Old 11-16-2011, 10:37 PM   #1
Gription
Gription's Avatar
Gription is an unknown quantity at this point
Send a message via AIM to Gription
Question for people with extended flca's
I've got this
and I want more of this
so I'm about to do this
now my question is, will this push the top part of the wheel out more past the fenders? I'm already rubbing as it is. I know a lot of dudes are slotting the top hole on the coilover mount but my wheels are super close to my coil springs already so thats not really an option for me.
I'm wanting to get around -5 degrees without having more poke. Can anyone in here tell me the outcome of a lengthened lower control arm as far as fitment and camber goes?
Gription is offline   Reply With Quote
Old 11-16-2011, 10:39 PM   #2
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Let me ask this, are you doing this for pure aesthetics, or for performance? (although I assume aesthetics)
Old 11-16-2011, 10:44 PM   #3
Gription
Gription's Avatar
hahaha does my car look like i'm worried about aesthetics? c'mon now.
Old 11-16-2011, 10:45 PM   #4
lflkajfj12123
slot the coilover lower mount top hole that bolts the knuckle
Old 11-16-2011, 10:51 PM   #5
Gription
Gription's Avatar
already stated, but thanks for the input man.
Also, I forgot to mention I'm using s14 control arms too.
Old 11-16-2011, 11:01 PM   #6
codyace
codyace's Avatar
Trader Rating: (58)
Then why do you want -5* of camber for anything? I could only imagine the actual amount of camber gain under compression...you'll be pushing all over the place.
Lengthening the LCA will get the job done, but obviously be aware now of tie rod length, as well as Tension rod length as well (and how it can introduce a ton of caster, and bind on the inner bushing) as well (causing more suckage)
So again, are you doing this for pure aesthetics, or for performance? The short answer is that it's not gaining any performance edge...
Old 11-16-2011, 11:28 PM   #7
Gription
Gription's Avatar
More camber=more contact patch at full lock. I've got room to adjust the tie rods so I'm not worried about that, and I'm extending the arms after where the tension rod mounts so it won't have an effect on that.
Also, front camber doesn't change under compression.
Old 11-16-2011, 11:30 PM   #8
Carbomb
Carbomb is an unknown quantity at this point
do it.
its like a one time adjustment. just get it right lol.
people have done this before. on s13 tho... s14 is pretty good with s13. but you want more, get it
someone makes these and sells them already.
wider is better.
Carbomb is offline   Reply With Quote
Old 11-16-2011, 11:32 PM   #9
Carbomb
also just found this thread on some... its a good lol enjoy.
S13, S14, S15, R32, R33 extended lower control arms - Hardtuned.net
Old 11-17-2011, 12:00 AM   #10
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
This ain't Nissan road racing this is zilvia. Haha with a nice tone of voice hehe
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 11-17-2011, 01:32 AM   #11
lflkajfj12123
it is an option for you because once you run more camber you have to run a spacer to make it flush again so it moves the wheel away from the coilover
trust me i've done it on my car mine is at -7 with a 33mm spacer
also if you have s14 control arms then your camber is already at around 4.5 depending on your ride height
the picture of your car looks like 4-5
the picture you want it to be like is more like -7-8
the top of your wheel will come in towards the wheel well and give you more clearance but like i said you're gonna need spacers
Old 11-17-2011, 11:42 AM   #12
codyace
codyace's Avatar
Trader Rating: (58)
While running more camber enables more camber retention under full lock and compression, you also are now fighting some serious toe in and bump steer when doing it. Lets also not forget that when you're at full luck and your outer wheel is now got (theoretically speaking) 3 or 4* of camber vs the static of 5, your inside wheel (non loaded) is going to be loosing grip due to the massive camber...thus putting (as what I'd say) an undesirable amount of stress on the loaded wheel/tire combo...I just can't see it being helpful for any sort of performance control, regardless grip or drift. There is certainly a balance of static camber to be reached...I just think you're throwing way to much camber at a setup (especially on street tires), when you'd probably have better front grip with 2-3* of static camber.
Front camber does also change under compression, it's all relative to your control arms and how off your roll center is though. I assume at your ride height that they are probably aiming at the moon, so you're obviously going to loose camber under compression, as well as have odd toe movement as well, as regardless of the tension arm being in the same place, it's still a triangulated point and will control how the hub rotates upon compression)
Either way, bust of luck. Not trying to be a hater, just trying to make sense of it all.
Old 11-17-2011, 11:46 AM   #13
codyace
codyace's Avatar
Trader Rating: (58)
Old 11-17-2011, 11:54 AM   #14
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
First decide whether being able to drift 1% better at your local amateur parking lot event will be worth the increased attention from the police.
Old 11-17-2011, 02:21 PM   #15
fightinchunk
fightinchunk's Avatar
fightinchunk is an unknown quantity at this point
that unfortunate
fightinchunk is offline   Reply With Quote
Old 11-17-2011, 10:55 PM   #16
Gription
Gription's Avatar
Is this nico forums?
Old 11-17-2011, 11:23 PM   #17
lflkajfj12123
all of this is important...
if you are drifting in a professional series
anywhere else it really makes no difference
i mean i have a lot of camber, 205/40 on a 9j, and r33 brembos
not once have i felt while drifting i needed more front grip or while braking
also this man doesn't seem to have any problem drifting fast with -9 degrees of camber
http://www.youtube.com/watch?v=ImGVaFNihLo
Old 11-17-2011, 11:30 PM   #18
Gription
Gription's Avatar
Only pic I have right now.
Not sure where its at but its probably more than -5. whatever.
Old 11-18-2011, 06:32 AM   #19
PoorMans180SX
PoorMans180SX's Avatar
The only reason that I would run extended LCA's is so that I can flip my camber plates and use them to adjust caster.
Caster is a much more effective method of adjusting the contact patch at full lock, because it's what actually causes the high-angle "lean" in the first place.
Adjusting caster with the upper strut mount is quite different that using the tension rod.
It's all a balance. How you adjust things, camber, caster, overcentering, etc. These all have to be balanced out, no one adjustment is going to make things awesome. Try and think outside the box, think of how your suspension moves and the way you can adjust the different points of the system and how it will effect things.
The guys in Britain do it kinda backwards.
Old 11-18-2011, 09:26 AM   #20
codyace
codyace's Avatar
Trader Rating: (58)
Originally Posted by fightinchunk View Post
that unfortunate
At times, but with anything the only way to learn is to balance all of your sources and to expose yourself.
What's that supposed to mean (honestly)? DUnno if it's a situation where you don't want to learn or are just writing us (me) off as unknowing, or what (which is fine)
While I understand your point, to me it's relative; Much like the fact that you can have sex with your cousin isn't going to hurt anything, it's still wrong and should be avoided (maybe a bad example, but still the same).
TO me, even on an amature level, I'd think that users would rather sort out how their setup works, and why it works, rather than modding it in one fashion and hoping it works. Again, I'm not doubting that you couldn't do it...nor am I saying that you'll never drift ever with that much camber (as we all know you can)...my point is if you have the ability to actually modify your car, and have half a brain, why not try and 'maximize' your setup and really make it work?
I guess that's always been the confusing thing (to me) in regard to the amature and semi-am drift guys...they are quick to make a odd adjustment and live with, rather than trying to really sort it out. Not saying they are dumb or wrong for doing it that way (heck even I did that forever ago with my 240 with grip stuff) but I just don't get the point of 'living with it' when it's so easily fixed.
Old 11-18-2011, 09:56 AM   #21
slider2828
slider2828's Avatar
OMG that is a great idea.... I assume you are on a s13 chassis with S14 LCA, so the front top hats on coilovers should line up and all you need to do is turn the top hats?
If I had adjustable FLCA's like from PBM, then I would be able to adjust camber and castor on the fly and adjust the castor "more" correctly where by moving the entire suspension instead of just pivoting it but adjust the tc rods.
Is that correct?
Turn and Burn!
Old 11-18-2011, 12:58 PM   #22
PoorMans180SX
Is that correct?
That is correct good sir, but my flca's will be extended by 25mm on each side and I will be running wide fenders to compensate.
Eventually I will step up to PSM's flca.
Old 11-18-2011, 01:29 PM   #23
lflkajfj12123
@codyace
drifting isnt real motorsports well in my opinion
sliding a car around is an absurd thing to do so the absurd modifications go hand in hand
everything you said makes complete perfect sense and that is how i would modify my car if i was using it for grip racing
i understand how to maximize my car to perform but instead i'll use that knowledge to maximize my setup to look cool (there's a lot that goes into making a low car work too ya know lol)
drifting is like 75% looks and 25% driving
Old 11-18-2011, 01:49 PM   #24
slider2828
slider2828's Avatar
Sweet man.... just sweet!!!! But how do you measure accurate on how far to adjust the castor through the top hats? eye ball? bubble leveler?
Turn and Burn!
Old 11-18-2011, 02:59 PM   #25
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
there is a formula to measure caster with a camber gauge
look up the SmartCamber gauge instruction manual if you are so inclined.
Old 11-18-2011, 03:08 PM   #26
codyace
codyace's Avatar
Trader Rating: (58)
If you have a camber gauge, you can can get a semi accurate reading by doing a backyard caster sweep (15* L and R from center, take a camber reading at each and then do some subtraction or addition and some mulitplication...google it as I can't recall off top of my head).
I would love to see if there could be a way to have Mustang caster/camber plates adapted to our cars...I should really look into it as it isn't complicated, and their options are great.
Understood...I guess I often forget the looks aspect/style of drifting, namely as I'm not really involved with that side of it. TO say it's not a motorsport may be a bit hard, as I'll be the first to admit that I don't have the balls to be throwing my car sideways near a wall at speed haha...it's a skill to say the least.
However even if I was a drifter, I think i'd get nerded out with the suspension stuff....in fact I love reading some of the articles (namely the MotoIQ ones) on how they setup the cars to work well...some neat stuff in there, that all forms of car guys can enjoy.
Old 11-18-2011, 03:26 PM   #27
BOROSUN
BOROSUN's Avatar
BOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfection
stance has a caster/camber plate available.
BOROSUN is offline   Reply With Quote
Old 11-18-2011, 04:06 PM   #28
Gription
Gription's Avatar
Pretty much everything s0apgun said is on point. I kind of want to just want to make my car to where people will look at it and say "theres no way he drifts it like that". We get nerdy with suspension still, just in different ways
Old 11-18-2011, 04:44 PM   #29
slider2828
slider2828's Avatar
Interesting guys will try.
Turn and Burn!
Old 11-18-2011, 07:01 PM   #30
fckillerbee
fckillerbee's Avatar
Do what makes you happy.
Hell, if you really want to make it a challenge and have people in awe, drift with 20's on a bone stock KA. People thought it was cool to see my bone stock spinning 18 inch 26lb wheels. I was pretty low....no crazy camber though. just -4.5 degrees in the front.
