Old 11-02-2011, 10:20 PM   #31
jchrisw85
jchrisw85's Avatar
jchrisw85 is an unknown quantity at this point
ball so hard
jchrisw85 is offline   Reply With Quote
Old 11-02-2011, 10:41 PM   #32
Levan. B
Levan. B's Avatar
Levan. B is an unknown quantity at this point
Onto the rear subframe and suspension of the car..
Bolted up all of the suspension arms, spindles, Diff, Axles, and Hubs and then re-installed the subframe to the chassis.
The sway bar was put back on after this photo was taken with brand new end links and energy bushings in them.
As for the suspension arms I decided to go with ISIS, I know there is a ton of criticism on the brand, but I have ran these arms on my DD for a while now with no problems. This car is NOT a race car, I'm not trying to save weight or anything like that. That being said, I see no problem with running these arms on it aside from Heim joint noise, which could be replaced with aurora heim joints. If anything happens to them i know I have a great warranty on them.
For the Coil overs, I threw some old ISIS coil overs on the chassis for Mock up so that the car could be rollable until I remove the BC Racing BR coil overs off of my other car and install them on this one.
The BC racing BR's the day I bought them.
Front suspension, Rack, Hubs, Brake lines and brakes installed.
I went with Agency power brake lines, and some re-manufactured Z32 30mm Calipers up front. The rotors I attempted to use were 13" Brembo's but the bracket I purchased ended making the caliper too far away from the rotor. I went ahead and put the stock z32 rotors back on until I could find a solution to the problem.
Re-installed some goods into the engine bay, repainted the brake booster so it could look fresh again and cleaned up the grime on the brake/clutch lines. Also pulled the harness back up obviously.
As you may have noticed in the other photo, the gas tank was dropped. It was caved in pretty bad, and It was looking like I wasn't going to be able to replace it...
So i ended up buying a brand new OEM gas tank, Lol.
I also ran across a BRAND NEW OEM sunroof, The sunroof whistle has always peeved me... especially when I could hear it over my radio at highway speed.
I attempted to just replace the rubber on my old sunroof with an OEM seal, but it fit terribly. I think that they are vulcanized to the glass at the factory and I had no way of doing this, so I seized the opportunity and picked up the new sunroof.
I love it.
enjukuracing.com
Levan. B is offline   Reply With Quote
Old 11-02-2011, 11:51 PM   #33
project_silvia
project_silvia is an unknown quantity at this point
wish i wouldve took the time your taking with my build
project_silvia is offline   Reply With Quote
Old 11-03-2011, 01:12 AM   #34
jdmjap808
jdmjap808's Avatar
jdmjap808 is an unknown quantity at this point
Where did you get the sunroof from?
jdmjap808 is offline   Reply With Quote
Old 11-03-2011, 01:16 AM   #35
RichieSR20
RichieSR20's Avatar
RichieSR20 is an unknown quantity at this point
The bottom of your car is outstanding... This car is going to be incredible!
FWD LOL
RichieSR20 is offline   Reply With Quote
Old 11-03-2011, 03:00 AM   #36
Tempo
Tempo's Avatar
Trader Rating: (39)
Tempo is an unknown quantity at this point
Feedback Score: 39 reviews
bump +1 id like to know also lol
great build btw, love that first pic of your gold hatch, sorry to hear about it being peiced away, but you gotta do what you gotta do.
cant wait to see more
IG - allen.kerose
Tempo is offline   Reply With Quote
Old 11-03-2011, 05:44 AM   #37
PSI240SX
PSI240SX is an unknown quantity at this point
We bought the last one in existence from the dealer new along with a lot of other parts which you will soon see.
www.enjukuracing.com
PSI240SX is offline   Reply With Quote
Old 11-03-2011, 05:53 AM   #38
sky high
sky high is an unknown quantity at this point
wow this is really nice. I'm using this build as a prototype for my own hatch build.
sky high is offline   Reply With Quote
Old 11-03-2011, 08:52 AM   #39
CamryOnBronze
CamryOnBronze's Avatar
Trader Rating: (131)
CamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud of
Feedback Score: 131 reviews
Send a message via AIM to CamryOnBronze
Man, so jelly of the underside of this car and the sun roof. Awesome attention to detail!
CamryOnBronze.com
CamryOnBronze is offline   Reply With Quote
Old 11-03-2011, 09:17 AM   #40
srstan
srstan's Avatar
srstan is an unknown quantity at this point
loving it. keep up the good work
srstan is offline   Reply With Quote
Old 11-03-2011, 10:18 AM   #41
Levan. B
Levan. B's Avatar
Yep, The sunroof came directly from Nissan, And as my Father said (PSI240SX) was apparently the last one.
I miss driving that gold car already, its sitting on dollies right now.
Thanks man! Haha, I figured some of the other type X bros would get a kick out of the sunroof.
enjukuracing.com
Old 11-03-2011, 11:16 AM   #42
tricky_ab
tricky_ab's Avatar
I was thinking the same thing!
Old 11-03-2011, 11:24 AM   #43
iLagX
Trader Rating: (40)
iLagX is an unknown quantity at this point
Feedback Score: 40 reviews
Send a message via AIM to iLagX
how much did the brand new gas tank/sunroof cost you?
PARTING OUT S13/S14 NEED PARTS PM ME!
iLagX is offline   Reply With Quote
Old 11-03-2011, 12:33 PM   #44
azsr20det
azsr20det is an unknown quantity at this point
pretty sure fr sport has the tank for like 250 or something lik ethat
dunno about the roof tho
azsr20det is offline   Reply With Quote
Old 11-03-2011, 01:12 PM   #45
wacko2
wacko2's Avatar
wacko2 is making a name for him/her selfwacko2 is making a name for him/her selfwacko2 is making a name for him/her self
so wat happen to ur old s13 hatch
wacko2 is offline   Reply With Quote
Old 11-03-2011, 01:45 PM   #46
Frankz91
Frankz91's Avatar
Frankz91 is an unknown quantity at this point
Looks real clean loving the paint man.
Hopefully I'll see you dipping around some time i be out in Pomona sooner or later i'll see you.
Frankz91 is offline   Reply With Quote
Old 11-03-2011, 03:57 PM   #47
PSI240SX
We're on the opposite coast of Pomona lol. Try Florida.
Old 11-04-2011, 09:46 AM   #48
Levan. B
Levan. B's Avatar
Back on track to the body work..
I wanted to keep the stock body, and to fit the wheels I was planning on buying I would need to pull the fenders. Since I pulled the fenders on my old car, and I knew how the old battles fit compared to how the new wheels would fit by calculating the width/offset I brought out the eastwood fender roller and very carefully pulled the fenders.
Took all of those silly stripes off of the doors, and started sanding.
Taped off the area where the stock hood insulator went and sprayed some lizard skin on that too.
Then put on some coats of paint.
After filling the door with sound deadening, laid some paint on the jambs
Took some time to test the color out on a fender that was not being used on the car.
This is just single stage paint, the car will be painted in a booth with two stage.
Finally, the chassis was back on the ground again.
As for the hatch, the spoiler was already removed on it. The only thing we had to weld and smooth out was the window wiper hole. When the car goes to the painter it will have the third brake light and rear markers welded up!
Also as I forgot to mention previously we welded and smoothed out the antenna hole.
Here is another random shot of the lizard skin inside the car.
Laid some primer on the chassis and sent it off to have the front end put on a frame machine to see if it was straight, and to line up the front bumper and fenders as perfect as possible.
enjukuracing.com
Old 11-04-2011, 10:59 AM   #49
AMPZ
AMPZ's Avatar
AMPZ is an unknown quantity at this point
Sick build! Really excited about seeing this finished!
AMPZ is offline   Reply With Quote
Old 11-04-2011, 11:26 AM   #50
sky high
What did you use as sound deadening in the doors?
Old 11-04-2011, 11:54 AM   #51
alexanderig
alexanderig is an unknown quantity at this point
Build is looking really nice and I'm in love with that color. What part of Florida you in?
alexanderig is offline   Reply With Quote
Old 11-04-2011, 12:43 PM   #52
Martino
Martino's Avatar
Martino is an unknown quantity at this point
Fml, such an awesome colour. Stoked to follow this build.
IG: @vsMARTINO
Martino is offline   Reply With Quote
Old 11-04-2011, 01:11 PM   #53
Pray And Spray
Pray And Spray is an unknown quantity at this point
Love the attention, looking forward to this
Pray And Spray is offline   Reply With Quote
Old 11-04-2011, 01:12 PM   #54
killer240
killer240's Avatar
Trader Rating: (24)
killer240 is an unknown quantity at this point
Feedback Score: 24 reviews
that color is sex
killer240 is offline   Reply With Quote
Old 11-04-2011, 02:00 PM   #55
Levan. B
Levan. B's Avatar
Dynamat, covered the entire inside of the door. If you tap it sounds like its solid. I did that on my gold car and it worked great for road noise.
Thanks man! Central FL
Originally Posted by killer240 View Post
that color is sex
I'm pretty happy with it, Pictures really don't do it justice. Plus, everything that has been posted is only single stage, the two stage color on the actual body is insane looking in sunlight.
enjukuracing.com
Old 11-04-2011, 02:27 PM   #56
homeslicej2
homeslicej2's Avatar
homeslicej2 is making a name for him/her selfhomeslicej2 is making a name for him/her self
I'm enjoying seeing the stages of your build come along. What led you to use Lizard Skin over other sound deadening products? Also, why didn't you spray it inside of the doors? Seems like that would have been easier than trying to get the Dynamat laid down. I wish now I would have used a spray liner in my wife's car. Installing all of that dynamat extreme was a pain.
homeslicej2 is offline   Reply With Quote
Old 11-04-2011, 04:30 PM   #57
Riq
Riq's Avatar
Riq is an unknown quantity at this point
One of the rare fla builds being done by a person that takes pride in their car. I wish Miami wasn't so full of fail wanna be ricers. Moar builds like this are needed here. I commend you sir, keep it up.
Riq is offline   Reply With Quote
Old 11-04-2011, 05:12 PM   #58
EazyS13
EazyS13's Avatar
EazyS13 is an unknown quantity at this point
awesome build cant wait for the final product. thumbs up for doin things right!!
EazyS13 is offline   Reply With Quote
Old 11-04-2011, 05:14 PM   #59
alexanderig
do you attend any of the local events at CFRC? i live in miami but would love to see this car when it gets done in person lol
Old 11-04-2011, 05:22 PM   #60
Levan. B
Levan. B's Avatar
Glad to hear man. The reason I used the lizard skin in the interior over the dynamat is because it is much easier to cover that much space with it, its a very thin coat, and it's much less expensive than trying to cover the whole car with dynamat. The inside of the door had a coat of lizard skin and dynamat, just to try to get it as quiet as possible.
Yeah, its definitely annoying.
enjukuracing.com
