Old 08-19-2012, 06:23 PM   #1
cbh148
cbh148's Avatar
cbh148 is an unknown quantity at this point
CA CA18DET Whole Or Parts -- EVERYTHING MUST GO
The motor is currently in my S13, but I'm selling it to make way for V8. I rebuilt the motor fresh since I've had it and it's only seen about 50 miles TOPS. Here's some details on some of the parts:
- Head, without cams, ported and polished by Southern Cylinder in Huntsville, AL
- Block with fresh rings, polished crank journals and ACL rod and main bearings (polishing also done by Southern Cylinder in Huntsville, AL)
- ECU has a NISTUNE daughterboard installed by Autovaughn Performance in Murphreesboro, TN
- Nice smooth-shifting CA trans with a B&M Short Shifter
- Poly motor (Circuit Sports) and transmission (Peak Performance) mounts
I was never quite able to get this motor to run how I wanted it to. It could be a bad sensor(s) or a shoddy wiring harness, I'm not quite sure to be honest, but it's all there and it has the potential to make some great power.
Here are my prices on everything:
- $300 for the block w/ new rings and bearings
- $400 for the P&P'd head
- $500 for the transmission with true B&M short shifter ($300 without it)
- $600 for CA18DET ECU w/ NISTUNE installed by AutoVaughn Performance in Murfreesboro, TN (license included)
- $1000 for the Garrett GT2860RS (disco potato)
- $350 for the Tomei 256/256 Poncams
- $300 for a set of Deatschwerks 800CC injectors
- $100 for factory injectors
- $350 for the full ISIS* turbo-back exhaust on the car (downpipe, test pipe and 3" straight dual-tip)
- $50 for exhaust manifold
- $50 for intake manifold (butterflies completely removed and their holes welded up)
- $125 for the poly motor and trans mounts
- $75 for the wiring harness (it could use a little bit of love, most of the plugs are missing the retaining clips -- this was the condition I received it in)
- $150 for N62 MAF w/ almost brand new Tomei Pigtail
- $150 for ISIS Electronic Boost Controller (from Enjuku)
If you don't see something on here that you're interested in, please let me know and I'll get you a price on it. I'm willing to entertain any reasonable offers -- REMEMBER, THESE PRICES ARE ALL "OR BEST OFFER". If you're within a couple hours of Huntsville, AL I'm willing to deliver for the price of gas in my Titan. I can ship everything but the block. The head weighs a little bit, but should be shippable through FedEX/UPS. If you have any questions, get at me.
cbh148 is offline   Reply With Quote
Old 08-19-2012, 06:34 PM   #2
collink
collink is an unknown quantity at this point
He's posting this for me. If you want pictures of something or to talk price shoot me a PM.
collink is offline   Reply With Quote
Old 04-06-2013, 07:10 PM   #3
Casperjay
Casperjay's Avatar
Casperjay is an unknown quantity at this point
what is ecu tuned for?
Casperjay is offline   Reply With Quote
Old 04-07-2013, 08:27 PM   #4
omgwtf
omgwtf's Avatar
omgwtf is an unknown quantity at this point
how much for the exhaust after the test pipe, and do you have the ps pump?
omgwtf is offline   Reply With Quote
Old 04-07-2013, 09:51 PM   #5
Lumos
Lumos is a well-known jackass
Dibs on the exhaust manifold. It's the stock iron one right?
Lumos is offline   Reply With Quote
Old 04-09-2013, 09:31 PM   #6
cbh148
cbh148's Avatar
Yes, still have the stock cast iron OEM turbo manifold.
Old 04-10-2013, 04:48 PM   #7
wurley
wurley's Avatar
wurley is an unknown quantity at this point
$600 for the nistune ecu? For $550 you can get it with installation by nistune and software.
wurley is offline   Reply With Quote
Old 04-10-2013, 10:45 PM   #8
trak-shuhn
trak-shuhn is an unknown quantity at this point
would you sell the b&m shifter separately please.PM I need it thanks.
trak-shuhn is offline   Reply With Quote
Old 04-13-2013, 08:22 AM   #9
chewyrps13
Trader Rating: (18)
chewyrps13 is an unknown quantity at this point
Feedback Score: 18 reviews
Hey do you have a stock water inlet to the block for the turbo???
chewyrps13 is offline   Reply With Quote
Old 04-13-2013, 03:13 PM   #10
Casperjay
Casperjay's Avatar
ecu??????????
Old 05-06-2013, 09:39 PM   #11
Ca-burner
Ca-burner is an unknown quantity at this point
Please text me about the block 2196138381, I has cash
Ca-burner is offline   Reply With Quote
Old 12-16-2013, 01:47 PM   #12
91_S13
91_S13 is an unknown quantity at this point
how much just for the isis ca18det downpipe?
91_S13 is offline   Reply With Quote
Old 12-16-2013, 05:53 PM   #13
bubbles210
bubbles210 is an unknown quantity at this point
Still have the ecu
Sent from my SPH-L720 using Tapatalk
bubbles210 is offline   Reply With Quote
Old 12-16-2013, 08:01 PM   #14
bubbles210
Text 2102742301 for ecu
Old 12-18-2013, 02:30 AM   #15
chewyrps13
Trader Rating: (18)
Do you have a thermostat housing? Shipped to 95334 also interested in the cams!
ca18, ca18det, disco potato, gt2860rs, nistune
