05-16-2011, 07:22 AM | #182 |
Yeah, glad they took care of you (or at least I hoped they hooked you up with the missing parts). Progress is looking real nice.
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
05-16-2011, 05:57 PM | #183 |
Thanx mate, yeah wisesquare is nice believe it or not it's one of only two in OZ.
Yeah Eric just happen to come across my NS build thread and noticed that there were missing part. Great thumb up for their after sale service. |
05-29-2011, 03:14 AM | #184 |
Not a big update but today we're able to finish the tubs and seam welding of the engine bay. Next time we'll bog the welds to make them look nicer plus degrease and prep the engine bay for painting.
And here some more parts that we collected. Relocation blocks Adapter plate for the intake plenum and throttle body, this also allow for the change in position of the throttle cable from the Mazworx original position. Twin 044 fuel pumps And currently waiting on these Heat shielding GT carbon mirror and carbon replacement plate Origin front under canard, but I will mod it to complement the feed sidestep |
06-11-2011, 05:12 AM | #185 |
Not much to update since both of us has been busy, hopefully stuck into it again next weekend.
Here some more parts' pics. Earl's oil and power steering coolers. Earl's Thermostat 90 degree elbow for the rocker cover |
07-10-2011, 12:11 AM | #186 |
So a few bit and pieces done since the last update.
Finished with the engine bay respray, look real nice for a backyard job lol. Heat shield, wiper motor, clutch and brake back on...heat shielding is a bitch of a job, the material doesn't stretch at all. The trick to it if anyone else contemplating is to do it in smaller segments. Oh well as long as it do it job. Clutch back on Oil dipstick Relocation block Origin carbon canards Gutted interior...there won't be much going back in. Originally just to remove the heater unit, but ended up removing most stuff just to get it out. I rather like these thing...allen bolts a neat touch. We be replacing most of them with stainless items. |
07-10-2011, 01:02 AM | #189 |
Thanks guys, it won't be long before the engine is in. But probably still a good few months before it's running again, at least we can see the light at the end of the tunnel.
07-24-2011, 10:50 PM | #197 |
Progress is looking excellent!
BRICKHOUSE PRODUCTS
08-08-2011, 02:20 PM | #200 |
that engine makes me want to end myself
cONtRol FReAkS |
08-10-2011, 07:40 AM | #202 |
all things considered,...its a good thing....lol
cONtRol FReAkS |
08-15-2011, 06:47 AM | #203 |
So it has been awhile since the last update...recently Taark sent me these progress pics.
Fuel cell Fuel line bulk heads Fuel lines Fuel return line Holley lift pump for the surge tank FPR mounted Reroute the turbo lines so they look neater. Turbo oil drain Modified Mazworx fuel rail for twin entries with centre return outlet. IACV Solenoids mounted. Throttle body with adapter plate to reroute the cable. Braided clutch line Engine rocker cover with stainless fittings |
08-16-2011, 03:46 AM | #207 | ||
If you're talking about the exhaust manifold then it's a 6boost T3 twinscroll. |
