05-01-2013, 11:36 AM | #3181 | |
that is crazy. how often is it driven? daily? |
05-01-2013, 12:05 PM | #3183 |
ok someone want to speculate iam curious what it should make....
iam getting a rebuilt sr at the moment with... 86.5 bore stock compression pistons eagle rods head decked cometic head gasket evry arp studs tomei poncams with valve springs gtx2867 740cc's stock intake mani stock exhaust mani iam going to push it 50/50 c16/91 oct something like 24psi any idea yet on the gtx? ive been pushing 350whp on dynapak last year on a fully stock sr with the gt2871 at 23 psi ( with the same fuel mix) |
05-01-2013, 12:30 PM | #3184 |
need to specify which exhaust housing AR for someone to give an educated guess. Otherwise, I am going to say maybe 410-420 depending on how hard the tune is pushed.
Mazworks | HKS | Greddy | T4 GTX3076r | Full Race | Tial | SPL | Feal |
05-01-2013, 03:00 PM | #3185 |
Which version of the 2871r did you have? I say 405-415
Unless you do a re tune, 350 at 23psi? says 52trim, bad tune or beat engine.
05-01-2013, 10:04 PM | #3186 |
http://i1326.photobucket.com/albums/u657/eddiedeleon03/IMG_1641_zpsf72b5394.jpghttp://i1326.photobucket.com/albums/u657/eddiedeleon03/IMG_1646_zpsf90279db.jpghttp://i1326.photobucket.com/albums/u657/eddiedeleon03/IMG_1647_zps6d6b0c8c.jpg
05-01-2013, 11:31 PM | #3197 | |
That SR is not at all like a virgin; more like a two dollar crack-whore that's been fucked half to death and sleeping in a dumpster for the past 15 years. Also, there's a little edit button down in the corner. Edit your posts instead of double posting.---------------------------------------------------------\/ |
05-01-2013, 11:31 PM | #3198 |
i used a no name manifold for over 3 years with no problems. if you don't have the funds for a new one just use it until it cracks. i would recommend a mazworx or doc race mani though
05-01-2013, 11:50 PM | #3199 | |
05-02-2013, 12:19 AM | #3203 |
i think they crack because cars are low. the down pipe hits something like a speed bump, and it pushes up the whole exhaust side, and since the mani is already hot, it ends up cracking it.
05-02-2013, 09:56 AM | #3206 |
bottom mount T3 2860? Well, that's different.
My old GT2871R .64 setup would hit full boost and spin the tires at 3,500.
