11-09-2010, 09:42 AM | #3 |
Zilvia.net GB Vendor
Trader Rating: (65)
Feedback Score: 65 reviews
F/S sr20det. sr20VE VVL Headsetup,Stock SR20det running longblock...Z32 trans etc
Hey all parts are mine and can verify condition and what not
Feel free to ask me any ?'s if you are unsure about anything Jim @ J-Tunedmotorsports will ship if needed Paypal accepted Local pick-up is fine along with looking at the parts 60km JDM Z32 transmission ---great upgrade to ppl who want better gearing and stronger transmission. good condition runs I pulled off the front cover to machine to work with my sr20det but did no everything was cleaned and inspected. you get rear tail shaft seal front cover gasket all sensors in bags, bolts , spring ball, rear shifter fork and shifter etc $550.00 80km sr20det rwd coils all work--was one a stock t25 car $80.00 shipped sr20det intake mani $25.00 HKS EVC5 limited...5k miles..Comes with complete manuel boxes and paper work best boost controller around..can take out of s13 panel.. $399.00 shipped paypal fees included 65k miles My personal street car motor.. compression 155-170 No oil consumption what so ever--used Amsoil 10w30 was going to rebuild this but have a stroker motor and dont need this Motor comes with oil pan to headgasket. starter, alt, ps pit work belts water neck.thermostat Lower water tubes with coolant temp sensor and hoses (not pictured). Flywheel bolts, trans bolts greddy pulleys installed this motor runs and pulls great...The only turbo to see it bottom end was a t25 stock car $1300 SR20ve 1n5 vvl head swap for sr20det rwd. This pix was before I pulled of the head You want to rev 9k and not worry about rocker arms here ya go Notice the rocker arms are positioned on a shaft and are mechanical not hydrolic For all of you that know this head is the head to use if you want to have not rocket prob and want big ports. Is head outflows the stock sr20det low port head all day long..No need for porting or cams.. Before the vvl is activated the cam duration is like 240 and when it is activated its around 270-280 This head comes complete with 2 oil activated vvl solenoids, valve cover, gasket, bolts stud bolts, etc I can get you the intake mani, exhaust mani setup for this to work..tuning etc and tel you how to get it running..I have done a few of these setup for my customers. $1400.00 obo...I have other parts for this head swap i can include or leave out Big ports VVL head SR20det IAC sensor and knock sensor $50.00 shipped This is a redtop sr20det head...only used to bottem end off the motor..Head seems ok needs deck cleaning and some new shims and 2 hydro lifters I would replace the lifters and shims and do a freshenup on this. $200.00 all 8 rocker arms head small bolts etc This is a space long block but it needs a rebuild.Crank still seems to be good..My friend overboosted and poped the ring and piston..maybe it can be bored out or resleaved...$175.00u get oil pan to top. 4th Cylinder wall scuffed still cranks Last edited by JTunedMotorsports; 11-24-2010 at 01:19 PM.. |
11-10-2010, 01:39 PM | #5 | |
Can you get me a price for that personal street car motor shortblock shipped to 92507.
If it will lower the price, you can keep the oil pan/pullies/other stuff. I really just need the shortblock. Thanks!
Tags |
block, coils, iac, longblock, shortblock, sr20, sr20det, vvl |
