Old 05-20-2012, 09:14 PM   #1
txrxs
txrxs's Avatar
txrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfection
s14 KA24DE obd2 bare minimum wiring
I need to know what wires on an obd2 s14 engine harness need power (12v) in order to have a functioning car.
The short:
The car (ka24det s14) is wired on an 8 switch relay panel. No body harness. Switches for ign, start, fuel, lights, fan, blah. The engine harness is mostly in tact, after some work.
After a bit of research, it seems that only the eccs relay pin 4 and ign switch pin 38 need 12v to have a running car. This proved correct, as the car does start and run, although like total shit.
Am I missing power to anything else?
DRIFTINDY
txrxs is offline   Reply With Quote
Old 05-20-2012, 11:17 PM   #2
txrxs
txrxs's Avatar
After digging in a bit more and checking out my AEM ems wire view, looks like I need provide power to pins 56, 61, and 70. That might be why I couldn't get the ems to sync. Can anyone confirm?
DRIFTINDY
ecu, ka24det, obd2, s14
