Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Local / Regional / National > Europe
Europe A place for our cousins from across the pond
Old 05-20-2012, 05:51 AM   #1
Califunky
Califunky is an unknown quantity at this point
UK nooooob
Already introduced myself here but thought i would say hi in my 'local' area
This is my 13 from when i got it
A bit of fun times
A few different looks
A few more on my mate Daz's flickr - Nissan 200SX S13 - a set on Flickr (check out daz's other stuff - Darren Thorndick Photography - Essex based Freelance photographer )
Another look
Califunky is offline   Reply With Quote
Old 05-20-2012, 06:02 AM   #2
Califunky
Getting ready for where everyone should go at least once
AD08's are an awesome tyre.
Old 05-20-2012, 06:14 AM   #3
Califunky
What its used for now
Spec List:
Chassis/handling -
HSD HR coilies 5/4 spring rates
Apex Performance adjustable alignment arms (cusco rear camber arms)
Fully polybushed with Energy Suspension kit
5 stud conversion using s14 hubs
R33 GTR full brake upgrade
Cusco front & rear upper strut braces
Performance -
standard CA with -
Apex Performance FMIC
Japspeed 52mm ally rad
Driftworks power steering cooler as a transmission cooler
T25g from a redtop SR
SFS performance hoses
Blitz DSBS Spec R boost controller
Grade 7 plugs
Tuning Developments 255lph fuel pump
Exterior -
Enkei NT03's, Volk CV-Pro's or R33 GTR rims (soon to all be gone for something else)
OE Chuki skirts
OE pre-facelift splitter
OE kouki rear lights
SRB Power +25mm front wings (fenders) modified to look like oe
Sure theres more. Will update as and when i can think.
Hope you guys like.
Old 05-20-2012, 07:42 AM   #4
racer98
racer98's Avatar
Trader Rating: (128)
racer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant future
Feedback Score: 128 reviews
Send a message via AIM to racer98 Send a message via MSN to racer98
coool................
racer98 is offline   Reply With Quote
Old 06-08-2012, 02:37 PM   #5
Califunky
Thanks.
Current "new" look
Wedssport TC105N in 9.5x18 et10 with 235/40 federal 595-RSR fronts and 10.5x18 et12 with 265/35 595-RSR rears
Brakes now look tiny
Ignore the bodywork, its in the final prep stage after being sprayed.
Old 06-09-2012, 08:42 AM   #6
racer98
racer98's Avatar
just a note on the front you might start hitting the top part of the shock area and you will need to fold a peice a metal so it does not bite into the tire. also same thing for the rear run a spacer as well and roll the fender some more. once you get back to the Ring you will see what I mean on this !
Old 06-11-2012, 04:56 AM   #7
Califunky
Already sorted, lip and inner arch had the hammer treatment previously. Loom was split in 2, flattened and relocated higher up.
Old 06-11-2012, 05:14 AM   #8
trickey1991
trickey1991 is an unknown quantity at this point
looks uberrrrrrrrr clean man! Sweet whip!
92' R32 GTS-T 355whp
trickey1991 is offline   Reply With Quote
Old 06-11-2012, 06:29 AM   #9
Califunky
Thanks.
Front wings (fenders) and rear passenger arch need flating back after being sprayed then the whole car needs a polish so not that clean yet.
Old 06-11-2012, 07:51 AM   #10
racer98
racer98's Avatar
what are you doing for control arms ? front and rear adjustable ones ? and is your car UK spec or Jap import ?
and your car has a factory diff cooler ?
Old 06-11-2012, 10:09 AM   #11
Califunky
UK spec, control arms are standard - just derusted and powdercoated.
It did have a diff cooler but when I checked it there was more dust and dead spiders than in my loft. It had never seen oil let alone cool oil. It's now gone
