Old 01-12-2011, 05:53 PM   #1711
240sxrb25
240sxrb25 is an unknown quantity at this point
um about 3 degrees everywhere.
Front 17x9 +12 235 40
Rear 17x9.5 +12 275 40
240sxrb25 is offline   Reply With Quote
Old 01-12-2011, 05:55 PM   #1712
mikerbike
mikerbike is an unknown quantity at this point
Edit: FOR Mad-ass..
Just set up your car a little different then. I use 205/45/17F and 245/40/17R with my N/A KA. No more understeer, just less oversteer.
Pretty sure Powers used 235/40/17F and 275/35/18R at Infineon this year. Pretty sure.
mikerbike is offline   Reply With Quote
Old 01-12-2011, 06:07 PM   #1713
simmode1
simmode1's Avatar
Phenomenal. Thanks!
Old 01-13-2011, 12:26 AM   #1714
mad-ass
mad-ass's Avatar
I have my car setup pretty durn good at the moment with the tire sizes, don't see anything wrong with them, just that I gotta prepare my car to accept the power of LS1 swap here soon and want to put down more tires then I am right now, at least rear camber wise. since I didn't even think about balancing out the tire width front to rear at all, this changes everything! lol
then again, GTO's stock come 235/40/18 all around, and that's LS2/400hp on tap, so I think 255 in the rear with almost no camber will do good!
Old 01-13-2011, 03:15 AM   #1715
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
If you're concerned about grip and balance you may want to check out Nissan Road Racing Forums - Powered by vBulletin.
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 01-13-2011, 06:33 AM   #1716
greddy2die
greddy2die's Avatar
greddy2die is an unknown quantity at this point
Send a message via AIM to greddy2die
Ive got a full bolt on + cam LS1 in my S14, close to 400whp and im running 255/40/17 Hankook RS3's out back. I love them, they provide excellent grip and ive had a few friends drive my car this past weekend and they agreed also. I do get wheel spin if i mash the pedal off the line or throw 2nd real quick but thats expected. It is very controllable though, not just insane spinning. hope you understand lol
btw im running 255/40 all around on 17x9 +22 advan rgII's. 1.5* camber up front and 0.8* camber out back.
Sorry, pic isnt the best angle =/
greddy2die is offline   Reply With Quote
Old 01-13-2011, 08:07 AM   #1717
longfellow
longfellow's Avatar
longfellow is an unknown quantity at this point
I deff don't want the car to under steer, that's a no no! haha.
i'll stick with 235/40/18 on 18x9.5+15 in front and 255/35/18 on 18x10+38 then.
I did have 255/40/17's on the rear before my 245/40's and didn't feel much difference as far as grip was, but then again, i do have almost -4 degrees of camber so i'm maybe using 60% of the tire thread patch.
Thanks for all the info guys. will keep you posted.
235/255 set up will work pretty nicely, I had it on my red car and loved it, front end was light but sharp and the rear had plenty of grip. If you run under -2*camber you'll be very happy with the results. Also look into changing your traction rod length to 8.5" for a better toe curve during suspension compression, it will further improve traction.
longfellow is offline   Reply With Quote
Old 01-13-2011, 10:12 AM   #1718
Melo_speed
Melo_speed's Avatar
Melo_speed is an unknown quantity at this point
Need help planning on getting 17" or 18" f9/r10, what would be a good offset and tire size for a s14 want alot of grip as im going to put in a 2jz.
s14 grip monster=2011-2012
Melo_speed is offline   Reply With Quote
Old 01-13-2011, 03:11 PM   #1719
simmode1
simmode1's Avatar
Personally, I'd go with +20 all around with 245(f) and 265(r).
Old 01-18-2011, 06:52 PM   #1720
Nick_04K
Nick_04K's Avatar
Nick_04K is an unknown quantity at this point
I would go with 18x9 up front in the +17 to 25 range.
For rears would go 18x10 +25 to 35
This all depends on how much tire you want and your motorsport though. Obviously if you want 285's or some shit in the rear (drag oriented setup) you dont want to go with 18x10 +25 in the rear...That would require enough camber to lose effectiveness.
However if your going for a grip/road course type oriented setup more camber would be acceptable and still remain useful.
Nick_04K is offline   Reply With Quote
Old 01-18-2011, 07:54 PM   #1721
kingkilburn
Philosopher King
Originally Posted by Nick_04K View Post
^ umm sorry...But fuck no.
LOL at rude 16 year old talking out of his ass.
Old 01-18-2011, 09:22 PM   #1722
simmode1
simmode1's Avatar
^^^Man, seriously. Straight out his ass. Both setups can work though... His just isn't what I'd do. Do his setup if you're scared of rear fender work, I guess. You might get lucky if you go with his 17x9+25 up front and it just barely clears your coilovers, but probably not.
Old 01-18-2011, 11:11 PM   #1723
MJenkins1101
MJenkins1101 is an unknown quantity at this point
Ok I guess this is the best place to ask? So I am running 17x9 +12 F and 17x9.5 +12 R so here is my question are 235/40 and 255/45 good sizes to run on a stock bodied S13?
MJenkins1101 is offline   Reply With Quote
Old 01-18-2011, 11:15 PM   #1724
kyles1988
kyles1988's Avatar
kyles1988 is an unknown quantity at this point
I've run a 17x9 +30 on the front of my s13 with coilovers (R33 wheels) and it cleared fine.
kyles1988 is offline   Reply With Quote
Old 01-18-2011, 11:33 PM   #1725
mikerbike
Probably not.
Online Wheel & Tyre Fitment calculator. Offset and Tyre Stretch
255/45 is really tall. Try 255/40 on the rear. /suggestion
Old 01-18-2011, 11:52 PM   #1726
MJenkins1101
Originally Posted by mikerbike View Post
Probably not.
Oh wow thats awesome, thank you I appreciate the quick response.
Old 01-19-2011, 02:05 AM   #1727
BustedS13
BustedS13's Avatar
i remember being this kid. dammit
Old 01-19-2011, 08:40 AM   #1728
simmode1
simmode1's Avatar
And that's great for you. Ppl just need to realize that not all coilovers are made with the same amount of backspace. I've seen 17x9+25 P45R's barely clear on s13's with coilover's like Megans. The same thing with 17x9+22 RPF1's on an s14 with Stance's. I'm talking they cleared with like 2mm of space... so little that both owners decided to get slip on spacers anyway beceause it was sooo uncomfortably close.
Like I said, you might get lucky, if you picked a coilover that has more backspace than most. Don't run around telling folks that 17x9+30 will CERTAINLY clear coilovers, because in alot of case, it won't. But +20 certainly will.
Probably not.
I totally agree. 17x9+12 with 235/40 (f) and 17x9.5+12 (r) with 255/40 is a great setup, IMO. Still gonna need some camber and fender pulling in the rear though, but go for it!
Old 01-19-2011, 09:23 AM   #1729
Melo_speed
Melo_speed's Avatar
The reason why i was asking is because i want something like J-rho's S13 those tires were massive and the car handled mint imo.
Old 01-19-2011, 06:02 PM   #1730
simmode1
simmode1's Avatar
Was just poking through Rimtuck setups and found yours...
RIMTUCK.com - Setup
I think it looks great. But I think if you're gonna make statements like the one I just quoted, it might be helpful to the less informed if you clarified that you're running Koni+GC sleeves and not the typical off the shelf coilover. Just to keep miscommunication & misinformation down to a minimum.
Old 01-22-2011, 08:41 PM   #1731
madd ocx
madd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymoremadd ocx is not welcome here anymore
whats up going with a new setup soon so wanted some input on tire sizing.. i'm going with 17x9 +20 f and 18x9.5 +15r.. im on kyb agx with tein s.techs( low enough for nyc daily driving) on an s14.. i was thinking to go with 235/40/17 in front and 255/35/18 in the rear.. what you guys think? good balance? if not open to suggestions..
madd ocx is offline   Reply With Quote
Old 01-22-2011, 11:04 PM   #1732
Nick_04K
Nick_04K's Avatar
Talking out my ass? I sure wish you would elaborate on that. Seems how my statement was factual and pertinent.
And my statement was not rude...I just wanted him to know that a +20 on a 9j or 10j with the purposed tire sizes was going to need fender work and a decent amount of camber.
You say "straight out his ass" and then go on to say they'll both work? A little contradictory huh?
In most cases that setup will work! And it will be easier and most likely more effective than your purposed setup too, unless he's got a car capable of using the camber necessary to fit your setup. Which is doubtful.
Old 01-23-2011, 06:04 AM   #1733
Jay97240Sx
Jay97240Sx's Avatar
Jay97240Sx is an unknown quantity at this point
Send a message via Yahoo to Jay97240Sx
^ I agree with u kid.
Jay97240Sx is offline   Reply With Quote
Old 01-23-2011, 08:22 AM   #1734
simmode1
simmode1's Avatar
Not contradictory at all. It was a backhanded compliment. Maybe you'll learn about them when you get older.
Your proposed 17x9's for the front with offset between +17 to +25. Do you realize that my suggested +20 offset falls within that range? Do you also realize than going much higher than +20 in the front won't clear alot coilovers? Do you also realize that many ppl have been running 17x9+20 FN01RC's with 245/40 tires for YEARS now?
From way earlier in the thread: 17x9+20(effective) with 255/40's fronts. Rears are 17x10+25 with 275/40's. Rolled and only slightly pulled.
Does this camber look unneccessary or extreme? Not at all far off from my suggested 17x9+20 with 245/40's and 18x10+20 with 265/35's. His rears are 5mm less flush, but since the tire size I recommended was 10mm narrower and lower profile, should fit about the same.
There is a reason why I gave very specific specs instead vague estimate with wide margins, like you. It's because the sizes I recommended are common to find and have been done before.
And yes, you are a rude ass little kid.
Old 01-23-2011, 11:16 AM   #1735
Nick_04K
Nick_04K's Avatar
My reply was not only to your offset! But your offset matched with your tire size.
***A 18x10 +20 with a 265 in the rear will NOT put his 2jz power to the ground as effectively as a 265 with a higher offset wheel!***
And good job making up your "purposed" aspect ratios in your new post haha. You never mentioned them earlier. I quoted your original post to refresh your memory.
Sorry you got all butt hurt about me disagreeing with your recommendations and using the super duper offensive f word when i did it.
Oh and by the way..You are just a narrow minded 31 year old ass.
Old 01-23-2011, 11:19 AM   #1736
longfellow
longfellow's Avatar
Front - 17x9+15 255-40-17 NT05 - -2.2*
Front fenders are rolled only.
Old 01-23-2011, 12:02 PM   #1737
simmode1
simmode1's Avatar
Nick_04K, pipe down. I'm not gonna bother bickering with you. If you're poking around in this thread, I would have thought the aspect ratios for 17's & 18's would be obvious. My bad for not spelling it out for you, I guess.
The guy asked for a recommendation. I gave my opinion. You disagreed with it. Fine. Obviously, neither are wrong. They're just different.
Hopefully the guy who asked will be happy that he has options to pick from for his new setup, because there's more than one way to skin a cat, as they say. Now drop it.
Old 01-23-2011, 12:10 PM   #1738
kyles1988
kyles1988's Avatar
[url=http://www.rimtuck.com/setup.php?id=1266]RIMTUCK.com
Its also worth noting that the setup I have posted on there is different than the setup I mentioned above. Let's try not to spread misinformation or call anyone and everyone out.
Old 01-23-2011, 12:16 PM   #1739
kojiki88
kojiki88's Avatar
kojiki88 is an unknown quantity at this point
^^^Loving the set up! What are your fronts? And camber specs, plz!
Same here What are your wheel specs? and tire size upfront. Thanks
Sigh... Sry for this meaningless post. I didn't see the reply with his wheel specs. Sorry again.
Last edited by kojiki88; 01-23-2011 at 12:23 PM.. Reason: Didn't notice the reply.
kojiki88 is offline   Reply With Quote
Old 01-23-2011, 01:00 PM   #1740
simmode1
simmode1's Avatar
Oh cool. No harm meant. Thanks for the clarification... What coilovers let you fit 17x9+30's, if you don't mind?
