Old 05-29-2012, 01:51 PM   #1
BLACKhatchBACK
BLACKhatchBACK is an unknown quantity at this point
S13 ABS to non-ABS
Alright, so I know this has been discussed many times, BUT I have a quick question. I pulled off my ABS system in order to get to the grommet that I fed my harness through. However, I do not want to reinstall the ABS. I know there are different ways to bypass the system (ie. T-block), but I have a non-ABS shell with MC and hardlines. I was just wondering if I would have to disconnect everything off mine and everything off the non-ABS. I know this has been discussed but after reading some threads, some were saying that you don't need to replace all the brake line. Just want a little clarification is all.
BLACKhatchBACK is offline   Reply With Quote
Old 05-31-2012, 11:45 AM   #2
kevinphan
kevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud ofkevinphan has much to be proud of
Swap out the master cylinder to the non abs one and all of the bay hard lines (front driver, front passenger, mc to rear lines firewall passenger side) and that's all.
kevinphan is offline   Reply With Quote
abs, brakes, s13
