![]() So I picked up a sr20 s13 it smokes only when im driving it meaning at idle it does not smoke at all only when I shift gears and give it gas thats when the white smoke comes out. The coolant and oil are fine, the car does not over heat and drives perfectly fine. I was thinking it could be the turbo? Anyone else have some input with this topic that actually delt with the same problem?
Also drove the car from Maryland to Pa which was about an 1 hour and 30 minute drive and did not give me any problems what so ever. |
Is it the stock T25 Garrett? If so it's a good possibility the turbo oil seals are fried. You can get it rebuilt. But If I were you I'd just pick up an S15 turbo or a 2871R while you're down there if you can.
Get a good leak down test or at least a compression test to be sure it's not the valve seals or something else also.
Like Me on FaceBook ![]() |
![]() Join Date: Jan 2013
White smoke can also be from running SUPER rich, but the engine would probly bog in that case. One time my GSX had the fuel injectors spraying 100% @ idle.. man it was the smoooooooothest idle I have ever seen, but it was smoking white smoke out like a chimney lol
#4 | |
Also I know for a fact that the car is running super rich I can smell it from just the exhaust. Picking up a s15 or 2871r soon and getting a tune once I get everything figured out. |
