![]() Join Date: Jul 2005
Trader Rating: (145)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 145 reviews
![]() Check out my Feedback or Trader Rating
Located in Garden Grove, CA. 92843. Email - [email protected] AIM - audiovideocentra My other threads:
Price does NOT include shipping and shipping is not free. Please add 3% for PayPal or send as gift. NO trades b/c CASH is KING. * For instant respond, reply to this thread since it will forward to my cell. Here are the last of my 240 parts I have left. The majority of the performance parts were purchased new from either phase2motortrend.com or frsport.com. Some parts looks dirty but still in great shape with minimal miles on them. I will clean them prior to shipping. This is a rough draft of my for sale thread. I will update this ad frequently and will be adding more parts. Now onto the parts... * saved for the heart
i have engine hoist for rent i do SR wiring Last edited by vutony; 09-20-2011 at 10:47 PM.. |
![]() I have 4 S13 SR20DET transmission available. Three of them are in great shape and 100% functional. NO leaks or noise/grind. $250 each ![]() The far left trans sold as parts, lmk what you need from it....shifter plate, bell housing, sensors, etc. Sorry I sold all the speed sensors. ![]() S13/S14 SR20DET Toda Flywheel - $300 ($525 @ Phase2motortrend.com) - Used only for about 3,000 miles - In good shape and work perfectly (made 350ish HP) - 4 flywheel bolts hole area was slightly shaved off to removed stripped bolts - I had no problem with it installed (drifted and dyno'd with) - I also have flywheel bolts for $30 ![]() ![]() ![]() ![]() S13/S14 SR20DET RPS Max Street Clutch - $300 ($415 @ Phase2motortrend.com) - Used for about 10,000 miles - Still has a lot of meat left on disc - In good shape and 100% functional (made 350ish HP) - Comes with pressure plate bolts ![]() - In good shape and 100% functional (made 350ish HP) ![]() ![]() SR dust cover - $40 - Its cut at the top (12 o'clock) b/c I didnt want to remove the flywheel which does not affect anything. ![]()
i have engine hoist for rent i do SR wiring Last edited by vutony; 09-26-2011 at 10:18 AM.. |
#3 | |
Full Race Pro Stock Manifold - $850 ($1000 @ fullrace.com but now discontinued so RARE piece now)
- The best bottom mount turbo for SR - Used but in great shape w/ about 5,000 miles - Its thermal coated at Olympics coating in San Diego (cost $140) ![]() ![]() ![]() S13 SR20DET Tomei 3" elbow - $150 - Used but in great shape w/ about 5,000 miles - Its thermal coated at Olympics coating in San Diego (cost $60) ![]() ![]() ![]() OEM S13/S14/S15 SR20DET O2 Sensor - $60 (FAT type) Quote:
![]() S13 SR20DET Pro Fab Design Intake Manifold Gasket - $25 ($50 @ Phase2motortrend.com) S13/S14 SR20DET 7 Layers Metal Exhaust Manifold Gasket - SOLD ![]()
i have engine hoist for rent i do SR wiring Last edited by vutony; 10-12-2011 at 11:28 PM.. |
Tomei/N15 TB 70mm throttle body - $450 ($575 @ Phase2motortrend.com)
- Used but in great shape w/ about 3,000 miles - Comes with Tomei adapter, N15 TB and hardware - S14 TPS not included, $70 extra - Also have matching 3" custom one piece cold pipe, $100 extra ![]() ![]() ![]() S14 SR20DET TPS - $70 ($95 @ Phase2motortrend.com) - Used only for about 1,500 miles - Perfect fitment compared to S13 TPS ![]() Nismo/Tomei 740cc Fuel Injectors - $550 ($685-765 @ FRsport.com) - Used only for about 3,000 miles - They are in excellent shape - Comes with 0-rings ![]() ![]() ![]() Nismo Fuel Pressure Regulator Type-B - $100 - Used but in great shape w/ about 3,000 miles ![]() OEM S13 SR20DET Fuel Rail - $50 - Used but in great shape w/ about 3,000 miles - Comes with fitting for universal FPR ![]() ![]()
i have engine hoist for rent i do SR wiring Last edited by vutony; 10-24-2011 at 12:34 PM.. |
S13/14/15 ARC Oversize Oil Pan - $300
- Used but in excellent shape w/ about 3,000 miles ![]() ![]() ![]() S13 SR20DET coil pack harness - SOLD S13 SR20DET coil packs - $30 each (2 of 4 sold) - 100% functional, no timing issue - NO cracks around the coils body - I switched back to stock since Splitfire kept cutting out at high RPMs ![]() ![]() S13 SR20DET alternator - $SOLD S13 SR20DET alternator bracket and hardware - $40 ![]() S13 SR20DET CAS - $110 - Used but 100% functional ![]() S13 SR20DET dipstick w/ tube - $30 S13 SR20DET water inlet and outlet - $20 each SR20DET coolant sensors - $20 ![]() S13 SR20DET stock oil sandwich block - $60 S13 SR20DET hard coolant pipes/lines - $30 ![]() S13 stock motor mounts - $30 - Used, did the job w/ my setup - They have polyurethane filled in ![]() SOLD S13 SR20DET knock sensor w harness S13 SR20DET coil pack harness S13/S14 SR20DET 7 Layers Metal Exhaust Manifold Gasket S13 SR20DET motor mount brackets S13 SR20DET Megan Racing Pulley Set S13 SR20DET starter Garrett GT2871R Ball Bearing Turbo w/ HKS actuator S13 SR20DET TAKA Turbo Lines S13 SR20DET alternator S13 SR20DET AAC Valve S13 SR20DET PS pump S13 SR20DET PS bracket and hardware S13 SR20DET Greddy Intake Manifold
SOLD
i have engine hoist for rent i do SR wiring Last edited by vutony; 10-05-2011 at 02:56 PM.. |
![]() Join Date: Jan 2008
How much for the braided SS line from the crank case to valve cover.
My Twin Scroll Gt30r Sr22det Build |
#14 |
crankcase breather ss line sold to me
#15 |
what can u do on the ps pump shipped, paypaled etc. to 29630
#22 | |||||
PM'd
PM'd I have a built long block I used with all these goodies. PM me if interested. Quote:
i have engine hoist for rent i do SR wiring |
#25 | |
I rather not part so price is the same
