wheel drive car, also look into your CV shafts. Although I'm fully aware this is a nissan site, My fiance has an issue similar to this, with her axles on her hyundai. Food for thought.
KA-T for life! Current for sale advertisement |
05-06-2013, 12:53 PM | #13654 | |
05-06-2013, 01:59 PM | #13655 |
I've tried searching on my phone but its not working.
Is 17x9.5 too wide for the front wheels? Would 9" be fine? The offset is +12. Would I have to roll or pull fenders with either? I have stock suspension now but will be getting coilovers soon I'm not trying to go crazy low but a nice drop. Also anyone know any good brands for hub eccentric rings? * |
05-06-2013, 02:27 PM | #13656 | ||
GM2 (SW/AW)
Belt really could be an issue. Like I started to mention in a different post, my fiance's car had an issue with the belt tensioner. occasionally it wouldn't apply full tension, and the belt wouldn't come off of the pully, it would slip. So she'd have intermitten power steering, followed by brief moments of manual steering. There really isn't too much going on with power steering, aside from the pump & rack. If you are the one with custom lines, do look into the pressure factor. If your lines are bigger etc.. you may not be building enough pressure. What I did was remove everything PS related. I found a tutorial on greasing & welding closed the feed nipples on the rack. Turned it into a manual rack. But that's just what I ended up doing. In theory it is actually possible for your pump to have allowed some metal shavings to block a line or two.
05-06-2013, 07:29 PM | #13657 | |
-John
Follow us on Instagram @Driftculture_ s14 Weekend Warrior s13 Drift Missile |
05-06-2013, 07:56 PM | #13658 | |
05-06-2013, 08:31 PM | #13659 | |
05-06-2013, 09:12 PM | #13660 |
when i replace the head gasket.. do i need to take off the intake manifold ..what do i take off? when taking the off the head?.. while having the engine inside?
05-06-2013, 09:39 PM | #13661 |
Used the search feature and google already but my question is what's the difference between s13 ka24de and s14. Besides the number of valve cover bolts and the obvious obdI and obdII difference. I'm just talking about the long blocks themselves not the intake and emissions systems. In other words are the long blocks interchangeable?
05-07-2013, 07:26 AM | #13662 | |
I and a friend just raised the CO's on a S13 USDM build up 1/2" because the idiot that had the car before the trade for a hardcore straight from Japan JDM car had no clue what he was doing. The CO's were bottomed out, bumping and grinding because they were not correctly installed, so we took the fuckers off, reset them 1/2" above where we wanted them and straight nailed the measurement after the car drove for a mile or so and the suspension settled.
05-07-2013, 07:59 PM | #13663 |
do r32 gtr (sumitomo) front calipers use the exact same conversion lines as z32s? the gtr caliper is 32mm and the z32 is 30mm so im just not 100% sure. i also read something bout the gtr calipers use a different type of fitting. also with r32 calipers should a z32 bmc be good? thanks!
05-07-2013, 10:18 PM | #13664 | |
GM2 (SW/AW)
Well I mean you would be able to see if the belt was slipping easily. Start the car and leave it out of gear & go under the hold. feather the throttle and see if it slips. it's got to be a pump thing if its intermittent.
05-07-2013, 10:23 PM | #13665 | ||
GM2 (SW/AW)
If you're talking about basically swapping heads between the two, I have a few friends that have done that. Haven't heard anything negative about it. I don't know too much about it to put in a factoid on it being legit. But I would assume as long as you have the two machined to match, it wouldn't matter? I don't think there's many dissimilarities between the two. my
05-08-2013, 07:15 AM | #13666 | |
* S14SR22 * 9.0 c/r * GT3071R * |
05-08-2013, 07:23 PM | #13668 |
How does the ecu get power? This is all I need to know and I've looked at the FSM and I cannot make sense of it, I've asked on here a few times with no answer. It seems like a really simple question and yeah. Help. ;_;
05-09-2013, 07:44 AM | #13670 | ||
Still good? As oppose to what, 500whp? Personally, I wouldn't daily drive anything under 550whp. Maybe it's just me, but I think you might have a hard time driving 100K miles on a 400whp motor, depending on the motor of course.
05-09-2013, 08:37 AM | #13671 | |
ECU F4A1 ---> F5 ECU Plug F5 ECU plug -> F6 Main Harness plug @ firewall F6 splits to: All Engine sensors inclusive of MAF, TB, O2, etc and F12/F13 Underhood Fuse Box ---> Relay in Fuse Box ----> (+) Battery That is from my FSM for a 1996 S14. Yours should be very similar
05-09-2013, 08:39 AM | #13672 | |
Yes. The engine wont make 400whp all the time or anything. People (includig myself) do it all the time. Not like its a 1000hp drag car. |
05-09-2013, 11:07 AM | #13673 |
s14 tension rod bolt, the 4" one, grade 8.8 bolt safe to use? Had to buy because it did not come with the rods and I had to cut the oem one off. The original didn't have any stamped number and the store I went to didn't have anything tougher. Every other store was closed that sunday evening. I can definately get under there with a tougher grade bolt now but just wondering if it's even needed as 8.8 seems pretty tough, but what do I know.
05-09-2013, 11:16 AM | #13674 |
my connector broke on my o2 sensor on my s13 sr20, and i stupidly cut off the wires when i was doing the swap into a new shell without labeling which wire goes to which on the sensor. does anyone know? the red/white/black are on the o2 sensor side, the black/blackgray/browngray are on the harness side. also, holy big pictures. i dont know how to scale them down.
05-09-2013, 11:18 AM | #13675 | |
05-09-2013, 04:42 PM | #13677 | |
I'd just throw it in there. I through whatever is cheapest into my trans.
05-09-2013, 06:11 PM | #13679 |
that's good to hear because I just put royal purple in my sr trans but i haven't been able to drive my car yet. i was hoping the extra money was worth it on the trans fluid
05-09-2013, 07:52 PM | #13680 | |
We've got a small, sealed fuse/relay box that can replace the stock fusebox, although we'd still have to have the car here to do a fusebox relocation.
