#61 | |
![]() Join Date: Mar 2011
hahahahaha.. he started this build thread at 930 am in the morning, posted like the first tenth of his build so far, and then less than 24 hours later you are calling for his head?? it takes a while to actually post up and make a build thread dude, so the fact that he hasnt completely posted it up inside of 24 hours is a bit harsh dont you think?? give him some time before you jump all over his nuts.. edit - i just realised since he has continued to update the build thread you havent come in and been a dick about it anymore, so i assume you realise your "stock Sr with a bov and shitty offset wheels" comment is null and void.. i know it must tear you up inside that we have access to cheap unlimited SR's, unlimited rb25's, unlimited GTR's, and all that awesome jap stuff but seriously dude, maybe just grow up a bit and show a bit of patience.. Cabs - its harris from ns man, good to see you branching out.. reppin it hard from down under ![]() |
#62 |
So I've finally started "the build" in the gaps when nfi's car was off getting tuned or we were waiting for something to be done before we could start on the next thing.
Took some quick shots of the car before I started but lighting was bad and the workshop had **** everywhere in the lead up to WTAC so space was limited. ![]() ![]() ![]() ![]() |
#63 |
The first task was to remove the body kit to allow easier access to the rest of the car for strippage and so it doesn't get damaged during the process. At this stage the same kit + a new front bar was going back on the car as funding wouldnt stretch enough to allow me the luxury of a wide body. This has since changed as the whole project as kinda got bigger and bigger and has now turned into a no holes barred full house build. :P
![]() ![]() ![]() ![]() ![]() The front guards turned out to be rather difficult to get off due to the sills being crushed over ontop of them at the base. The side skirts required some serious massaging and a heat gun to get off as whoever fitted them had bought a tube of sikaflex and gone to town like a mofo! After I'd pulled them off we discovered that the sill panel on the passenger side had been giving sound rough love too. Another thing was added to the list of "to be fixed" |
#64 |
Next I removed all the intake piping, afm and air box.
![]() ![]() The next step was to drop all the fluids from the car, diff, gearbox, coolant, engine oil. Then I removed the radiator to make space for the engine/gearbox to come out in once piece. The gearbox crossmember, engine mounts, wiring looms and fuel lines all had to be disconnected first. ![]() ![]() ![]() Hooking up the chain to the intake and water neck ready to be hoisted out. ![]() ![]() ![]() Sweet as! ![]() |
#65 |
The motor came out without any issues. You can balance it perfectly with the chain off these two points and with two people it was piss easy.
![]() The engine bay already starts to look pretty bare and you realise these is actually a tonne of space in there compared to alot of cars. ![]() The next step was to remove the gearbox. ![]() Then the clutch pressure plate, clutch plate and flywheel all of which were in tip top shape having only just been fitted 6 months earlier. ![]() Then we put the engine on the new engine stand (thanks nfi) and tipped it over to empty out as much coolant as possible. ![]() More coming soon. |
#66 |
Some engine parts arrived for the new motor.
Head and main studs ![]() ![]() ![]() Filter relocation block. ![]() Greddy winged sump. ![]() ![]() New OEM S13 gasket kit. ![]() OEM waterpump ![]() OEM GTiR and S13 Oil pumps I wasnt sure on which one was best to get. I'd heard that the GTiR pump was a good upgrade but wasnt sure so I got both. ![]() ![]() The goodies including new S13 splitfires with ignitor ![]() New timing chain kit. ![]() Tomei bottom end ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Rods ![]() Cam gears ![]() Oil relocation block tomei ![]() More soon! =) |
#69 |
![]() Join Date: Jun 2009
Trader Rating: (24)
![]() Feedback Score: 24 reviews
[QUOTE=CaBS;4642039]
OEM GTiR and S13 Oil pumps I wasnt sure on which one was best to get. I'd heard that the GTiR pump was a good upgrade but wasnt sure so I got both. [QUOTE] whoops my bad anyway whats the difference? |
#73 |
holy dick this is gonna be awesome!
cONtRol FReAkS |
#74 |
Thanks for the kind words guys glad your enjoying the thread. Haters will always be out there, in the end I'm trying to build my ultimate 180SX not anyone elses so as long as I'm happy with it I cant really go wrong! =)
Engine out was the easy part. Stripping the rest has been far more time consuming! Went over to the workshop one night and stripped some stuff off the motor aswell as starting to scrub/degrease it. Its crazy how heavy the power steering bracket and alternator bracket are. They're made from chunky cast iron and probably weigh the best part of a kilo each just for the brackets alone. I ordered a naprec power steering bracket and we're looking at making a new lighter alternator one aswell. The drivers side engine mount was actually loose as well which would have been letting the motor flop around much more than it usually would. ![]() ![]() ![]() ![]() The front half of the loom (engine bay and dash) out its crazy how big it is its around 1.5x the length of the car not including the back section. Will be able to loose a reasonable amount of weight out of this in the rewire. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() It really was very time consuming to get it to this point. The dash was rather involved/time consuming to pull out as was the loom from the interior. It does all come out in one piece though its just rather fiddly. Pretty excited in that everything I'm touching on looks pretty easy to improve on in terms of simplicity and weight. I should have it 100% stripped by the end of tomorrow and be able to get stuck into cleaning the whole interior/exterior. I cant wait to look at it and not feel dirty. =) ![]() ![]() ![]() More soon! |
#75 |
I'd put an extra day into stripping the car and got basically everything out of the engine bay and interior bar the essentials to keep it rolling.
boxhead helped me remove the remainder of the sound deadening tar. It was on the sides of the tunnel, under the dash and behind the firewall mat nether of which had ever been out of the car before. While I've owned it anyhow. ![]() We pulled the dash bar out to make access to the tunnel and foot well a bit easier ![]() ![]() Tunnel wiped down with solvent after most of the tar being chiseled off. ![]() ![]() ![]() ![]() Massive reinforcement bar behind the rear bar. I'd like to remove for weight saving but still up in the air about it cause the fuel tank sits just behind it. ![]() Fuel tank out! ![]() More random interior shots ![]() ![]() James and Matt W helped me finish stripping everything and clean the engine bay. ![]() ![]() The engine bay after its first proper degrease and prepsol love session looked so much better the picture doesn't do it justice. ![]() Starting on the chassis weight reduction! ![]() ![]() ![]() ![]() ![]() More soon! |
#78 |
Tuesday was a mission out to pickup steel. We're planning on making a chassis stand so the car can roll around the garage with no subframes in it for awhile.
Here some pics of what I got upto next anyhow. Drivers side parcel shelf thingo out. ![]() ![]() I didnt stuff it up too badly maybe someone will buy it? lol ![]() The other side is shivering in its welds ready for tomorrows linaging! :P ![]() |
#79 |
Got a fair bit done that weekend. I spent about 9-10 hours chipping away at things on Saturday afternoon/evening. I got the other side of the "parcel shelf" out and the seat belt mounting point. Along with the spare tyre bracket in the tyre well. I also cleaned up the passenger side of the tunnel from all the tar and removed 90% of the seam sealer along that join in the floor on that side.
Sunday arvo wheats and nfi came over and helped me sort out all the boxes of crap and they got stuck into the seam sealer from the rear towers down to the rear passengers foot wells on both sides. Damn the air die cutter is loud my neighbors will have no love! Thanks for the help too guys! ![]() Anyhoo some pics! Looks far tidier in the rear without the side parts in I think. Cars looking very bare now! ![]() ![]() ![]() The foot well I've cleaned up with solvent/rag/paint scraper needs abit more work. ![]() Surprise shot, say cheese! ![]() Accelerator pedal position shot so front leg of the cage doesn't interfere later. ![]() The wire brush makes fast work of the sealer ![]() ![]() Its the last week or two there will be so much room in there to move! ![]() Horde of sheat deemed "unnecessary" ![]() ![]() More soon! |
#81 | |
The car will still be street driven. I've had friends who have done this it makes it so much louder in cabin I've decided its not worth cutting it out. Also its a nice little whole to keep my tool bag in... =) |
#82 |
![]() Join Date: Jan 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
I just thought you were going all out cause you removed the supports behind the rear suspension towers, you might want to stiffen that part back up. If you put a cage in it then you will be able too.
#83 |
I'd halted work until this point because the car needed to be weather proof but things have now changed and the cage will all be made under cover. I'd settled on a cage design which were are a few minor points still to be decided on. The cage will come in way over what I budgeted for but the end result should be the best possible design for rigidity while still maintaining my street registration. Which is a limitation but I enjoy my weekend drives too much to give them up.
Some pics =) Some serious work will be happening here for the cage. One of the most exciting things that I'm looking forward to seeing most is the difference it makes once driving the car in anger ![]() ![]() Rear end as it was ![]() These will be going up on the for sale thread ![]() Ugly ugly ugly! No need for this anymore. ![]() Apparently I'm **** at taking out windscreens managed to break it before I'd even gotten the seal out =( Made a rather large mess of everything too. ![]() Now with less ugly (slightly) ![]() |
#85 |
Yup fuck the haters. They aint payin a penny to the build so their opinions means nothing.
i would suggest that you minues well go and get yourself a z32 tranny and conversion kit and run a z32 tranny so it can handle alot of abuse and not worry ... i mean it can still break but wont break as easily as an SR tranny ![]() Interested to see what your new turbo setup your gonna run to take advantage of the built bottom end. P.S: Gunk those tails n get some kouki taillights ![]() |
#87 | |
#90 |
The car got picked up to get the cage done. Was pretty excited and nevous to see the results and if it'd turn out like I hoped it would. Headed over and checking it out a few times to get progress shots. I was told I should be able to pick it up on/before the next weekend all going well! =D
Its looking very bare now without the windscreen in. I was recommended a glass guy to get my rear quarter windows out without cracking them (very tricky apparently) by a mate. They should have been taken out today so I'll bring them home for safe keeping when I go to checkout the progress. Some pics. ![]() ![]() ![]() ![]() |
