#62 |
![]() Join Date: Jun 2010
Baffled Power Steering reservoirs are fairly popular these days. Will most of you notice the difference? Probably not.
We're going to be offering 2 reservoirs, 1 baffled, 1 not. It will be +$25 more for the baffled can. I will get some pictures up of both the cans sometime this week. We changed the design a little bit. Thanks for the input folks!
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE www.ChaseBays.com | [email protected] | (205)623-2188 |
#64 |
![]() Join Date: Oct 2006
Trader Rating: (33)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 33 reviews
You have to answer for all the fields, so you have to say "no" to the cooler, if you leave it blank, you will get unavailable.
I had a cool signature |
#66 |
Added this to page 1.
This is pretty cool stuff. Been working on this since before we even released the kits. We came up with a great simple solution to those worried about baffling. Although its not necessary for most of you, figured we would do it anyways. Not the first to do this, this is something that been used in Road Racing for years. This is a simple baffle system that can keep our prices the same and can be standard on all kits. If you look at the first picture you can see that it looks like the -6AN fitting dead ends... ![]() BUT if you look closely it has two drilled ports on either end, this works as a simple baffle. ![]() Also we have a redesigned reservoir with a better looking cap/can. This can is what will be standard on all kits ![]()
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE www.ChaseBays.com | [email protected] | (205)623-2188 Last edited by Chase Bays; 12-02-2010 at 12:52 PM.. |
#68 |
ahh I will get that pic up this week
#72 |
Taking those pictures today.
Added VQ35 to the options on the site.
#76 |
Thanks for the orders guys! Keep em comin!
Sorry for delays for some of you, the demand is bigger than we expected for these. ![]()
#77 |
rhd available too? possible to get longer lines than shown? i also have 12" tubs and my midmount ic piping goes in your location then half inch from the tub so no room, already run my air filter infront of my radiator.
so if the lines were longer, i cud run from the rhd side of the rack under the engine on the crossmember, but the resevoir cant be located neither oem or in your loaction, i have 4 inches between the front of the tub to the rad support, so to the left hand side of the engine bay where the oem air filter goes is ok, and theres room near the windshied wiper motor. power steering cooler included with as well needed longer lines because of resevoir placement. looking to buy after the holidays. |
#78 |
Yeah the RHD kit is just longer lines.
Call us when you are ready to purchase and we will find a good solution for you.
#79 |
Forgot to post this, posted on page 1.
There is two ways to mount this. Zipties, or on the PS cooler there is a spot where you can slide in square headed bolts in and bolt it to your chassis (drilling required) ![]()
#80 |
awesome, the placement of that cooler is perfect for the pbm midmount setup, only difference im gonna have is rhd, and placing the resevoir on the inside of the strut towards the firewall/wiper motor so ya just some longer lines.
cant wait to get this after xmas, excited i found my solution ![]() |
#81 |
![]() Join Date: Oct 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
DAM, you guys are doing some great products, keep it up.
Im having problems with my brake setup so i want to do your brake Booster eliminator and your power steering setup, any chance of a package deal?
#82 |
Use the discount code CBDECEMBER on our website for 10% off!
#85 |
Not sure, looking into it. Any good pictures of the power steering pump on a VH??
#87 |
![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
really good looking stuff guys, so far everything you guys have been making looks top notch...also i have yet to see any negative feed back about your stuff so thats a definit plus since i want to buy some stuff of yours hah keep up the good work guys
#88 |
Thank you sir!
#89 |
I allready bought a FUJIISPL SS line for my RB before i saw this. I really want that resevoir is there anyway i could get just the resevoir and my line will work with it? im also interested in everything to get the cooler aswell.
#90 |
Yes of course, give us a call (205)807-8891
