Old 09-12-2011, 08:59 AM   #7651
Zenki_516
Zenki_516's Avatar
Trader Rating: (30)
Zenki_516 is an unknown quantity at this point
Feedback Score: 30 reviews
Originally Posted by JDM SPUG View Post
Does anybody have any experience with powered by max RUCAS on an S14?
What about them?
Still Thug.
Originally Posted by ka-titties View Post
i'm from Florida so i'm retarded....
Zenki_516 is offline   Reply With Quote
Old 09-12-2011, 09:12 AM   #7652
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Originally Posted by 2stepGoesPowPow View Post
How hard is it to convert my RPS13 to external wastegate? Do i just look for an aftermarket exhaust manifold with a flange for a wastegate, and buy whatever mm wastegate the flange is? Then how do i manage the wastegate spring vs the PSI i run?
It's easy it just takes time and some money.
By a wastegate with a vband flange, send your oem manifold in with the flange to have it welded on, then put it on.
When you buy the wastegate they have different options for the springs/psi. Tial MVS 38mm are great for the oem manifold. They are tiny, compared to other wastegates.
Edit, don't forget to weld the internal gate shut Haha.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 09-12-2011, 09:27 AM   #7653
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Originally Posted by JaeTea View Post
Do you have to loose the bottom pivot bolt on the alternator to tighten the belt?
What is the exact procedure for tightening the alternator belt? (talk to me like I'm an 8 yr old)
Yes you'll need to loosen that, and then on the side of the bracket you'll need to loosen the nut on front, and trun the long bolt on the side of it to tension it. Lock in the little (is it 12mm or 14mm i can't recall) set nut and then retighten the large one.
Originally Posted by towlie View Post
How do I bleed r33 front calipers?
Searched (obviously) but couldn't find any how to results i need
Here's the bleeder (I believe)
Does it just pop/screw off?? would try
but I'm scared of breaking it
Cut/take that little rubber cover off, and then access the bleeder.
Originally Posted by harrypotter View Post
This is a page that should have been written a long time ago.* The e-brake is the most difficult element of the entire brake swap and require more time and research to try and figure out the best solution.* Unfortunately, this page is going to revolve around suggestions rather than a definite solution.
I'll admit, that was a pretty good answer to ChiBoy's attempt at trolling, as he obviously didn't know how to do it either (the issue with forum coolguys is that they blab without knowing, so props to you for calling his shit out)
With that said, I don't have any experience doing the R32 setup, but the E brakes are kinda clunky for sure. If you do find out let a moderator know so they could update a faq as more solid info is what this place needs for sure.
To run it on your stock manifold, you'll need to have it welded on. I got mine done at JPC Fabrication as have some others. 100 dollars, and no more stupid boost issues. PM me if you need more info.
Many do, what is your question?
Old 09-12-2011, 09:11 PM   #7654
towlie
Aha, it's just a condom
Thanks good sir!
Old 09-13-2011, 12:35 AM   #7655
jdmjap808
jdmjap808's Avatar
jdmjap808 is an unknown quantity at this point
Im getting new rotors and im wondering what is better for track and drifting, drilled and slotted or dimpled and slotted? Also are password jdm rotors any good?
jdmjap808 is offline   Reply With Quote
Old 09-13-2011, 01:28 AM   #7656
BOROSUN
BOROSUN's Avatar
BOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfection
j hooks rotors.
that or blanks with hawks or porterfield would be better.
BOROSUN is offline   Reply With Quote
Old 09-13-2011, 04:19 AM   #7657
JaeTea
JaeTea's Avatar
JaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really niceJaeTea is just really nice
Send a message via AIM to JaeTea
Have a belt squeal on start up. It also does it if I turn on the heater and the lights or the rear defroster with the lights or the heater with the rear defroster.
Went and tightened the alternator belt and the squealing got ALOT worse and lasted longer. Plus the alternator pulley was burning hot.
I'm lost.
JaeTea is offline   Reply With Quote
Old 09-13-2011, 09:53 AM   #7658
sr20sean
sr20sean's Avatar
Trader Rating: (25)
sr20sean is an unknown quantity at this point
Feedback Score: 25 reviews
Send a message via AIM to sr20sean
I'm lost.
check your alternator. the pulley shouldnt be that hot.
TLDR
Cliff notes: Florida
sr20sean is offline   Reply With Quote
Old 09-13-2011, 06:27 PM   #7659
chiboy002
chiboy002 is an unknown quantity at this point
I'm lost.
seems like a slipping belt is causing the pulley to heat up from friction
street dancer.
GLEAM
Old 09-13-2011, 07:00 PM   #7660
anton1o
anton1o's Avatar
anton1o is an unknown quantity at this point
Send a message via MSN to anton1o
Originally Posted by chiboy002 View Post
wtf is a globe
i have those markers so i can tell you the light bulb sizes.. idk about globes
haha sorry, a Light Globe = Light Bulb.
So yes if you could get me the light bulb size that would be great as i would love to get the right type!
anton1o is offline   Reply With Quote
Old 09-13-2011, 07:04 PM   #7661
frsh4
frsh4's Avatar
frsh4 is an unknown quantity at this point
Why do my gauge light and left turn signal, turn on when i step on the brakes? Lights are off. S13 BTW.
http://thatistupid.tumblr.com/
frsh4 is offline   Reply With Quote
Old 09-13-2011, 09:04 PM   #7662
hartig
hartig is an unknown quantity at this point
is it a terrible idea to make my own gasket for my turbo inlet/outlet? t25 on a redtop.. i have this gray gasket maker material and i'm just wondering if its worth using, or if i should get some gaskets from a 300zx.. obviously i'd rather not spend money if i dont have to
hartig is offline   Reply With Quote
Old 09-13-2011, 09:10 PM   #7663
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Do you NEED a T28 clocking kit to run a t28 on a S13 SR?
SLiDe_WaYz is offline   Reply With Quote
Old 09-13-2011, 09:12 PM   #7664
codyace
codyace's Avatar
Trader Rating: (58)
just get the cheapest rotors you can, that are solid and vented. no need for cross drill or slots
Old 09-13-2011, 09:16 PM   #7665
S14DB
AFC #1
S14DB's Avatar
Yes.
Old 09-13-2011, 10:21 PM   #7666
SLiDe_WaYz
SLiDe_WaYz's Avatar
I know what it looks like lol, I just didnt want to fork out 150$ for the kit if it wasn't necessarily needed.
Old 09-13-2011, 11:09 PM   #7667
sr20sean
sr20sean's Avatar
Trader Rating: (25)
if youre talking about that silicone stuff DO NOT use it. if it's the fiber material it will work as long as it has a metal center. the other shit will just burn up. that metal sheet sandwiched in between the 2 fiber layers is important for high heat.
if you have access to machining tools or have the dimensions ready then you shouldnt have a hard time getting a machine shop to make one for you.
TLDR
Old 09-14-2011, 12:38 AM   #7668
sr20sean
sr20sean's Avatar
Trader Rating: (25)
does the signal wire for the maf go TO the ecu or does it come FROM the ecu?
not sure if i should check at the maf or right near the ecu to make sure the wiring is ok.
TLDR
Old 09-14-2011, 04:53 AM   #7669
SLiDe_WaYz
SLiDe_WaYz's Avatar
Anyone happen to have the dimensions ? I can head to a shop today for one to be made.
Old 09-14-2011, 07:51 AM   #7670
codyace
codyace's Avatar
Trader Rating: (58)
Maf has Power/Ground/Signal. The wire connects from MAF to the ECU, but it's the maf that is sending the signal to the ecu.
EC section, FSM.
I'd sooner just buy it to have it done, then buy the material, setting up the machine cutting it etc etc. Unless it's ALL free
Old 09-14-2011, 12:01 PM   #7671
JaeTea
JaeTea's Avatar
Got a tranny fluid leak where the transmission meets the engine block.
Is this an easy fix or something I'm gonna just have to deal with.
Old 09-14-2011, 12:59 PM   #7672
Wake
Wake's Avatar
Is dropping your tranny easy to you?
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 09-14-2011, 03:27 PM   #7673
codyace
codyace's Avatar
Trader Rating: (58)
It all depends on your care level
Aside from the rear valve cover leaking, any other fix requires dropping the transmission.
Old 09-14-2011, 07:08 PM   #7674
Lukasss
Lukasss's Avatar
Lukasss is an unknown quantity at this point
Found the answer myself lol
Lukasss is offline   Reply With Quote
Old 09-14-2011, 08:04 PM   #7675
ryandriftingfat
ryandriftingfat is an unknown quantity at this point
Anybody know the thread pitch and depth of the bleeder screw for an OEM S13 clutch slave cylinder? I don't have one handy to measure.
Thanks.
ryandriftingfat is offline   Reply With Quote
Old 09-15-2011, 03:38 AM   #7676
Prime
Prime's Avatar
Prime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the roughPrime is a jewel in the rough
Looks like someone dropped my intake manifold off the workbench. Dent in the side, and the rise from it is on the mating surface. Hit it with the dremel and a good flat block with 400 grit. This is on the upper plenum where the runners bolt to the lower. Looks good to me, but I do have a spare.
Swap or trust the gasket to seal?
Prime is offline   Reply With Quote
Old 09-15-2011, 12:42 PM   #7677
mvang44
mvang44 is an unknown quantity at this point
Q's: Type Xspoilers!<----
I have seen the 180sx type X spoiler but recently seen a hatch with a bigger on?,is there actually a big one? anyone knows where to find a big type x spoiler for the 180sx? If so get back at me! need more info, tell me what you know!
mvang44 is offline   Reply With Quote
Old 09-15-2011, 12:52 PM   #7678
hartig
if you have a spare one, why not just swap it for your own sake? no point taking the manifold off twice
Old 09-15-2011, 01:05 PM   #7679
Prime
Prime's Avatar
I was gasket matching it. I don't want to redo the work. But better safe than sorry in this case, I guess.
Old 09-15-2011, 02:57 PM   #7680
Jonathong
Jonathong's Avatar
Jonathong is an unknown quantity at this point
Was wondering how he got his winshield wiper like that? did he just remove one and put a bigger wiper blade?
Jonathong is offline   Reply With Quote
