07-30-2012, 09:21 PM | #277 |
Carolina Dyno- Taylors turbo V8 s13 - YouTube
made 447 on pump gas on spring pressure, going to turn it up and run some E through it remember this is thru the auto power down low is just bring it up to speed, power jump is going full throttle |
07-31-2012, 06:12 AM | #284 |
Trader Rating: (33)
Feedback Score: 33 reviews
Its not recommended to run spacers in the rear if your pushing serious HP. The fronts are doable and many people run 10mm or smaller spacers up front but I would be afraid of using a spacer in the rear once your putting down some power. I was discussing this with a few guys on the forums and there is just too much of a risk with the spacer (bolt on or slip on). But feel free to chime in if anyone else has personal experience. I am just basing my 2 cents off of the discussion I had with guys pushing 700+hp and running 10 or sub-10 quarters.
07-31-2012, 06:31 AM | #285 |
Was just curious because my 26x10.5 slick is really close to my coilovers and I know it's a lot smaller width wise then the agx teins I just wanna make sure before I order them ya know
07-31-2012, 06:35 AM | #286 |
What wheel are you running? I've ran a 26x10.5 with both na Z32 wheels, tt Z32 wheels, FD wheel 16x8 +50 and Weld draglites 15x8 5.5" BS no rubbing on any of them.
07-31-2012, 06:38 AM | #287 |
Trader Rating: (33)
Totally understandable. I wish I had more knowledge about the S13 chassis but thats about all I can chime in.
Im sure the others on here will be able to help. |
07-31-2012, 07:50 AM | #288 | |
what pump are you running and is it hardwired or how many volts?
796whp. its a personal thing you can always go hub centric if it helps feel a little better.
MunkyW3rkz Racing |
07-31-2012, 08:39 AM | #290 |
yea its more of what you feel comfy with, yes i would rather not but we ordered out wheels and tires made the clearance we needed in the tubs then mocked them up , took our rear end measurements ordered our 9" diff housing so you will always have a +/- .25-.5" depending on growth/shrink of material and we had a tight tolerance to play with and we had to run the spacer to clear both sides of the inner tub.
over 100+ passes down the strip and never had a issue.
MunkyW3rkz Racing |
07-31-2012, 08:50 AM | #291 |
used intank supra 300lph, (came in the car). took a gamble with it, i will check fuel pump voltage next time its on the dyno. One of them should be enough to make that power
07-31-2012, 09:11 AM | #292 | |
i hardwired it with a replay to the battery and got consistant 12Volts and pressure stayed solid sitting about 38-43psi on the FPR. so IMO hardwire your pump and you should be alright. what size fuel lines?
MunkyW3rkz Racing |
08-02-2012, 02:08 AM | #295 |
Not really relevant to the thread, but on spacers, I ran 15mm rears when making 450-550, and had no real issues that I noticed on the top end.
One run went to 6K on fifth gear (R33 RB25 Tranny), alignment was a little off so the steering wheel went haywire and I let off. |
08-02-2012, 11:19 AM | #297 | |
my Throttle body brok eso i replaced it but need to set my TPS and connect a relay for the antilag set up. hoping to be wrapped up in a week or 2 then hit the track sometime this month.
MunkyW3rkz Racing |
