Old 08-06-2012, 09:47 AM   #211
supakat
supakat is an unknown quantity at this point
A vacuum is a vacuum. I have never had any issues. My FPR feed is Tee'd to my MegaSquirt. Even DIYAutotune.com states to Tee from FPR. MegaSquirtPNP by DIYAutoTune.com
12.96 @ 116.36 - Build Thread
supakat is offline   Reply With Quote
Old 08-06-2012, 08:42 PM   #212
je_decoy
Trader Rating: (33)
je_decoy is an unknown quantity at this point
Feedback Score: 33 reviews
^^ if your blowing vac lines its gonna effect the whole system not just the individual unit its hooked to
je_decoy is offline   Reply With Quote
Old 08-07-2012, 05:22 AM   #213
supakat
Anything hooked up to a turbo motor will see positive pressure unless it has a one way valve like the brake booster.
Old 08-14-2012, 10:33 AM   #214
Bosko
Bosko is an unknown quantity at this point
Hey guys, just recently found a used KA24DE on good ol' Craigslist. Its got 125kish on it. Its got everything but the trans on it. He thinks it has a spun bearing, and is selling it for 75$ (block, head + components). Now, this just seems really low to me, so I'm alittle skeptical about its true condition, but I'm in need of an engine for my car, so, should I shell the 75$ and see what all needs done to get it going, and if so, what brands would you guys recommend? I've already started factoring in sr injectors, a fuel pump, and such. Or should I try and find a different one? I'm looking to go for a mildish build, mid to low 200's hp wise, just to be around an SR20's area. I just have no idea where to start, but I have seen the info about the injectors, 255 fuel pump, avoiding Egay, so on, I just have no idea what to expect. So I was wondering if someone could point me in the right direction. This is my first build, so I'm trying to go the "prepare for the worst, hope for the best", route.
Here's the link to the Ad if it helps
240sx KA24DE motor and trans
Just looking for alittle advice, all input is welcome!
Bosko is offline   Reply With Quote
Old 08-21-2012, 05:46 PM   #215
roboticnissan
roboticnissan's Avatar
roboticnissan is making a name for him/her selfroboticnissan is making a name for him/her selfroboticnissan is making a name for him/her self
Why is spark plug gap sooo different on everyones builds? Whats the latest on spark plug gap for turbo guys, im at 23 and having issues. That seems hella low
roboticnissan is offline   Reply With Quote
Old 08-22-2012, 05:01 AM   #216
supakat
The reason why it is so different is because of cylinder pressures, fuel, power of the spark, etc. .028 seems to be a good gap for most KA's with distributor systems. I am running .036 with LS2 coils. In regards to your setup, have you tried rewiring the ignition coil with a relay. This helped my setup a lot when I was using a distributor.
Old 08-25-2012, 06:19 PM   #217
240skate
240skate's Avatar
240skate is an unknown quantity at this point
Turn key Ka24det swap & Silvia front end
This is going in my car. What do u guys think? Its costing me 3000$ for a turn key swap...
240skate is offline   Reply With Quote
Old 08-26-2012, 06:01 AM   #218
shalezzz
shalezzz's Avatar
shalezzz is an unknown quantity at this point
If you have a de already than no, if you have a sohc than it's debatable, but still kinda high for a Kat. You Should have him install it with the price for 3 grand if he's that firm on the price. And is it tuned? It may have never ran good enough to get it on a dyno and now he's jest selling his prob and trying to get every penny he can.
shalezzz is offline   Reply With Quote
Old 08-26-2012, 04:50 PM   #219
240skate
240skate's Avatar
I have a blown stalk ka right now. Just got the car as a project. Its getting installed for 3k
Old 09-04-2012, 01:22 PM   #220
OiyItsC4ry
OiyItsC4ry's Avatar
OiyItsC4ry is an unknown quantity at this point
How are T3/T4 Turbos on a Ka? Do I still need to have it tuned or do you think I can run it w/o a tune and low boosting?
OiyItsC4ry is offline   Reply With Quote
Old 09-05-2012, 05:28 PM   #221
booey13
Trader Rating: (91)
booey13 is an unknown quantity at this point
Feedback Score: 91 reviews
^sure you can and it's been done before. Although it's not recommended. If you want it to last get a tune. An safc at the very least.
www.monkeyboysyo.blogspot.com
booey13 is offline   Reply With Quote
Old 09-19-2012, 03:44 PM   #222
Jonas00
Jonas00 is an unknown quantity at this point
had a t3 60-1 set up. works perfectly fine. you are going to want a tune ...
Jonas00 is offline   Reply With Quote
Old 09-24-2012, 11:12 AM   #223
ditchs14
ditchs14's Avatar
ditchs14 is a well-known jackass
hey guys. got a quick question. this is mostly for the guys who are running over 14psi. heres my setup
built forged bottom 9:1
bc 264 cams
bc oversize valves
all arp hardware. im running the old arp headstuds(the 1.9 saturn ones)
t3/04e @ 15psi
hks 740cc
so i blew my first head gasket. was a felpro. took the head off and everything is fine. nothing is warped. i was at the strip and i just got my bee r a few weeks ago. testing out the 2 step... anyway #4 cylinder started burning coolant after my third pass. car has around 10,000 on the new motor. coolant was NOT in the oil.
the gasket had two small holes between cylinder 2&3 and by #4 as well.
so my question is..im going with a felpro again.is there anything i can do to prevent this from happening again? a buddy had the same thing happen to his KA-T(built with t28) after a few thousand. he said that instead of just hand tightening the studs in like it says. he used an Allen key and tightened them down pretty good before putting the head back on. haven't had a problem since. also i saw that on arp's new stud kit for the KA it says you can use locktight but you must torque the head down before it sets. soo any tips
ditchs14 is offline   Reply With Quote
Old 11-21-2012, 07:01 PM   #224
brandonc108
brandonc108 is an unknown quantity at this point
What do you guys think of this kit?
cxracing.com: Newly Released Complete Turbo Kit for 91-94 Nissan S13 240SX with Stock KA24DE DOHC Dual Cam Engine
brandonc108 is offline   Reply With Quote
Old 12-19-2012, 05:20 PM   #225
240 bro
240 bro is an unknown quantity at this point
Can I Get Some Help??
hey guys,im pretty new to the whole forum thing but my names biagio, i have a 1993 240sx se,its a Ka24de pretty much stock aside from intake, exhaust and finally coilovers, anyway i was wondering if i someone could help me, im really interested in saving money for a whole turbo setup but i cant get a solid price because i dont know everything i need. could someone give me a complete list of everything id need to put on a stock 240 to have a complete setup, thanks
240 bro is offline   Reply With Quote
Old 01-23-2013, 01:20 PM   #226
One_love_silvia
One_love_silvia's Avatar
Trader Rating: (38)
Feedback Score: 38 reviews
what size fitting did everyone get for the turbo oil lines that gets welded onto the oil pan? anyone know stock sr20 thread size and pitch?
2016 Nissan 370z
Old 01-31-2013, 06:00 PM   #227
chuki monsta s13
chuki monsta s13's Avatar
chuki monsta s13 is an unknown quantity at this point
Need help ka-t running lean
Hello everybody i have a ka24de with a t25, walbro 255l pump, n60 maf, 370cc injectors, smic, xs manifold, sr downpipe and elbow, Enthalpy ECU for 91 octane and stock FPR
NOw we retarted 15 deg BTDC, when we start the car it idles fairly high, i read the wideband gauge it reads crazy lean. We checked for vacume and boost leaks but none, we noticed when we spray starter fluid in the MAF the car idles perfect for a lil bit then goes lean. I am stumped any wise words would help.
thanks
OHHHH SHITTTT!!
chuki monsta s13 is offline   Reply With Quote
Old 02-10-2013, 09:06 PM   #228
kevmeistah21
kevmeistah21's Avatar
Trader Rating: (68)
kevmeistah21 is an unknown quantity at this point
Feedback Score: 68 reviews
Send a message via AIM to kevmeistah21
I got a s13 ka24de, i removed the "PCV TREE" and now i'm wondering what to do it with it? Im going to boost it so i have a catch can as well. Can i have one vacuum line going from the PCV valve to one side of the catch can the the other line leaving the catch can going to the breather on the valve cover? OR have the the pcv and breather off the valvecover tee'd into one line going to the catch can and the other line from the catch can to pre turbo?
Late Night Crew... #02 <3
Bought anything from me? Please leave me a review!
http://zilvia.net/f/private-sellers/...meistah21.html
kevmeistah21 is offline   Reply With Quote
Old 02-28-2013, 05:12 PM   #229
EliteDriftProductions
EliteDriftProductions's Avatar
EliteDriftProductions is an unknown quantity at this point
KA Ka24de/Turbo Help
Ok, so I recently purchased a 90 hatch rolling shell, my buddy is giving me his ka24 engine,tranny and ecu wiring harness. He rebuilt it and has about 10k on the new motor. I want to turbo it and am wondering if it can handle pretty good boost on a t28 turbo? Thought about a t3 but I am not 100% on how much the motor can take. Any suggestions on what size turbo or should I just start buying eagle rods, forged pistons, new crank and cams so that I can uprade to a bigger turbo eventually? I am starting to drift so I am figuring should just stay stock for a while then slowly upgrade to all this that I just explained. Let me know if there is a better way of going about this? Thanks!
Oh and I know some of you will say "SR! Problem solved" But I hear KA's are badass built up.
more tax returns = more car parts
EliteDriftProductions is offline   Reply With Quote
Old 03-06-2013, 09:53 PM   #230
mmmS13
mmmS13 is an unknown quantity at this point
t3/t4 50 trim .63 ar beautiful turbo for pump gas, full boost around 3500rpms holds strong until redline. If the motor was properly rebuilt it will hold 15psi easily on a good tune. Im running 11psi on a stock block with 230k miles, proper tune is what makes or breaks a KA.
S13 stock block Ka-T 16psi Enthalpy tuned
*SOLD*
mmmS13 is offline   Reply With Quote
Old 04-19-2013, 11:14 AM   #231
pkhensley
pkhensley is an unknown quantity at this point
So what your saying is I can use the 370cc injectors from an sr20 (or any size injectors from an sr) on my KA-T build (single cam btw) ?
pkhensley is offline   Reply With Quote
Old 04-20-2013, 01:56 PM   #232
josh_schul
josh_schul is an unknown quantity at this point
Hey just wondering what your numbers are... i have the same turbo and am running a similar setup... just curious?
josh_schul is offline   Reply With Quote
Old 04-21-2013, 10:57 PM   #233
mmmS13
I've never dyno'd my car but I should be around 330-340whp (based off of similar setups on Ka-t.org). I'm running 16psi now as well. I think im selling my car but if I keep it I'll dyno it for sure.
*SOLD*
Old 04-28-2013, 04:49 PM   #234
driftracerx
driftracerx's Avatar
driftracerx is an unknown quantity at this point
anyone know where to get an affordable turbo manifold for my ka-24de
driftracerx is offline   Reply With Quote
Old 04-30-2013, 12:20 AM   #235
mmmS13
JGS Log manifold for a T3. Isis for a T2.
If neither of those are considered affordable then you get what you pay for if you go eBay special (DON'T)
*SOLD*
Old 04-30-2013, 09:09 AM   #236
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
Find a used JGS log manifold. Good for up to 400hp and will never crack on you.
Frank_Jaeger is offline   Reply With Quote
Old 04-30-2013, 10:33 AM   #237
240low
240low is an unknown quantity at this point
hey, i wanna go turbo ka but i have some questions on it.. i want around 250-300 whp and i dont know if i should upgrade the internals or not.. i read jeffs assessment on the different stages of ka-t's but how reliable would that be on a stock ka.. keep in mind i am aware of the other mods i would need to have as well, i just want to know as far as engine internals go
240low is offline   Reply With Quote
Old 04-30-2013, 12:27 PM   #238
driftracerx
Know where I can order one new?
Old 04-30-2013, 01:03 PM   #239
mmmS13
JGS Precision Turbo
*SOLD*
Old 04-30-2013, 01:06 PM   #240
mmmS13
If the block is healthy I wouldn't upgrade unless youll eventually want 350+hp. Im pushing 16psi from a 50 trim on my stock block that has 230k miles. Its all in the tune.
My build if you're interested in copying/ getting ideas from it
www.ka-t.org :: View topic - mmmS13's Backwards build.
*SOLD*
