![]() Join Date: Dec 2010
s13 ka24de consult/obd1 plug
does anyone knoe where the consult plug is located on the s13 i knoe its somewhere around the fusebox but couldnt find it also where the obd1 plug is located as well my check engine light is on and want too read the codes is throwing any hits or help would be helpful thanx
UNDER DESTRUCTION!: 91 s13 Top Secret Build |
found them previous owner of my s13 left a bunch of alarm wiring that dnt even work thanx for the help tho
![]() Join Date: Sep 2009
Trader Rating: (22)
![]() Feedback Score: 22 reviews
Consult plug/DLC connector is above the driver's side fusebox, it's a gray 14 pin connector. S13's aren't OBD1, plus you can pull codes through the DLC.
240sx, drift, ecu, obd1, s13 |
