![]() Hey all.
I'm in a predicament where I need to lengthen both my rear shafts coming out of my diff to the rear wheels. I'm running about a 6 inch wide body done by moving control arms but now have the problem of shafts too short. The original plan was to make some dolt in spacers that bolted on but I feel they won't hold to the 550+ foot pounds of torque my engine is putting out. Is there any way I could lengthen the shafts? I was thinking about cutting splicing and sleeving but I still don't think that will hold. Does any one know of a place that could make a new shaft at a longer length? Thanks for reading, Brent. |
![]() Join Date: Jan 2009
Three words Driveshaftshop.com, that's the number one place for aftermarket half shafts and drive shafts for 240s, I'd love to see that project of yours.
Driveshaft shop is gonna be expensive tho. I honestly feel that you can sleeve the stock ones. If you notice at one end the cv joint comes apart and you can remove the bearings (I'm almost positive it's the outside joint) . There is an Alan screw that holds it together on the inside. I'd cut the shaft, get a piece of round stock about the thickness of the shaft, cut to desired length, and weld in. Set it on a flat table tho to get it straight. Then sleeve it. If your welds are good it will hold. Much easier than a spacer, cheaper than a custom one/ones Good luck, Brandon |
![]() Join Date: Aug 2011
wider wheels??????
save you all the headache
www.NYZC.net |
![]() Join Date: Jun 2007
Doesn't matter- he moved his arms out, which means the hubs, spindles etc went with them... From the sound of it, the shafts are physically too short to safely reach the hubs. Only options are to find compatible shafts or have some custom-made. Splicing in a length of shaft would be okay for stock torque- but definitely not for a 550ft/lb load.
Thanks for the input guys. I'll give the driveshaft shop a call on Monday. Right now I have a set of nitto drags for the rear so not sticky tires isn't an option at this point. Haha I'll probably give splicing and welding a try and see if they hold. If not it would be good to know that the shop could make a solid set for me.
Splicing and welding is not going to hold and is a stupid idea. You're asking to fuck shit up doing that. Most shafts are hardened or tempered steel. Once you heat them up, you remove their hardness/temper and you'll twist/snap a shaft in no time.
![]() Join Date: Sep 2006
![]() Feedback Score: 23 reviews
hit up your local drive shaft shops, dude
formerly known as "hotboiblaze" ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
