Old 05-06-2013, 03:37 PM   #1
JDMSTYLE
JDMSTYLE's Avatar
JDMSTYLE is an unknown quantity at this point
s13 hunting idle sr20det
my idle hunts around 1500-2000 rpm. it has never done this before (i took the car for a drive earlier and idle and everything was running fine). wondering what could be causing it.
took the car out for a short stroll and hit full boost (a little bit about 1 bar) and then after the idle started acting up once i push the clutch in or have the car in neutral. was wondering if maybe a sensor or vacuum hose got loose somehow?
took a brief look around the engine bay and didnt seem like anything got loose.
some specs on the car:
s13 sr20 blacktop
has pfc
i also just recently changed the water pump if that could be related. and also messed around with the apexi auto timer if that could possibly change anything?
JDMSTYLE is offline   Reply With Quote
hunting idle, idle problems, s13
