01-19-2013, 09:53 AM | #1 |
Trader Rating: (145)
Feedback Score: 145 reviews
*** SR20 Parts *** 2013 Garage SALE - ALL must GO GO GO!!
Check out my Feedback or Trader Rating
Located in Garden Grove, CA. 92843. Email/Paypal ID - [email protected] Call/Text - 7I4-951-thirty 47 Price does NOT include shipping and shipping is not free. Please add 3% for PayPal or send as gift. NO trades b/c CASH is KING. I delete ALL sold parts within 24 hours so if you see it here, its available. * For instant respond, reply to this thread since it will forward to my cell. My other thread: Here are the last of my 240 parts I have left. The majority of the performance parts were purchased new from either phase2motortrend.com or frsport.com. Some parts looks dirty but still in great shape with minimal miles on them. I will clean them prior to shipping. This is a rough draft of my for sale thread. I will update this ad frequently and will be adding more parts. Now onto the parts... S13/S14 2-Way Tomei LSD - SOLD Spare diff parts Axles bolts (complete set) - $40 shipped Driveshaft bolts (4) - $20 shipped Diff bolts to subframe (2) - $15 shipped Diff cover bolts (8) - 20 shipped Diff fill 1/2" ratchet bolt (1) - $10 shipped Diff drain -sold Tomei diff gasket - $20 shipped (used but very little miles and looks new) S13 diff cover - SOLD Full Race Pro Stock Manifold - SOLD
i have engine hoist for rent i do SR wiring Last edited by vutony; 06-22-2017 at 03:26 PM.. |
01-19-2013, 09:55 AM | #2 |
350Z G35 Brembo Slotted Rotors Front Set $220 (Purchased new at FR @ $389.95 plus tax)
- In great shape with less than 2,000 miles. - Has a minor defect from the calipers rubbing on the rotors. - Rotors measured 30.16mm, minimum is 28.4mm. - Rotors are 12.75 in diameter Z32 Front conversion brackets to use 350Z rotors The brackets below are sold.
i have engine hoist for rent i do SR wiring Last edited by vutony; 09-08-2015 at 06:30 PM.. |
01-19-2013, 09:57 AM | #3 |
Nismo radiator cap - $20 ($55 @ frsport.com)
Mishimoto radiator cap - sold OEM S13 SR20DET Fuel Rail w/ injector caps - sold
i have engine hoist for rent i do SR wiring Last edited by vutony; 12-22-2013 at 08:43 AM.. |
01-19-2013, 10:00 AM | #5 |
OEM SR headstuds - $40
- In excellent shape - Has about 5,000 miles on them SR20DET Exhaust Manifold Inlet Gasket - $8 each shipped, 1 left OEM SR20DET 5 Hole Turbo Outlet Gasket - $8 each shipped, 1 left - Gaskets are used but still in good shape - I have reused them before and had no problem with leaks SR20 Turbo Oil Return Tube - $20 SR20 5 speed flywheel bolts (8) - $30 - bolts are in good shape, not stripped S13 SR20DET dipstick w/ tube - $20 Crank pulley bolt and washer - $30
i have engine hoist for rent i do SR wiring Last edited by vutony; 08-16-2015 at 08:42 AM.. |
01-19-2013, 10:01 AM | #6 |
SOLD
S13 SR20DET knock sensor w harness S13 SR20DET coil pack harness S13/S14 SR20DET 7 Layers Metal Exhaust Manifold Gasket S13 SR20DET motor mount brackets S13 SR20DET Megan Racing Pulley Set S13 SR20DET starter Garrett GT2871R Ball Bearing Turbo w/ HKS actuator S13 SR20DET TAKA Turbo Lines S13 SR20DET alternator S13 SR20DET AAC Valve S13 SR20DET PS pump S13 SR20DET PS bracket and hardware S13 SR20DET Greddy Intake Manifold OEM S13/S14/S15 SR20DET O2 Sensor Intial D toy cars DIF Dual Electric Fan Controller 3" custom aluminum cold pipe FRS Polished Aluminum Hotpipe S13 SR20DET S13 SR20DET coil pack harness S13 SR20DET coil packs S13 stock motor mounts Tomei/N15 TB 70mm throttle body Nismo/Tomei 740cc Fuel Injectors Nismo Fuel Pressure Regulator Type-B S13 SR20DET water inlet Toda Flywheel RPS Max Street Clutch S13 SR20DET water outlet S13 H4 Hella Headlight Housings Power Enterprise 4PK865 V-Belt S13 SR20DET Tomei 3" elbow S13/14/15 ARC Oversize Oil Pan S13 SR Koyo radiator S13 SR20DET Pro Fab Design Intake Manifold Gasket S14 SR20DET TPS Redtop head DPI Rocker Arm Stopper Valve cover hardware (rubber grommets, washers, SS nuts Walboro fuel pump Nismo SR13 thermostat S14 SR20DET engine harness
i have engine hoist for rent i do SR wiring |
01-26-2013, 09:16 AM | #8 | |
ps, the fullrace mani and sr cas should be sold soon
02-28-2013, 11:21 AM | #18 | |
yupp thanks for your business
04-15-2013, 12:41 PM | #25 |
Redirect Notice do u have these for a red top
04-15-2013, 12:45 PM | #26 |
http://i34.photobucket.com/albums/d1...p/HPIM0245.jpg redtop power steering banjo bolt and connector
04-20-2013, 09:14 AM | #27 | ||
Happy April 20th!
