![]() I am moving to Boston in 1 week and I can only have one car. NO TRADES, I need money not another car. I didn't want to sell it but I have to.
**I HAVE HAD THE CAR FOR ABOUT 3 YEARS AND I HAVE HAD THE NEW MOTOR IN FOR ABOUT 1.5 YEARS. I have put about 10k miles on it, not one problem! **IT'S THE BEST, MOST RELIABLE CAR I HAVE EVER OWNED.*** ***I AM MOVING TO BOSTON ON SATURDAY AND I NEED THE CASH*** ***$3,800*** ***THE PRICE IS FIRM*** *ENGINE* -Blacktop SR20DET from a 1998 180sx type-X. (75,000 miles, re-sealed all the gaskets, replaced the belts, thermostat, water pump, power steering hoses from Nissan) -New spark plugs NGK-PFR6B-11 -Front mount intercooler with custom made stainless steel mounting plate -Old school Blitz blow-off valve (It was the only modification to the motor when it arrived from Japan.) -WALBRO fuel pump with new fuel hoses + 300zx fuel filter -Circuit Sports Aluminum Coolant Reservoir -MEGAN 3" Test Pipe -MEGAN 3" Down Pipe -3" Cat-Back Exhaust -New Altima fans (NOT INSTALLED) *TRANSMISSION* -SPEC clutch kit stage 2+ -New clutch master cylinder & slave cylinder -New clutch hose -New clutch pedal bushings -Aluminum Pedals -Clutch pedal switch is by-passed -Clutch damper has been by-passed *300ZX BRAKE CONVERSION (FRONT ONLY)* -New 300ZX aluminum 30mm brake calipers + brake pads -Stainless steel conversion brake lines (coated in blue) -New Brembo 300ZX brake rotors -New tokico brake master cylinder adapted for non-ABS -ATE Super Blue brake fluid (brakes & clutch) *SUSPENSION* -KYB GR-2 struts and shocks -KYB upper shock mounts, front & rear -TEIN S. Tech springs -SPC front tension struts (adjustable) -SPC rear toe links (adjustable) -SPC rear upper control arms (adjustable) -SPC rear camber arms (adjustable) -New inner and outer tie rods -New front control arms with new ball joints -Energy Suspension front sway bar bushings & end links -4 Wheel Alignment was performed by me 3 months ago. *BODY* -Hella H4 headlight conversion -New MT-51R Interstate Battery(3/11/11) + Custom battery hold-down -New headlight switch -New ignition switch -Autometer Boost Gauge + Single Gauge A-pillar pod -New driver door jamb switch -EVO wiper blades -2 new Pioneer 6.5 speakers -Pioneer CD player -Custom made stainless steel front speaker adapters -Sleepy eye mod -Both front seats were removed, disassembled, and the cushions were swapped from the driver's side to the passengers side. -BMW Z4 floor mats -All new instrument cluster bulbs *WHEELS & TIRES* -Rota Grid 17x9 (+12 offset) 4x114.3 Hyper Black. (The 4 lug have to be special ordered){RARE} -Front: Michelin Pilot Sport PS2 225/45/17 {85-90% of the tread} -Rear: General Exclaim UHP 235/45/17 {75% of the tread} ***ALL THE WORK WAS DONE BY ME INCLUDING THE MOTOR SWAP AND THE ALIGNMENT(ON THE NEW HUNTER HAWK-EYE MACHINE)*** **I have receipts for 90% of the purchases.** EMAIL OR CALL ME, I CAN SHOW THE CAR ANYTIME @ two one zero eight five seven eight eight six zero Last edited by buzzbomz1; 07-27-2011 at 07:02 AM.. Reason: Updated the new lower price. |
![]() I have dropped the price because I move in 4 days and I need the money to live and eat for the first 2 months. This is the time to get "One of those deals" that I wish I found. *$3,800 firm.*
#11 | ||
460
240sx, for sale, nissan |
