Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 03-18-2013, 09:50 PM   #1
Azeno
Azeno is an unknown quantity at this point
CA NEED HELP PLEASE! 90 300zx won't start!
Recently had my engine wiring harness replaced and now it won't start because of the security light flashing on the dashboard anyone know of this problem? Could it possibly be the starter relay? And is there anyway to bypass the security mechanism to get it to start?
Azeno is offline   Reply With Quote
Old 03-21-2013, 09:09 PM   #2
13esim
13esim's Avatar
13esim is an unknown quantity at this point
Im assuming the engine wont turn over.
Check your clutch/neutral safety switch; make sure its all good.
Also if you feel it is your security system, maybe you can disconnect the battery for a couple minutes to help reset it and bypass it.
13esim is offline   Reply With Quote
Old 04-02-2013, 09:53 PM   #3
Aaronbradley1234
Aaronbradley1234's Avatar
Aaronbradley1234 is an unknown quantity at this point
This is a known problem. You're stock alarm is malfunctioning. It's a silver box by your ecu (has a blue plug on it) remove it and see if that does the trick.
Aaronbradley1234 is offline   Reply With Quote
300, 300zx, 300zx na, security light
