10-18-2011, 09:47 PM | #8191 |
when i installed my kouki tail lights sort of same thing happened. no blinkers, headlights on, only on the rear signal works but very dim and the right rear goes off when i hit the brakes.
i checked everything, it was the posi-taps i used for wiring there was something wrong with it maybe creating resistance. i fixed it by soldering the wires. so checks the tail light wires,ground and such. |
10-18-2011, 10:21 PM | #8192 |
My brake lights dont turn on when i engage the pedal. But the all the lights turn on. I just checked the power to all the fuses and the second to last one size 10 fuse which is for the stop signal isnt getting power. Is the wiring burned out?
http://thatistupid.tumblr.com/ |
10-18-2011, 10:50 PM | #8193 |
do a continuity test, see if there is a connection. Fuses blown don't always mean a short but there is a greater reason to them blowing. Briefly try jumping the connection, use a small wire as a fuse and see if they work, if so replace the fuse and see whats up. or cut to the chase and find out what caused it to blow (harder than it seems)
street dancer. GLEAM |
10-18-2011, 10:52 PM | #8194 |
Anyone know the torque specs, if there are any, for the z32 brake caliper bolts? Rebuilding them soon and couldn't find anything from the Tutorial threads (Rexbo, nicoclub, blah blah blah)
As well as, how come some sell the kit for $100+ and z1motorsports sells it for 44$ for both front and rear? Is there a knock-off rebuild kit, lol
10-18-2011, 10:53 PM | #8195 | |
10-18-2011, 11:26 PM | #8196 |
Anyone know off the top of their head if there's any radiator hose that, instead of going straight across like a ka, goes from left to right? I've got a Griffin radiator but it's not for a KA, just need something that looks proper that can be picked up locally. It'd obviously need similar dimensions.
10-19-2011, 12:26 AM | #8197 | |
straights are for fast cars, corners are for fast drivers. |
10-19-2011, 07:37 PM | #8199 |
Thinking about doing a T25 turbo set up on me dual cam KA. I think I want to run somewhere around 10lbs of boost on stock internals. I was wondering if I'd need bigger injectors for that. Also, what is a good cheap FMIC for a KA-T? And last but not least, what is a good decently priced top mount manifold?
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
10-19-2011, 07:55 PM | #8200 |
I'm sitting here reading Turbonetics turbo installation manual, and it says something about tightening compressor and turbine bolts after re-orientation? Does anyone know anything about this?
10-19-2011, 08:27 PM | #8201 |
PLEASE PLEASE PLEASE HELP.
Alright so I have an s14 zenki with an s13 sr but my windshield wipers don't work. I do have the motor but the little thats suppose to be connected isn't their and nothing is connected to the motor. So I wanted to know wat do I need to get my windshield wipers to work and how do I go about it??? thanks |
10-19-2011, 08:33 PM | #8202 |
So, lowered the rear of my car about an inch today. Rubs over bumps, even the small ones. Pretty sure I know the answer to this, but to avoid this am I just going to have to add in more negative camber? Any other tips on how to make this shit not rub so much?
Edit: For reference I'm on coilovers. 18x9.5 +12, 225/40s in the rear. Fenders are rolled, I'm sure I could roll/pull them some more. Either that or more camber, yeh? |
10-19-2011, 09:30 PM | #8206 |
does anyone have info on the panel that's on the quarter glass? trying to achieve a 2 tone scheme to have my hatch resemble a coupe without it looking awkward, like this: |
10-19-2011, 09:37 PM | #8207 |
Anyone know how much a 1986 Bmw 535i with about 132,000 miles will go for. It runs, I'm getting it soon for my first car. Its just sitting in my drive way til i get my license. I'm thinking of selling it, to get a good stock 240sx.
10-19-2011, 09:56 PM | #8208 | ||||||
Trader Rating: (58)
Feedback Score: 58 reviews
http://www.imperialsupplies.com/pdf/...rqueCharts.pdf Quote:
..and with that said, if this is your daily driver, and you don't have much experience, and you don't have reliable backup transporation, that you should rethink the setup until you can attain at least experience or reliable backup wheels (whether your own, or a parents, or something) Quote:
Let me google that for you That panel looks like trash, and was probably homebuilt.
10-19-2011, 10:17 PM | #8209 |
As in, loosen the bolts that hold the backing plate on and the equivalent for the turbine? I was under the impression not to remove those. But isn't the exhaust and intercooler piping dependent on the turbo being where how it sits?
10-19-2011, 10:58 PM | #8210 | |
Those panels will only make it look worse, Like a 2tone z32
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
10-20-2011, 12:19 AM | #8211 | |
As far as the kit, i guess i'll just call them cause the price changes from 12$ to 44$ if you choose the "front and rear" package
10-20-2011, 08:15 AM | #8212 |
can anyone tell me the correct way to check a 96 KA tps with the two plugs? also if anyone can post up some info on how to get a ka to idle decent without having the iacv hooked up. i didn't get a nipple made when i did my pipping & dont have a welder.
thanks |
10-20-2011, 10:41 AM | #8213 |
Just bought some CDTRL's from a local. I was wondering if anyone else who has cdtrl's could tell me if something is missing? Also where can i get the replacement screws tha go through the housing? the skinny tall one. |
10-20-2011, 12:37 PM | #8215 |
I will probably be the first one to make most zivilians change their minds about 2 tone hatches I'm going beyond just a 2tone s13 hatch. I'm going all out s13.4 front-rear, supermade kit + rb spoiler. Just looking to make the lines of the quarter window flow better..
10-20-2011, 01:59 PM | #8217 |
i have a 1995 nissan 240sx i just bought, it has an srdet20 swap in it, the mass air flow sensor went out, it is a three pin, all the ones at the stores around here are four and look way diff,
do any of you guys have one for sale or know were i can get one around here? email me at [email protected] |
10-20-2011, 03:58 PM | #8218 |
i gotta quick question for you guys im putting a painless wiring harness in my car and am trying to figure out whether i should wire a relay into the turn signal. do you think its necessary? the painless Manuel doesn't say anything about it and cant seem to find the answer searching.
89 2tone coupe 2jzgte swap in progress |
10-20-2011, 06:13 PM | #8219 |
10-20-2011, 07:41 PM | #8220 |
Trader Rating: (42)
Feedback Score: 42 reviews
Okay guys I have two questions
#1 I have two s13 diff covers. But they are different. What is the difference? Or should I say why are they different. Both drain plugs are in the same spot. But the check/fills are not Here is the first Now this is the one that is different See now this one has the check and film on the drivers side Now question number two. I'm waiting for my PBM solid risers to come in. But I'm wondering did I do this right? Or did I remove too much? All four of them are bore like this. No lips. Help? |
